Question about Kenmore Refrigerators
Leak gathering under produce drawers inside kenmore fridge
Water (I assume) is leaking from an unidentified source and collecting under the produce drawers at the bottom of my fridge.
  • Anonymous Mar 16, 2014
    water gathering at the bottom of the fridge
  • Kenmore Master
  • 4,655 Answers
I can send you a video of that problem if you like. It's a Youtube video.
seabreezehvac@yahoo.com
Posted on Feb 28, 2009
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
Why do I get blobs of water on the inside of my salad drawer in my Fridgemaster. Fridge/Freezer
Leaking Refrigerators
I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil on the average of about every 8 hours so the water that accumulates during defrost has to go somewhere right?
APPLIANCE 911
Dec 15, 2015 | Refrigerators
Water collecting inside refrigerator
At the back is a little channel with a hole in that drains to the outside of the fridge. Remove the drawers and shelf and blow through the hole with a drinking straw.
Jun 13, 2012 | General Electric Refrigerators
We have a slow water leak in our fridge. The water pools under the bottom 2 produce drawers.
On most newer fridges, there is a very shallow 'V' shaped collection channel at the back of the fridge just above the bottom drawers, this is for condensate collection. In the middle of this channel there should be a hole, this quite often gets clogged, and over flows, hence the water at the bottom of the produce drawers, clear the hole and it should cure your leak, worth checking every couple of months.
Mar 22, 2011 | Samsung RM255LASH Side by Side...
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
I have a zanussi ZI 920/9K and the fridge has water under the salad drawer every day but the drain hole is not blocked - what else might it be?
two solutions
1...a door seal leak
2...you are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
Jul 05, 2010 | Zanussi ZI921 / 8FF Bottom Freezer...
Unexplained water accumulation under the crisper/produce
OK, I am going to give you a lot of information on one page, so please read carefully and choose the parts that apply to you. PS, Please rate my solution and my thanks to all the Guru's that helped put the following page together. please click on link below, Thanks Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 10, 2009 | Whirlpool Refrigerators
Water/liquid collects at bottom of refrigerator under vegetable drawers
For water collecting inside of a refrigerator, there is usually something leaking inside, or perhaps the door seal is letting moist air into it.
Jul 08, 2009 | Kenmore Refrigerators
GE Refrigerator, Model TBX22ZA
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
Refrigerators Logo
212 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
