Question about HP Media Center m1264n - 3.0Ghz 1024MB (PW784AA) PC Desktop
Memory upgrade on HP Media Center m1264n?
I opened the case, but the place where i need to install the memory chips is being blocked by other parts of the inside of the computer.
I have no problem digging around in there so long as somebody gives me clear directions. Please help.
    President:
  • 1,223 Answers
What is that part that is obstructing the RAM fitting place , it may be DVD drive came too close to the RAMS dont worry just see the screws of drive take them out from both sides and just slide ur drive out from there in the front direction now u can easily replace rams other wise send me a photo of ur mother board and casing i will provide u solution on zohail2008@yahoo.com
Posted on Mar 02, 2009
My e-machines will not let me upgread my ddr2 1eb memory
That Machine would take DDR2 PC2-5300 upgrade chips. The max that system could take would be two 1GB sticks for a total of 2GB or 2048MB of memory. Memory is fairly easy to damage with static discharge and is also very easy to not put in all the way. When putting it in, unplug the power from the computer, push and hold the power button for 20-30 seconds to help discharge power from the computer, Line up the pins on the memory and push them into place till the little arms at the sides of the slot pop up and click into place. I'd install one chip at a time, powering the machine up after the first chip to make sure it works, then starting over again. The only time I'd install both chips at the same time would be when installing a memory kit (two or more chips in one package), in which case, install both chips before powering it on.
Jan 13, 2013 | E-Machines T5082 PC Desktop
How to upgrade RAM for compaq nx9010
Upgrading memory helps improve system performance. By following the step-by-step instructions in this document, you can successfully upgrade random-access memory (RAM) for all HP and Compaq notebook computers. While the graphics might not match your specific computer model, the steps will work. Read all instructions carefully before attempting memory installation. NOTE:Do not purchase memory modules until you know the type of memory used by the computer, the maximum amount of memory the computer can use, and the memory slot configuration. How to find the product number of your HP notebook PC To order replacement internal components such as memory, you must know the exact product number of the computer. For many HP notebook PCs, the product number and serial number are printed on a label on the bottom of the computer. Also, the product number and serial number are printed on the outside of the shipping box that you received when you purchased the computer. Product number locations can vary, and there are numerous methods to find the product number of your notebook. NOTE:A general family name may be imprinted on the case near the keyboard or on the frame around the display screen, but this does NOT provide sufficient information for ordering replacement parts. Finding memory information for your computer model (amount installed, maximum supported, and type of memory) Important memory upgrade information is in the specifications document for your HP computer. To find product specifications, browse to the Product Information category on the support page for your computer model. Refer to the Memory section within the product specifications document for memory information specific to your computer. Among the information listed, take note of the following items. It will be useful when purchasing memory and when performing the next steps. Amount of memory installed - The current amount of memory installed on your computer. Go to Verifying how much memory can be added to verify the amount of memory currently installed. Maximum memory supported - Subtract the amount of memory already installed from the maximum amount supported by the system to determine how much memory to get. You can also buy the maximum amount allowed and replace the currently installed memory. Once you know the maximum for your system, check Maximum memory supported by operating system to see how much memory your version of Windows will support. Use the lower of these two numbers as your maximum memory. Type of memory (including speed) - It is recommended to get the same type of memory (same size, same speed, same manufacturer) for each slot. For best performance, get the fastest memory that the motherboard supports. CAUTION: Due to the variety of possible configurations, some motherboards might not be able to properly configure memory if the array of small outline dual in-line memory modules (SO-DIMMs) contains a SO-DIMM that is not from the same manufacturer, has a different CAS latency value, or has a different density value (high and low used together). Make sure all SO-DIMMs meet the requirements of for the motherboard (the information listed in product specifications), have the same part number, are from the same manufacturer, and meet the basic memory requirements for your motherboard. If not, make sure that you can return the memory if it is not recognized by the system after you install the new memory. Determining where your memory is located Memory is installed inside of the memory module compartment, which is located on the bottom of the computer on most HP notebook PCs. Some HP notebooks are designed with the memory module compartment under the keyboard. If