Question about SanDisk Sansa Clip MP3 Player
Sansa fuze my sansa fuze wont say it is connected when plug it in the usb port it will only charge
  • 8,596 Answers
Make sure the hold/lock is not enagged
Try another USB port
If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 08, 2009
SANSA FUZE CHARGER
The Fuze charges through its USB connector. You can plug it into a powered USB port on a computer or a USB charger plugged into a wall outlet. You may already have one of these for your cell phone.
If you need a connector cable, you may order one here. One AC adapter is here.
Mar 16, 2012 | SanDisk Sansa e260 MP3 Player
Will my sansa fuze charge even if the driver is not on my computer
MP3 players charge up by the USB cable that is connected to a computer or by a 5 volt USB mains adapter.
Feb 18, 2012 | SanDisk Sansa Fuze MP3 Player
I'm trying to charge my sansa fuze battery. I plugged it into the USB port of my IMAC, but the charge meter on the fuze never changes, it stays with the same charge. Do I need to do something else?
Battery : Remove the back and check and see if
the battery isn't fully connected I put a folded peace of paper and put it on top of the battery and put the back on.
Jun 15, 2010 | SanDisk Sansa e260 MP3 Player
Can i play SanDisk Sansa Fuze 2GB MP3 Player while charging
It depends. What's charging it?
If it's connected to a computer's USB port, then no, you can't listen to it.
If it's connected to a USB charger, such as you might find for cell phones, then yes, you can listen to it.
May 14, 2010 | SanDisk Sansa Fuze MP3 Player
When i connect my fuze to the usb port in my cd player i dont hear any songs jus says "check"
The USB connection on the Sansa is to communicate with a computer (and incidentally to charge the battery). It's not intended to connect to a CD player.
Mar 04, 2010 | SanDisk Sansa Fuze MP3 Player
How to charge Sansa in Windows XP
Use the supplied cable. Plug one end into the slot on the bottom of the Sansa, the other end into an available USB port. As long as the computer is supplying power to the port, the Sansa should charge.
Oct 09, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze of 4gb wont charge
Hi
I have sansa clip which i believe behave the same it never says charging it always says connected but that does not mean it is not charging .
leave your sansa connected for a while and then see if the battery meter has changed .
hope it helps
Enjoy
Jul 17, 2009 | SanDisk Sansa Fuze MP3 Player
Computer will not read Sansa Fuze
did you try to connect from your sanza to onboard usb don't use the front of your pc usb maybe wrong setup or wrong connecting the wire . use the usb located at back of your pc , if you connect the sanza to you pc if have words appear ( found hardware)it mean the sanza need the software driver and you unable to detect without driver..
Jul 05, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa fuze wont charge
Some USB ports cannot supply enough power to charge the Fuze. I had the same problem. I worked around it by getting a wall charger from RadioShack.
Mar 15, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa Fuze wont work with home stereo
The Sansa doesn't play music through the USB port. You can connect the Sansa to your stereo via the Sansa's headphone jack.
Feb 22, 2009 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
682 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
