Asko washer model W6222 Error message F3 what does it mean and how to solve
  • lisaetJohn Mar 24, 2009
    Hi.  I don't have this machine but I'm considering purchasing the Asko w/6222 washer.  Have you experienced other problems with this unit and did you have your F3 message error fixed?  What would be your review of the Asko w/6222?  Thank you for your input.
Guides.homeeverything.com/cache/FILE24924.PDF
to fix this, check this out - addresses all issues with this machine.
Posted on Jul 02, 2010
  • mbwals Jul 02, 2010
    Most likely the issue is water level error - which also causes weight errors in the spin cycles. so open the small door on the bottom left, then get a little bucket ready to drain water into. look for the tube that's connected to the inside of the hinge of the small door. pull it off the door (tug hard if it's the first time) and get ready for water to come gushing out. drain it into the bucket (this may take a while or a few trips to the sink to empty the bucket). if you need to stop water flow, just pinch the tube with your fingers and slip it back into place on the door while you're emptying the bucket.
    once you've emptied the water, turn the valve and open the little hatch. clear out any debris and on the bottom there's a little hatch you can open with a screw driver to clear out any additional debris. The last part is just extra. most likely it's a water level issue.
    What i did is remove enough water to manually open the door (right above the drain tube in the little door on the bottom right, there's a screwed in red pull valve). use that, empty the stuff from your washer and reset, then run a test wash.
    All good ~
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
• that no objects are stuck in the drainage
hose outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump (see the
"Care and cleaning" chapter).
• that there are no kinks in the drainage
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
May 30, 2008 | Asko Washing Machines
F3 Error Message
F3 is a pump problem check the pump trap and clean it this should clear it up...
Aug 25, 2007 | Asko W6441 Front Load Washer
My ASKO W6222 won't drain
Sounds like the inlet water valve is not seated properly and is letting water in when it shouldn't .
Jun 20, 2012 | Asko W6222 Top Load Washer
What does f3 flashing mean?
F3 error code means your washer has not drained. To fix the washing machine error code is simple and straight forward. Simply remove the drain pump filter and slide the filter out and clean the debris inside. The filter in most cases is on the lower bottom panel. Simple depress the tab and fold the access door down. The washer drain pump filter is a white handle twist the handle to remove the filter. You may also find an article of clothing trapped down where the filter is like socks or change etc. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Jul 08, 2011 | Asko W6222 Top Load Washer
During the washing circle the machine stops and F3 appears in the time window and machine cant restart
If F3 is flashing, then you are having a problem with drainage.
Check that there is no object stuck in the drain hose outlet. Check that the pump is not blocked by foreign objects and clean the pump. Check that there are no kinks in the drain hose.
After making these corrections, run the drain program or press the key button (door open) to empty the machine.
Feb 10, 2011 | Asko W6222 Top Load Washer
Hi, I have the ASKO W6222 front load washer, my
if the valve was stuck open it would run all the time the washer was on i would say that there is a power short running to the valve turning it on when not selected
sonic boom electronics australia
Jan 04, 2011 | Asko W6222 Top Load Washer
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
F3 Error Message
The F3 error code relates to a pump problem Check pump trap and clean. Good luck!
Washing Machines Logo
476 people viewed this question
Top Washing Machines Experts
