Question about Frigidaire FDE336RE Dryer
Need to put a belt on frigidaire dryer model fde546res2
I want to know how to put the belt on my dryer?
  • Anonymous May 17, 2009
    How do you put the belt on?
  • 70 Answers
Ok. this is a HARD job.
First you need to release the top from the cabinet.look where the top closes and you will see 2 release tabs that you must press in with a flat blade. lift open top and you will see 2 screws that hold the front on, remove them and move the front to the side( careful not to pull on the wires that go to the door switch,if you remove them, mark what terminal they go on)
slide the belt grove side down onto the drum. now go to the back and remove the little plate so you can see into the rear where the motor is.loop the belt around the motor pulley and theypull the idler arm & pulley away from the side and loop the blet over it( this will cause back tension and hold the belt in place) once you do this, move to the front and reassemble the unit. I hope this helps.
Good Luck!!
Posted on Mar 01, 2009
The belt is broken i have a new one i need to know how to get inside the dryer
Hi Cyndy s
Go to the following webpage and watch the video on how to dissassemble your Fridgidaire Affinity Dryer this is for the front slide replacement but you will remove the drum and you will see where the belt goes.
http://www.youtube.com/watch?v=yIPnnUqJ6Ds
For parts and a schematic of your dryer.
http://www.appliancepartspros.com/parts-for-frigidaire-aeq6000es2.html
If the belt is broken and you don't know how to route the belt check out the following picture
Please rate me
Bud
Oct 25, 2012 | Frigidaire Dryers
Noise in dryer Frigidaire model fde336res1 when running
Could be the drum bearings are worn. These are what the dryer drum turns on and when they wear out the drum and frame rub together (metal to metal). Also could be the belt idler which keps the belt tight around the drum. In either case the dryer would have to be internally accessed to determine failure.
Feb 17, 2010 | Dryers
Washer and dryer capacities
4 cubic ft washer
7 cubic ft dryer
Feb 17, 2010 | Frigidaire FDE546RE Dryer
Frigidaire dryer - tub will not tumble/turn....what to do? Can read all of the model numbers....the label has a crease it in.
If the machine sounds like it is running but the drum is not turning then you most likely have a broken or unseated belt. Just open up the top of the dryer and have a look at the belt on the rear of the drum usually. Most appliance parts stores should carry belts but you would need the model number to know which belt you need. See if you can find the manual for the machine. Otherwise you'll need to have a pro come and figure out your model number.
Dec 13, 2009 | Frigidaire Electric Dryer
Tensioner fell off when changingh dryer belt
i do have the mapping you need but dont know how to get it to you...so go to fixya.com parts and see if you can pull it up by model number,,if not i will be glade to walk you though
Dec 29, 2008 | Frigidaire Dryers
Need Help replacing dryer belt
PUT BELT AROUND DRUM FIRST AND NOW YOU HAVE TO GET TO BACK OF DRYER ,SHOULD HAVE SMALL PANEL AND ISTALL FROM THAT SMALL REAR PANEL NOT EASY
Nov 29, 2008 | Dryers
Need to know how to replace the belt on my dryer
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Frigidaire FDE336RE Dryer
REPLACE BELT
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Oct 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
430 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