the memory module compartment for your particular notebook is located under the keyboard, HP recommends that you contact an HP-authorized support or repair facility for assistance in ordering and replacing the memory. Verifying how much memory can be added Prior to upgrading memory, you need to verify how much memory you currently have installed to determine how much memory can be added. Using your User Guide for memory installation instructions The User Guide contains helpful information and pictures showing how to remove and install memory in your specific notebook model. A copy of the User Guide is stored on the hard drive, and it is also available for download from the HP Web site. Installing memory Notebooks are designed so that additional memory can be added using a Phillips screwdriver. Use the following steps to install memory in an HP or Compaq notebook computer. After reviewing the following steps, if you are not confident in performing the installation yourself, contact an HP authorized distributor for technical assistance. NOTE: If someone other than HP installs or upgrades the memory, any damage caused by the memory and/or by a person trying to install or upgrade the memory is excluded from coverage under the product warranty. The customer assumes all risk and liability for damages for any such installation or upgrade. NOTE: Important! You might find that your HP or Compaq computer is able to support a physical installation of 4 GB or more memory. However, this maximum memory might be further limited by the operating system not being able to address the full range of physical memory. 32-bit operating systems, such as 32-bit types of Windows 7, Vista, and XP, can address approximately 3.3 GB. This limitation is present on all 32-bit hardware and 32-bit operating systems and is not limited to HP and Compaq PC systems or Microsoft software operating systems. Verify the computer is turned off, not simply in sleep or hibernate mode. Disconnect the A/C power adapter. Turn the notebook over and place it on a firm surface. Remove the battery. Use a Phillips screwdriver to remove the cover on the memory module compartment. (See the User Guide for instructions on how to remove the memory for the specific computer. If you need help finding the User Guide, refer to the section Locating your User Guide for memory installation instructions .) With the cover removed, and before you touch the memory, ground yourself to discharge any static electricity. NOTE: To ground yourself, and discharge any static electricity, place one hand on the case of the computer and touch the other hand to a metal surface or grounded object, such as the metal part of a lamp. To release the memory, use a small wooden tool, or fingernail, to spread the clips holding the ends of the memory in place. One side of the memory will rise when the clips are released. Remove the memory and place it in an anti-static bag. Remove the new memory from the protective anti-static bag and hold the memory by the ends. Place the gold contacts into the connector (bracket) and gently, but firmly, press the memory into place. The clips will click when the memory is properly seated. Replace the cover and tighten the restraining screw. Replace the battery and A/C power. Turn on the computer and allow it to reconfigure and recognize the additional memory and improve performance. Buying memory HP recommends purchasing memory directly from HP, an authorized HP dealer, or from a reputable computer parts supplier. You can buy computer memory from most local electronic stores and online shopping sites (such as www.crucial.com or HP , for example). Many of the online sites partner with HP to automatically suggest the correct type of memory based on the model of your computer. Before purchasing memory, make sure you know how much memory you need and what type of memory is compatible with your computer.
Aug 05, 2012 | HP Compaq Business Notebook NX9010
How to increase System Memory on HP Multi Media 8200 Vista O/S
Read the manual.
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and search them on upgrading the memory.
It's a simple process. You remove the power cord, remove the case then look inside and you will see the memory chips and memory slots.
You can check the site below to make sure you get the correct memory and it will tell you how many slots you have and how much memory the system will hold.
http://www.4allmemory.com
May 14, 2012 | HP Computers & Internet
Latest bios for HP Media Center PC?
sad how, how fixya AI guessing wrong??? pathetic, mess....
wow a very old media center, gen 2 of 14 or so.
HP does not support this quote
HP Media Center m1070n Desktop PC,its RETIRED now
https://support.hp.com/us-en/retired-products
The BIOS does not do that!
what HP, it has full name and model.
the MMC controls this, and is very strict. (mem-managment controller)
the memory you are buying is no good. for YOUR PC.
this is so very common
and worse every year,
ever heard of Crucial or Kingston memory
they can fit up memory for you, it very complex.
not just DMM1, 2,3, but speed, min.
density rules.
chip count rules
chip voltage, 1.3. 1.5 or both or?
Total memory max allowed and PER SOCKET !
and even number of chips per side of stick , rule.
that worst was intel i5 old processors.
those are facts, and only the exact motherboard you have a
and what processor is there, (and if mmc is external to processor that)
matter.
