Question about Lexmark X9350 All-In-One InkJet Printer
My Lexmark 9350 won't print from a wireless notebook.
It shows as being connected to the network and it communicates wirelessly with my notebook as I was able to scan a document wirelessly. It just won't print when I select print document.
    Problem Solver:
  • 5 Answers
If you are using a Vista machine. First,make sure you don't have two conflicting firewalls active in your firewall menu. If you have a built in firewall in your dsl or cable modem I suggest not using windows firewall. If you don't have two firewalls active and you are only using Windows firewall, you may have to allow the spool portions of your lexmark program through Windows firewall manually.Check your windows firewall and make sure all parts of the lexmark application are allowed.Also make sure you have installed the latest lexmark drivers on your notebook via lexmark update. I suggest anytime you are installing drivers that you install them using your administrator account. I also recommend unblocking the installation exe before you install. To do this when you download the update, right click on it click on properties click on "unblock" at the bottom then click ok.Right click again on the installation exe and click on administrator. This gives you administrator rights to run and install all portions of the exe file.
Posted on Apr 15, 2009
S405 printer won't communicate with computer when trying to print
First, make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
If the firmware update doesn't help, try to uninstall the Lexmark driver and download an updated driver online at http://bit.ly/rtOKTx. Just choose the Operating System of your computer.
Also, if your printer is connected to your network, try to set a static IP to your printer to prevent it from getting a different IP.
Dec 12, 2012 | Lexmark Interpret S405 Wireless All-in-One...
After installing my lexmark 7675 my laptop cannot access the wireless network
Wireless communication issues could be due to wireless signal quality, signal interference, firewall, etc. Make sure your printer is positioned where it receives excellent wireless signal strength (avoid physical obstructions whenever possible) and away from appliances which emit wireless signals (e.g. microwave ovens, cordless telephones, baby monitors, and other wireless electronics) that may cause interference. Make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
You may also refer to these articles from the Lexmark website to identify and rectify this problem:
- Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
- How to identify a Wireless Communication Problem and Resolution Tips
I hope this helps.
Jan 28, 2012 | Lexmark X7675 AllInOne InkJet Printer
Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
Here are some guidelines to identify and fix your wireless communication issue:
  • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
  • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
  • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
My lexmark x6650 printer will not connect back online
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via USB cable to your computer, simply disconnect the printer from your computer, reboot your pc and unplug/re-plug the printer into the power source to reset it. When everything turns back on, reconnect the printer into the pc. Wait for the computer to fully recognize the USB connection. Try to print again.
If you're printer is wirelessly connected to your computer through your wireless network, please refer to this article for a more comprehensive instructions on how to identify and fix the communication problem - Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 06, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
My printer wireless indicator is flashing red and I cannot print
The flashing status of the WiFi light on the printer indicates that it's either trying to connect to a wireless network or it has gotten disconnected from your wireless network.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, check the WiFi light status. Try to print again.
You may also refer to this article: Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 05, 2011 | Lexmark Z2420 Printer
Wifi signal orange. showing as not connected to computer
This could be a slight communication problem. Try to reboot your computer. Unplug and replug the printer into the power outlet in the wall to reset it. Doing this usually fixes minor communication issues.
If there's still no communication, try to reset your printer's network settings - How to Reset the Z1400 and Z1500 Series Network Settings. Once done, re-launch the Lexmark Wireless Setup Utility on your computer to reconfigure the printer to your wireless network. If you're using Windows, go to Start menu > Programs > Lexmark Z1400 Series > Tools > Wireless Setup Utility. Follow the instructions on your computer screen.
Jun 08, 2011 | Lexmark Z1480 InkJet Printer
I think I accidently cleared my wireless wifi on my printer.... the wifi light is orange instead of green so not connecting
Try to print the network settings page to determine if your printer is still connected to your wireless network or not. On the printer operator panel, press the Setup button -> Network Setup -> Print Setup Page. Check the SSID if the printer is still registered to your wireless network. If not, you may need to reset your printer's wireless network adapter. Press Setup -> Network Setup -> Reset Network Adapter. The wifi light on your printer will then momentarily turn off. Once it turns on solid orange again, you may reconfigure your printer to connect to your wireless network.
If your printer is still registered to your wireless network, then it could be just a slight communication problem. Try to unplug and replug your printer into the power outlet to reset it. Doing this usually fixes minor communication issues.
May 03, 2011 | Lexmark X4690 Wireless InkJet Printer
I need to print from laptop to wireless lexmark 9350. how do i do it
Check the following steps:
1. Scan for the available wireless networks on laptop.
2. Check the network and select the desired wireless ssid which is for printer
3. If is it password protected than proviode the password.
4. Connect to the network.
5. Then print.
**If this works please rate else let me know in case of further help.**
Jul 05, 2010 | Lexmark X9350 All-In-One InkJet Printer
I am running Vista Home 32 bit and have a Lexmark X4850. It will not communicate with the printer from either wireless or USB. I got it to print a test page from both, but that was one time after a...
Have you talked with Lexmark Technical Support? I suspect you may have to escalate this beyond level one. Vista on Mac is likely to have issues that differ from other Vista environments.
Sep 24, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Network router printing issue
sure..you can put all the computers on the same workgroup, and form a network
we got fresh wireless drivers here too
Mar 17, 2008 | D-Link Wireless
Lexmark X9350 All-In-One InkJet Printer Logo
455 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
