Question about Kenmore Elite 45986 Front Load Washer
Water not draining into tub from dispenser. how do you unclog dispenser drain?
    President:
  • Kenmore Master
  • 2,651 Answers
The dispensor has no drain simply a hole that feeds teh tub, you can remve the bellow/rubber boot from the front of machine( pullllback the rubbe rto reveal the spring clamp) only removefromfront the rear will cause you much grief to reinstall, after removing hte front you can see the end ofthe drain line perhaps a small sock/washcloth is in ther clogging the port
Posted on Mar 01, 2009
How do I unclog my tub?
Put a cup of Baking Soda in drain, then add two cups white vinegar! This should foam like crazy wait ten minutes ,run real hot water.
you may have to repeat a couple times.
this will not hurt pipes unlike some drain cleaners.
Oct 02, 2016 | Moen & One Handle Tub & Shower Faucet
Tip
Winterizing a Washing Machine
If you keep your washer in area where you need to winterize for the winter (unheated garage or unoccupied vacation home), the following steps may provide you with some helpful guidance in preparing before extreme temperatures occur and possibly leave you with damaged plumbing and/or a ruined appliance.<br /> <br /> <b><u>TOP LOADERS</u></b>:<br /> <br /> 1. Turn off the main water supply to both water taps.<br /> <br /> 2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.<br /> <br /> 3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.<br /> <br /> 4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub, and any water remaining in the drain pump or drain lines. <br /> <br /> NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).<br /> <br /> 5. STOP or CANCEL the timer on the washer and UNPLUG.<br /> <br /> 6. Wipe down and dry the wash tub.<br /> <br /> 7. Clean the detergent dispenser and fabric softener dispenser and ensure they are dry.<br /> <br /> 8. Store washer, unplugged in an upright position.<br /> <br /> <br /> <b><u>FRONT LOADER</u></b>:<br /> <br /> 1. Turn off the main water supply to both water taps.<br /> <br /> 2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.<br /> <br /> 3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.<br /> <br /> 4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub and any water remaining in the drain pump or drain lines. <br /> <br /> NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).<br /> <br /> 5. Press PAUSE/CANCEL twice to halt the cycle and UNPLUG the appliance.<br /> <br /> 6. Wipe down and dry the wash tub.<br /> <br /> 7. IMPORTANT: Check the perimeter of the door bellow (gray rubber seal) and make sure no small articles of clothing are left in the rubber folds. Clean this area thoroughly and dry. NOTE: Anything left behind will mildew over a period of time causing foul odors.<br /> <br /> 8. Clean the detergent dispenser drawer of any remaining water or fabric softener residue.<br /> <br /> 9. Store washer, unplugged in an upright position.<br /> <br /> <b><i><u>Secondary Method</u></i></b>: <br /> <br /> If you cannot find RV antifreeze (or prefer not to use it), another method of draining the washer is to remove the drain hose from the standpipe at the wall and pull a vacuum on the line with a wet/dry shop vac. This will pull any remaining water from the drain pump and lines. <br /> <br /> If a shop vac is not available, lowering the drain hose from the standpipe to the floor will allow it to drain using simple gravity. <u>IMPORTANT</u>: On a front loader, you may have to remove the drain line from the drain pump to drain the pump. Or, use the access cover (if equipped). Most front loader pumps are accessed by removing the lower panel directly below the door.<br /> <br /> <b><i><u>Taking the Washer out of Winter Storage</u></i></b>:<br /> <br /> To remove antifreeze from the washer following storage, run the appliance on a complete cycle with detergent and NO garments added.<br /> <br /> I hope you find this information helpful. If you have any questions, please let me know.<br /> <br /> <br />
on Aug 09, 2011 | Washing Machines
Why does my GE model number TBX1811 refrigerator leak from the back inside the fridge
Water leaking inside it
  1. Check the lines to your dispenser
If the lines to your dispenser are broken or damaged you will need to replace them.
  1. Damaged drain pan
If your drain pan has holes or cracks it will also need to be replaced.
  1. Clogged drain
If you experience any clogged drains, they must also be unclogged or replace. If you experience this at the ceiling of your unit it can be attributed to a clog in the freezer section. Remove the divider and let the insulation thaw out and dry.
Mar 28, 2015 | GE Refrigerators
Fix water leak in water dispenser
  1. Clogged drain
Sep 08, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
How to clear a blockage in the drainage tube from the soap dispenser to the tub?
best to take the top off by removing the bolts in the back the slide it to the back then off.you then can get to the hose and remove it.
May 04, 2014 | Samsung Washing Machines
Dishwasher not draining
drain hose should be attached to drain under the sink. pull it loose from that drain should be a small hoe with a black end on it. use a wire coat hanger to run through the hose to loosen clog.
Jan 23, 2013 | Bosch SHX45L05UC Dishwasher
My washing machine is having trouble getting past the rinse cycle. I checked the hose made sure it was secure and clear of any debris hair etc. Then tried to resume draining but once it starts back up it...
YOUR PROBLEM IS DOOR SWITCH OR CLOGED DRAIN PUMP THER SHOULD BE A ACCESS PANEL FOR THE DRAIN PUMP SO YOU CAN GET TO THE PUMP AND UNSCREW THE OUTLET TO UNCLOG DRAIN
Apr 26, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I can't drain the water from the tub. we just had it installed and has been filled with water so that the tub can set. but now i can't get the water out!!
Is the trap and drain not installed yet? If there is no plumbing to drain into then I would siphon or pump it out into buckets.
Jan 21, 2010 | Price Pfister Hanover 950-102S Soap &...
Have water under crispers not going to pan think drain tub e mite stoped up took frezer apart could not find it where is it
It's located below the coils inside the freezer at the very bottom. The water comes from the coils. Take a turkey baster filled with water and push the water down the drain. This will unclog the drain.
Oct 16, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Jun 07, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Kenmore Elite 45986 Front Load Washer Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
