Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Ec12 hitachi air compressor will not build pressure higher than 40psi
  • 52 Answers
Most likely the the reed valves are stuck or miss aligned. Worse case senerio your piston seal blew causing this not to build pressure. Read manual on how to disassemble head. to remove should be 4 bolts and your copper line, just be careful of the reed valve plates, they are thin steel that sit into the head. Put back the same way you took it apart.
Posted on Mar 02, 2009
Wont build up air presher on ec12
Low pressure ususally caused by faulty reed valves /gaskets in the head. Easy to check. When compressor reaches highest pressure, check for air blowing out of the intake or no or very little suction. If the compressor has reached highest pressure and you still feel very good suction, suspect air leaking out of system. Check all fittngs with soapy water or shut off the compressor and listen carefully for air leaks. Repair as needed. If faulty reed valves, you can make them using feeler gauge material or purchase from www.toolpartsdirect.com
Oct 21, 2011 | Hitachi EC12 Portable Electric 2hp Air...
My Hitachi EC12 builds pressure, shuts off, then air escapes
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However, I do want to replace it before the warm weather come to the north. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit and when using an extention cord I have a 10 guage cord that will carry the load needed to run the EC12. I have also changed to 100% synthetic oil.
May 15, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I have a Hitachi EC12 Portable Electric 2hp Air Compressor. It builds air pressure fine and shuts off normial. But if I attach a blow nozzle or another attachment to the hose and try and use it, the...
This is a stab in the dark.....but have you emptied the condensation out of the tank? It may reach max pressure....but have little air compressed inside the tanks. Just a guess.
Dec 13, 2009 | Hitachi EC12 Portable Electric 2hp Air...
My hitachi EC12 compressor starts up and fills the two tanks. When I connect my hose, the pressure in one tank drops to zero, then goes back up to about 60 psi, then very slowly builds back up to max...
how do you know one tank drops to zero unless you have a pressure gauge on both tanks sounds unlikely unless you are looking at the gauge on the pressure regulator
Nov 18, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Do not have manual for hitachi ec12 air compressor, cannot increase pressure
You have to manually adjust the pressure regulator. Make sure drain is completely closed. The one thats on the bottom of the tanks
Aug 29, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hatachi EC12 Portable Compressor When I start the
well make sure air pressure is not too high. if not just replace it any air supply house carries them
Jul 02, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Ec12 hard restart after drop in air pressure
It sounds like the air pressure assembly unit is not reading the pressure drop. some of these units have adjustments under the covers and be reset.
Aug 31, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC12 Compressor- weird hum
The burst of air you hear as the compressor shuts off is the cylinder unloading so it will not have to restart against a high pressure load. If the unloader is electrical it would explain the hum that you hear. This could be a normal function.
Aug 24, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
377 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
