Polaroid LCD TV not working with HDMI- says HDCP issue?
My TLX-04240B worked fine at 11am. At 2pm when I tried to access the TV or DVD (both connected with HDMI cables) it won't show anything. For the DVD I get a blank screen. For the TV (which is connected through a Series3 TIVO) I get a message saying that HDMI connection is not authorized "click select for more information" so I did. It says my TV is not compatible with HDCP Digital Rights Management Standards. When did that change? I've had the TV for 18 months and no problems. I followed the troubleshooting from TIVO's website which suggested checking in the settings if HDCP is enabled (it was not, but there's no option to enable it). It said to disconnect both ends of the HDMI cable, then reconnect. Tried that (with both cables) no change. The only other solution it gave me was using the RCA cables. That works. But I bought a 1080p TV for a reason- not to use the RCA cables.
Polaroid website has no suggestions. Any ideas?
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
Posted on Jan 04, 2008
SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central 2. Settings
3. Remote Control 4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
Posted on Mar 11, 2008
budmrtn
  • 11361 Answers
SOURCE: I am looking for a Polaroid TLX-04240B service
http://www.polaroidsupport.com/polaroid/en_us-sm.html
Posted on Dec 03, 2009
  • 470 Answers
SOURCE: i have a polaroid tv tlx-04240b
The power supply pn#860-AZ0-IPOS250H is around 100.00
and the control box is around 90.00
Mind you they are used but taken from good units.
Discount-merchant.com
If you get one remember to switch out the prom by the red LED if you get one from a different model such as the TLA-04011C
Posted on Dec 07, 2009
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
Replace both HDMI ports on television
I doubt you could replace just the ports. You would probably have to replace the whole board. I wouldn't spend the money.
Jul 28, 2016 | Polaroid Televison & Video
How do you connect a polaroid lcd tv to a polaroid vcr/dvd combo?
does it have HDMI INPUT/OUTPUT? OR Audio video input/output? First you must have a cable for either of those two. HDMI (from the lcd tv) to HDMI (vcr/dvd combo).
audio/video input (from the lcd) to audio/video output (from the vcr).
hope this helps.
Jul 06, 2011 | Polaroid TLX-01911C LCD TV
I have a Polaroid TLX-04240B It comes on and Displays the Polaroid logo, then it goes to a black screen with the HDMI1 input box on the top right hand corner. THis box eventually disappears, leaving me...
Buy another HDMI cable.Try another HDMI cable with another HDMI hub on the tv port.If u still have the same problems,mean the whole main tv Tuner signal board have problems and the caused.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.
May 19, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
I HAVE A 42" Polaroid LCD TV (TLX-04240B) that i
First, I doubt that the power supply and MB are "connected", so they likely lied to you. As far as parts go, you can get them on Ebay, probably for around bucks total for the power supply and MB. This is important, Just because the model number on the TV matches the model number on the part, it doesn't mean it is the right one...the manufacturers sometimes use different boards on the same TV's. So make sure you are looking at the numbers on the boards and that they match before you buy it. Honestly though, you never know what you are getting on ebay as far as used boards and power supplies go, by the time you pay for shipping ETC you are going to be probably 150 to 200 bucks into it...and it might not work, or it might work for a while then the used parts go out as well. Best Buy has a 43" sharp LCD TV, smart, built in Roku...for 269. You might be better off to spend the extra 50 to 100 bucks and just buy a new TV, and definitely better off buying a new TV than paying some scam artist 400 bucks to fix a TV. Either way, good luck!!
Jan 04, 2018 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid TLX-04240B going to a black screen after running for 2mins. Any ideas on how to fix this?
open the black plastic panel and the aluminum panel which has 3 screws each in the back of the tv.
look at bottom left corner of top board. to the right of the red led light,
there's these four white small switches. turn the bottom two switches to "on" and tv should be working.
It's very simple to fix the problem to everyone.
My tv capacitor was not the problem.
I hope this will help everybody.
Jan 04, 2010 | Televison & Video
I HAVE POLAROID TLX-04240B TV,HAS PICTURE STAY ON FOR AMOMENT &DI
I'm looking to purchase a broken TLX-04240B, the screen on ours is cracked. If you did not fix yours, I would be interested in purchasing it.
Sep 07, 2009 | Polaroid Televison & Video
Polaroid tlx-04240b loses picture
I'm very appreciate to jranada's solution, my tv gets new life.
May 20, 2009 | Polaroid FLM-4201 42 in. LCD Television
Selecting 1080p
Hd tv only has 720p picture ability
bluray xbox playstation 3 needs a hdmi cable connected to enable 1080p
Apr 19, 2009 | Polaroid FLM-4201 42 in. LCD Television
Can the remote do a code search? I had to do that with my Tivo remote to control my new Polaroid.
Nov 26, 2007 | Polaroid FLM-4201 42 in. LCD Television
Televison & Video Logo
1,329 people viewed this question
Top Televison & Video Experts
