Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door won't open or close
I've had it for around 10 years... I opened it 2 weeks ago..opened like usual... tried to close it and it would not respond light turns on like it has heard the command from the remote unit but nothing happens, It's not the door sensor, I checked that. It's not a jammed belt, I checked that too. I can't find a reset button so I unplugged it overnight and plugged it back in, that didn't work. Do I just need a new unit?
  • Barbara vonKNipper May 11, 2010
    does it hu? Is it a Liftmaster, Sears or Chamberlain product?
It may be stuck on the stop bolt... Is the carrier ( the part that moves the garage door) jammed?
Posted on Feb 28, 2009
2000 Chevy S10 passeger door won't open
Remove the door panel and inspect the latch rods for damage or broken retention clips. A video is below of how to remove the panel.
Nov 06, 2012 | 2000 Chevrolet S-10
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
My Keurig is stuck. The top of the handle won't go in :( it won't close. Stuck open.
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
Jan 21, 2012 | Keurig Elite B40 Coffee Maker
About 6 months ago someone tried to break into my driver side door. Ever since, you couldn't unlock the door from the outside with a key. The door would open and close just fine though. About a week ago,...
That sounds like what happened to my neighbor.They came to the conclusion that someone tried to jam a screwdriver in the lock to open the door.As far as not openeing anymore,that happened to me and I had to replace the mechanism inside the door.I bought a used one for $5 and did it myself.A regular mechanic should be able to fix it however,you may end up needing to have 2 separate keys for your car if they replace the lock.1 for the ignition and other locks,and 1 for the drivers side lock.Call around a few places for a few estimates.Tell them the same as what you posted,they should be able to give a close estimate over the phone.Also,please read my tip about car keys.It is good free info.Good luck! Greg
Aug 15, 2010 | 2008 Pontiac G6 Sedan
Keypad Chaimberlain 32B2171-1 does not work any more
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
2001 Town and Country Lock and Unlock is Going Haywire on its Own
Door Locks Go Crazy 1
Door Locks Go Crazy 2
Door Locks Go Crazy 3
Not to difficult to understand what's happening ,when you know how they work .Plus you need tool the proper tools to diagnose .
Mar 03, 2017 | 2005 Chrysler Town & Country
Programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Jul 12, 2008 | 2003 Mazda Mazda6
Refrigerator
use a hair dryer to heat the gasket up and gently pull all the bends and wrinkles outs. this takes a tremindous amount of patients even with us techs, so work slowly. once you have that done and the gasket shift to form the door seal put a light coat of vasaline all the way aroung the gasket then push the door shut making sure you gasket is touching the door seal all the way around it mat take going over it again with the hair dryer with the door closed to get it to form correctly, once formed don't open the door for a min. of 4 to 8hrs if it can be avoided and after that make sure you close the door and it seals for the next week to 2 weeks which is about the time it take for it to cure properly
Jun 13, 2008 | Refrigerators
Dvd region usege
Nope sorry there is not a way to change regions. On the door problem there seems to be a problem with the timing of the gears or mechanism that closes the door system. Good luck
Apr 08, 2007 | Zenith XBS344 System
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
117 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