? this?
M1070n
finding data on such and old box.
is not easy but google can dig up bits.
why not ask Kingston? for help,.
key facts are, (besides old)
Intel Pentium 4 520 / 2.8 GHz
Intel 915P Express (my guess, mmc is inside here)
oops
  • 512 MB / 4 GB (max)
  • Memory Speed 400 MHz
  • Memory Specification Compliance
    PC3200
  • Features
    unbuffered
  • Configuration Features
    2 x 256 MB
  • Technology
    DDR SDRAM
  • Installed Size
    512 MB
  • Data Integrity Check
    non-ECC
  • 4 GB
  • Form Factor
    DIMM 184-pin
looks like 1GB max per slot , 1 to 4.
good luck finding SDRAM in 2017 that works.
why not find a newer box? (pc) say 2010 or newer.,
they will run better and can buy ram easy
vastly better.... even Goodwill has them for few bucks
or this.
or like this,
https://www.walmart.com/ip/Refurbished-HP-7800-Desktop-PC-with-Intel-Core-2-Duo-Processor-4GB-Memory-19-Monitor-250GB-Hard-Drive-and-Windows-10-Home/54997432
May 21, 2017 | HP Pavilion Media Center M1070n...
I put in a cd in the cd drive and it will not open the tray to take the cd out on my hp media center pc m1264n
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 15, 2011 | HP Media Center m1264n - 3.0Ghz 1024MB...
I need to put more memory chips in. where do I do it--the monitor or tower? how do I open the cover?
The memory goes in the tower on the motherboard. Most cases come apart by unscrewing screws on one side of the back. Some have a little lever on the back that, when pushed, releases the side of the case that is opposite the motherboard.
Some cases have a button (large or small) that is recessed into the top and maybe the bottom of the case. When pushed these buttons release the catch inside the case and you can swing it open.
Once open, you will see the memory slots. By pressing the catches on each end of the memory chip, you can release them and lift the chip out. Note the position of the key on the chip socket and the slot in the memory chip when reinstalling memory.
Jan 01, 2010 | Compaq FS7600 17" Flat Glass Monitor
I have a HP media center m7360n , with a 920 intel pentium D processor. I changed the video card which required a more powerful power supply. I upgraded the ram and changed the power supply out to be...
Open your computer casing where the motherboard lies in and then remove the memory card, your new video card and then reset the BIOS, refer to the motherboard manual on how to do it. After resetting, plug in the memory card and video card. Close the casing and connect all the wiring. Power up your computer.
Nov 03, 2009 | HP Pavilion Media Center TV m7360n...
I'm having difficulty reaching the memory chips. Plug-in drive, burner and writer in the way.
To reach the memory chips , remove the cables that come in the way. If that still doesn't help remove the drive, burner or whatever needs to remove to reach the memory chips. Make sure to make note of all the cables and parts positions before they are removed so that they can be reconnected as before.
Sep 17, 2009 | HP Media Center m1170n Photosmart PC...
Need instruction on how to install memory upgrade
First you have to determine whether this model can support 4Gb or memory.
All laptops use the same memory. SODIMM (Small Outline Dual Inline Memory Module) chips are readily available. It's actually quite easy to upgrade. First remove the small piece of the casing that covers the top part of the keyboard. This should just snap off. Then you should find some screws holding the top of the keyboard to the case. Once you remove these, the keyboard will easily pop out. Carefully disconnect the ribbon cable connector leading to the keyboard. Then you should have access to the RAM chips.
Therefore, the only tool you really need is a small phillips screwdriver. Be careful when handling the chips.
Sep 06, 2008 | Acer Aspire 4315 Notebook
Installing RAM
I was not able to find specific information for that computer but replacing memory on any desktop computer is usually pretty straight forward. You would unplug from power, remove the screws for the cover, and locate the slots that hold the memory chips and add the memory. It might be a case that all of your memory slots are full and you'll need to remove some of the memory first. You could replace them with larger capacity chips. HP lists generic memory information at http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03886&lc=en&cc=us&dlc=en&product=426931&lang=en Good luck
Sep 04, 2007 | Gateway FX4710-UB003A Core 2 Quad Q9300...
Computers & Internet Logo
111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
