Question about GE WJSR2070B Top Load Washer
GE washer stopped spinning and smell of burning out lingered
GE washer does not spin and earlier it smelled like something burnt out. How do we fix this? Does it require an expert?
  • tford6 Apr 01, 2009
    Mine is doing the same thing but it will not drain either.
  • ottisn May 10, 2009
    Washer will not spin and I smell something burning. I checked the belt and it seems fine. I can hear water inside the unit, but not visible in the tub.
I am going through this right now and best I can tell..needs a new belt. Pop the front off of your washer (UNPLUG IT FIRST:)) and see if there are black shavings on the bottom. The appliance place where we usaully order our parts from do not carry this belt in stock so it will have to be ordered. Price from them was $19.00+ tax
Posted on Aug 13, 2009
Washer smells like burnt rubber
What is the make and model of your washer? I had a similar problem with my Maytag - there was a burnt resistor on the control board. We ended up just buying a new washer since the cost for parts alone was close to $400...the labor would have been a DIY-thing (15 minutes easily for the greenest amateur).
Nov 28, 2011 | Washing Machines
Frigidaire FEX831CS Top Load Stacked Washer / Dryer will not spin - burn smell
The transmission is burnt out. Happened to my mother in law a few months ago.
Nov 13, 2011 | Frigidaire FEX831CS Top Load Stacked...
The washer was in spinning cycle, when I smelled plastic burning, then it stop all together. I was able to turn it off, but now it doesn't do anything. What could this be?
It will be good to start with looking into the washer with the power switched off smelling for the source that burnt. this will be easy to find and the possible area could be the power section in the main board- the control board.
Once you have isolated the burnt component we can decide if the part alone can be changed or the full board needs a change.
The motor and the drain pump also must be checked for any burnt outs.
Dec 02, 2010 | GE WSXH208A Front Load Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
My GE Eterna washer doesn't spin and smells of
YOU NEED A NEW BELT AND AN ADJUSTMENT
STEVE'S APPLIANCE
516-300-3249
Apr 06, 2009 | GE Washing Machines
Washer stopped spin cycle smell like burning rubber
hello if the belt is broken quite easy to put back on .take the back off you should see the belt if it has snaped or just come off .at the bottom of the washer you should see the motor at the back of the motor you should see 2 nuts this holds the motor on get a felt tip pen and mark the 2 nuts where they are fixed so you know where to tighten back on . get spanner and loosen the 2 nuts the motor should drop down put the belt back on and tighten up good luck
shaun
Mar 31, 2009 | GE Washing Machines
Burning smell and washer will not spin
The buring smell could be coming from the belt, try looking to see if the belt i burnt or broken
Nov 22, 2008 | Whirlpool LSN1000LW Top Load Washer
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
GE WJSR2070B Top Load Washer Logo
1,042 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
