Question about Peg Perego Vespa Scooter
Have lost all lights indicators and petrol gaugue reading. checked one fuse(7.5) were workin when last used
Just had the same prob.
It could be a broken solder joint on the lighting coil on the stater plate.
Remove the flywheel and visually check. The smallest blob of solder cured this on my Px 200 disc.
Posted on Mar 08, 2009
Matize main beam stopped workin lights flickered when indicated right but now nothing checked bulbs fuses any ideas
relay?bad ground ?have it checked at the dealer diag on the computer on your car will show up codes for problem
May 03, 2016 | Cars & Trucks
How do I rectify indicator lights not working at all, on a 2003 Toyota Prado (Petrol)
If the blinkers on the car are working when the trailer is not connected but they fail when you connect the trailer plug, it is because the LOAD of the bulbs on the trailer exceed the capacity of the BLINKER CIRCUIT of the vehicle. I would recommend replacing the tail lights on the trailer with LED tail lights. Did that on my travel trailer, and it solved the problem 100%
May 09, 2015 | Toyota Cars & Trucks
Holden cruz petrol cap will not open
i have a problem with my VW Bora 2002 ,2.0 engine .
i drove home last night and today the lights did not switch on , no indicators , no wipers and no AC
but the hazzard lights go on and the head light or brights.
it drives normall , I did check the fuses all of them looks good.
any one can help?
Nov 22, 2013 | 2001 Volkswagen Golf
My dignostic box is not workins to check the check engine lights, what do I do?
If you have a fuse Blow in your escalade ,Your dig. box will not work
Nov 26, 2011 | 2002 Cadillac Escalade
200 chevy blazer 4x4 is not workin it is push button and the indicator lights dont light up at all
Check the fuse in the fuse box first and replace if the fuse is bad. If the replacement fuse goes bad again, check the wire harness at the encoder motor on the transfer-case. Look for any damages causing a short making the fuse to go bad, once the harness and connectors are good. Inspect the encoder motor, check to see if it's not the problem causing the fuse to go bad and if it is. Replace the encoder motor, good luck and keep me posted.
Feb 21, 2010 | 2000 Chevrolet Blazer
My Bajaj Pulsar's carburetor is giving problem. I am getting black smoke and also sometimes there is overflow spillage of petrol whi;le it is standing. Further intially the RPM indicating are high. Can...
black smoke sounds like its running rich. and fuel leaking out is probably due to either a fuel soaked carb float and or a bad needle and seat.
You should get your carb checked for a possible rebuild.
Jan 03, 2010 | 2007 Bajaj Pulsar 150
My KitchenAid dishwasher quit workin no light no nothin, float switch is good, having problem troubleshooting water fill valve with solenoid???
Thanks for using FixYa. Please check for the following if your dishwasher is not working--
1. Fuse (blown or tripped).
2. 120 VAC supply wiring connection faulty. Repair or replace wire fasteners at dishwasher junction box.
3. Electronic control board faulty.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate when START or OPTIONS is depressed.
Please do rate the solution and revert for further assistance.
Nov 18, 2009 | KitchenAid Dishwashers
Escort 55 problems
water ingress on top of fusebox above drivers footwell is common problem.
Aug 19, 2008 | 1998 Ford Escort
Peg Perego Vespa Scooter Logo
291 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
