Question about Numatic Henry Bagged Canister Vacuum
Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
1. I have a Henry HVR 200 Vacuum cleaner (has two switches - on/off switch and a hi/lo switch).
2. Got the Henry about 2 years.
3. Yesterday when using it started to produce a smell - an electrical burning smell.
4. Other than the smell, there is no other symptoms - it sounds the same and has a decent ****.
5. Thinking it was the cardon-brushes, these were checked and are still in good condition (did not fully remove the brushes from the motor - but saw that each had at least 7 mm of carbon left on them).
6. Re-assembled the Henry and it still gives the electrical burning smell.
7. The smell is more noticeable when the hi/lo switch is on hi.
8. Is a new motor needed?
Best, Simon
  • 1 more comment
  • siprog64 Mar 01, 2009
    Hi & thanks for your reply.
    When I dismantaled Henry and checked the motor it appeared to be in good condition. The commutator did not look scared or worned - just black from where the brushes touch the commutator. I like your idea of changing the brushes as this should be easy to do - do you recommend any supplier?
    As regards to bag, most of the time is does not have a bag. But If I had my way it would have a bag.
    Regards Simon.
  • Anonymous Mar 31, 2014
    It has an on off switch and a high/low switch. I believe the smell started after I changed the vacuum to high. I also changed the brush to the hard floor setting..
  • Adam
    Adam May 07, 2014
    Hi i am also having problems with my Henry it started making noises from the motor then smoking and now every time I try to switch it on it trips the electric out. Could this be the carbon bushes need replacing or something more thanks Adam
    President:
  • 389 Answers
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Posted on Mar 01, 2009
  • Philip Gaut Mar 01, 2009
    Hello again,
    Thanks for your feedback, I'm glad you found my comments helpful. I'm amused to see how the site censor has dealt with the word "s u c k"!!!
    I repeat that going bagless is false economy. By which I mean that more dust than necessary will get through to the motor and cause avoidable wear.
    As for carbon brush suppliers, I think I'm not allowed to advertise but I notice that when I read our exchange on screen there are at least two Henry spares websites advertising in the box on the right side of the window. You don't say which country you're in, so these may or may not be helpful.
Mine did this. It turned out to be the switch. I bought a new one online for a few quid & fitted it myself. Reasonably simple to do. It's worth taking it apart & seeing if there's any melted areas on the switch.
Posted on Mar 30, 2009
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
Dec 26, 2015 | Dyson DC41 Animal Bagless Upright Vacuum...
HENRY VACUUM CLEANER HI LO SWITCH BROKEN CAN I DISABLE IT TO STAY IN HI MODE?
It can be disabled to stay in high mode, but you need to know what you are doing. It basically involves removing the small PCB and connecting the motor wires directly to the on/off switch. The hi/lo switch can be left in place (although not connected) or removed and a blanking plate put in it's place. You can leave a hole as this is a potential hazard and against government regulations.
Feb 28, 2015 | Numatic Henry Bagged Canister Vacuum
Burning smell vacuum cleaner
Maybe, the brushes and commutator are alreay worn off. Best bet is to replace the vacuum fan motor.
Sep 03, 2013 | Electrolux Vacuums
No suction on my HVR 200 -22 Henry Vacuum Cleaner
check filter and bag here is a video
Nov 11, 2012 | Vacuums
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
GoVacuum.com
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
My vacuum cleaner is giving off a burning smell.
if its a rubber burning smell check the belt and the brushroll. if its an electrical burning smell then dont use it. the motor is overheating and will eventually get hot enough to catch fire.
Jan 02, 2010 | Vacuums
Numatic Henry Micro HVR-200
motor is over heating. you need to clean bag, filter and hose first then re test
Aug 21, 2008 | Numatic Henry Bagged Canister Vacuum
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Numatic Henry Bagged Canister Vacuum Logo
5,310 people viewed this question
Top Numatic Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
