Question about Sharp R-1610 Microwave Oven
My sharp microwave is under 6 months old. I was
My sharp microwave is under 6 months old. I was using it for quick heat ups of my pets food, and now it isn't heating up at all. It started making a louder noise than before and I think I smelled a weird burning smell. Could I have burned out the engine doing these short heatups?
  • Sharp Master
  • 9,098 Answers
It may be a shorted high voltage diode.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Posted on Mar 02, 2009
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 6 months...
Small component called a diode. Open up the microwave and try to find a black (usually) component that is most often connected between the magnetron (the thing that heats the food) and the chassis of the microwave oven (ground). I used to make a fortune replacing these! Costs about 5 bucks most appliance supply stores. Make darn sure you get one of the same value.
Apr 06, 2010 | Maytag MMC5000 Microwave Oven
Microwave taking much longer to heat food
The microwaves are produced by what is known as a KLYSTRON TUBE. Like anything, early failure is possible. There is also the possibility that the transformer or electronic circuit providing the correct voltage to the KLYSTRON has failed, either from over-use, manufacturing defect, or leakage from the KLYSTRON enclosure, which creates heat.
With microwaves being as CHEAP as they are, replacement should not be an issue.
Feb 03, 2010 | Microwave Ovens
At least twice in the past month have had food explode all over the microwave (as if it was overheating). Items vented properly or not covered at all. this time, kept making poppong noises for at lesat 10...
If you have an item overheating, try looking at the directions on the unit for the watts and adjust cooking time according to the oven. Some foods will explode if left for too long in a quick heating microwave oven. If this is a new problem and the microwave is 4 years old, you may consider the unit is beyond its useful life. Its difficult to tell w/o knowing the brand, but it could be the meagtron tube is simply wearing/worn out. Let me know if this helps. m
Oct 20, 2009 | Sharp R-428J 1200 Watts Microwave Oven
Sharp microwave losing cooking power
If the supply voltage is low it will take long time to heat foods. The second reason is the Magnetron. Since it is in the warranty period you can call at the sharp authorised service center. They will do it free of coast.
May 04, 2009 | Microwave Ovens
Outside caseing heating up while cooking`
Also, Please reply back with your brand and model number so we can help you.
Nov 20, 2008 | Sharp R-1480 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Dec 30, 2007 | Maytag MMV1153A Microwave Oven
Sharpd R-420LW
I always recommend that folks put food off-center on the turntable to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking.
The turntable generally replaces the stirrer, which actually scrambles and stirs the microwaves as they come out of the waveguide from the magnetron. But some models, notably GE's, have both.
So if you're placing the food properly and it's still burning, since it's under warranty, contact Sharp at 1-800-BE-SHARP (1-800-237-4277) to see about getting it checked.
Oct 21, 2007 | Sharp R-420DK Microwave Oven
Sharp selling bad microwaves
paddy paddy paddy i want i want, bet you were spoiled as a child, never continue to use a microwave that sparks, you can only do more damage to the appliance and maybe even worse is this sparking when you use it under normal conditions, place a plastic bowl with cold water in and see if it sparks then, if not then is it something you have done, i assume you know what you can not put in a microwave if sparking occurs anyway, and its only 6 months old, is it under guarantee, then its simple, send it back and ask for free replacement SHOUT AT THE RIGHT PEOPLE DON'T WASTE TIME ON HERE
Oct 04, 2007 | Sharp R-220BW Microwave Oven
Sharp R-1610 Microwave Oven Logo
244 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
