Question about HP xw9400 Workstation - AMD Opteron 2210 1.8GHz - 1GB DDR2 SDRAM - 80GB - DVD-Reader - Gig... PC Desktop
HP laptop DVD Problems.
When I insert a DVD into my HP laptop, it cannot read it. It says there is no disk entered. It used to work, just one day it just stopped working. It reads some DVD's, but others it won't. It is so weird. And the DVD is clean, and spot free.
  • govideodfw May 07, 2009
    I have the same problem. My toshiba dvd drive will not play the dvd movies but it will play data dvd. When I load in a disk it does recognize the DVD title and windows media player launches and runs but the screen is blank and the video is not playing. Any suggestions would be good. Thank
  • Peter Steiert
    Peter Steiert May 11, 2010
    This might be a problem with the laser that reads discs inserted into the drive. Either it is dirty (you can't clean it) or broken. It is my personal opinion that it's easier to replace the DVD drive than it is to repair it.
    Novelist:
  • 148 Answers
Are the DVDs youre having problems playing movies? If so the decoder may be missing. Confirm for us if the disks youre having trouble with are movies. Data DVDs should play with or without a decoder. Programs such as PowerDVD should solve your problem if this is the case.
Posted on Mar 02, 2009
Dvd/cd rom not working
The drive may have failed. It can't read the disk.
Jan 16, 2014 | Computers & Internet
Dvd reading error
Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs
Sep 22, 2012 | HP Pavilion dv6775us Notebook
Ihv inserted the DVD in the slot..the disk is nt being read
You didn't mention if the dvd was working before or it's new.
Now, you have 2 options to try:
1) Try to open the same DVD on other DVD-Reader. If it was read, then the dvd is unreadable on your laptop, because it's bad, or the DVD-Reader have problems, OR
2) Try other DVD on your laptop, if it was read, then your DVD-Reader can't read all types of DVDs, if not, then the dvd is bad
Tell Us your results, please
Good Luck
May 13, 2011 | Toshiba Satellite L305-S5907 Laptop
Hi, my laptop model is LE50-FINE5, LG product. My problem is its dvd rom...this few days my dvd driver could read dvd r,dvdrw, cd r, and cd-rw. then the next day i used it, there was a problem, it cannot...
Hi there its a common problem with maximum laptop. Reason is hi speed DVD. CD work but when you run DVD a bad noise is came from the Disk driver, is it? Try to clean the lens & slowly insert the DVD in laptop & then see what happens. If no changes then you need to replace the Disk Driver. Just Let you know I also have the same problem & i am not going to change it , because i know i will face same problem after few months. Thanks.
Nov 18, 2010 | LG X-Note LM50 Notebook
DVD/CD-ROM drive not working. Drivers were reinstalled and still not operational. Message received that there is a problem with the registry - how can this be fixed?
Find a "bootable" CD-R disk (Ubuntu Linux, Microsoft Windows Vista, Microsoft Windows 7) and restart your computer, and tell it to "boot" from the disk inserted into the CD/DVD disk. If it reads from the CD/DVD, then the hardware is OK. If it cannot read the disk, then it's time to replace the "broken" CD/DVD device.
Aug 02, 2010 | HP G60-230US Notebook
How do i restore my hp hdx18 to factory install settings? completely wipe it
Turn the computer off.
Turn the computer on, and look for a message like "press BLAH to enter System Recovery".
When you see the message, press the BLAH key.
This will start a complete "restore-to-factory" install of Windows.
Or, if you have a set of "System Recovery" CD/DVD disks from HP, then insert the 1st disk,
restart your computer, and select to boot your computer from the CD/DVD drive.
Or, there may be software already on your computer that lets you "burn" a set of "System Recovery" CD/DVD disks -- have 10 CD-R disks, and 5 DVD-R disks -- you may need to use most of these "blank" disks.
Apr 23, 2010 | HP Pavilion HDX18T Laptop
I have a Zd8000 hp laptop and the cd rom doesnt read or write but if i insert a dvd it work reads and writes the disk, how do i go about fixing this issue, mark
That is a lens problem, CDRW and DVDRW use different focus , and the lens is working only on DVD , try using a lens cleaner disk.
That probably will not work, in that case replace the DVDRW that is not an expensive part.
May 04, 2009 | HP Pavilion dv8000t Notebook
Drive cant write any disc
If the unit was working ok and suddenly the unit stop to read the blank disk, the problem could be related to a dirty lector (need to clean) or unit firmware (need to be updated)
In that case you can update your firmware here:
http://drivers.softpedia.com/progDownload/Matsushita-DVD-RAM-UJ-840S-104-Download-14615.html
Remember
1) You have to use a blank "recordable disk" to allow your drive write a disk
2) Not all disks are compatible
3) Try differents brand
4) Clean your drive lector
5) Update your firmware
Oct 24, 2008 | HP Compaq nx6310 Notebook
Hp Pavilion dv6000's dvd-rw won't work
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
DVD Drive not working properly
Try cleaning the drive with a cleaning disc (purchasbale at most electronics stores like Best Buy or Circuit City). If that doesn't get it up and running, it'll need to be replaced.
Jan 29, 2008 | HP Pavilion dv6000z Notebook
HP xw9400 Workstation - AMD Opteron 2210 1.8GHz - 1GB DDR2 SDRAM - 80GB - DVD-Reader - Gig... PC Desktop Logo
109 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
