Question about Meade LXD55 AR5EC Achromatic 5 in f9 Refracting Telescope 05095503
Pinion gear for Meade 390 focus. worn teeth and loose on shaft
Where / how can I get a replacement part?
  • 3,186 Answers
You can send it to Meade -- but very expensive-- or you can buy a complete new focuser from these people-
http://www.optcorp.com/
http://www.telescope.com/control/main/
Posted on May 18, 2009
Flywheel or something grings against the starter when clutch is engaged
There is no way the ring gear will hit the starter pinion unless the fly wheel bolts on the crank shaft or loose allowing the flywheel to run out of true. If you have had clutch/ rear seal work done lately the fly wheel will only fit in one position and if that was ignored at some time then the fly wheel will run out and touch the starter pinion.. I would also check the adjustment on the starter pinion as it has to be set by the lever pivot to a correct distance or it will touch the teeth of the ring gear
Jul 28, 2013 | 2001 Ford Escort ZX2
My 2004 chrysler sebring its a 2.4 liter engine when I turn it on the engine makes a weird nose like if sumthing in the engine isnt rotating right what could it be
look for loose or missing starter bolts,the starter drive pinion gear either worn or damaged or flywheel gear teeth worn or broken. noise you hear if it sound like starter grinding noise check starter mounting bolts could be loosen or 1 missing or drive pinion gear or flywheel gear teeth worn or broken.
Feb 11, 2012 | 2004 Chrysler Sebring
I want to replace the starter
take off negative cable off battery take cable off starter take 2 bolts off starter put new starter on the same way
Feb 20, 2011 | 2003 Harley Davidson FXSTD Softail Deuce
The rack and pinion gear on the focuser for a meade ds 2000 telescope got stripped. I can't find replacement focuser .
You can possibly buy another focuser from Meade here:
http://www.meade.com/support/index.html
Orion Telescopes also sell focusers here:
http://www.telescope.com/control/telescope-focusers
Jul 21, 2010 | Meade DS-2130ATS (250 x 127mm) Telescope
The differntial has to much back lash. clunking noise starting and stopping.
Ring and Pinion may need replacing. Also check preload on the pinion bearings. Nut on end yoke may be loose. Sometimes the axle gears will make a clunking noise if worn out.Check out drive shaft ujoints, May have to remove ring gear and pinion to check for wear.
Mar 10, 2010 | 1993 GMC Sierra K1500
The focal tube on my Meade DS 114 has several stripped teeth. The auto-focus skips and jumps! Where can I find a replacement part (Meade no longer carries them) OR how can I repair this; ie, create new...
You will need to buy another focuser like one of these.
http://www.telescope.com/control/accessories/telescope-focusers/1*25-inch-orion-basic-rack-and-pinion-focuser
http://www.telescope.com/control/accessories/telescope-focusers/2-inch-orion-crayford-style-telescope-focuser
Feb 21, 2010 | Meade DS114-EC Telescope
Meade DS2102 Telescope lost teeth for focusing in and out
It might be easiest to see if someone is selling one on Craig's list or ebay.  You might be able to find one used where the telescope is OK, but the motorized drive is broken and replace the telescope.
Here is the contact information for Meade:
Contacting the Customer Support Center     Customer Support representatives are available to handle your calls and letters regarding any Meade product 7:00am to 5:00pm Pacific Standard Time, Monday through Friday, excluding holidays. To contact the Meade Customer Support Center, please write, call, or fax. Our information is as follows:
Meade Instruments Corporation
27 Hubble
Irvine, CA 92618
(800) 626-3233 (U.S.A. Only)
You could try calling them and see if they will sell the part you need for the focuser.  The focuser is called a rack and pinion focuser.  From your description it is hard to know if it is the long linear gear on the draw-tube (the part that holds the eyepiece) or the gear on the shaft of the focusing knob.  You will need to be able to describe that to them.
I hope that helps.
May 05, 2009 | Meade Optics
The teeth small pinion gear on the focus knob shaft are stipped
No. That's one of the trade-offs with cheap models, they can be fine but have absolutely no spares back up.
All you can do is to check whether the 'scope is covered by a manufacturer's warranty.
Jan 20, 2009 | Galileo 800mm-72mm Refractor Telescope...
Meade LXD55 AR5EC Achromatic 5 in f9 Refracting Telescope 05095503 Logo
304 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
