Question about Nokia N95 Cellular Phone
N95 LCD BACKLIGHT DOES NOT WORK
AS ABOVE
  • 1 more comment
  • wobat1 Apr 05, 2009
    backlight on LCD and Nav keys are not coming on. Back contact inside the phone ??
  • Anonymous Apr 28, 2009
    i have just received a new screen hoping that that would resolve the back light problem but it didn't. so i know its not the screen. what else could be causing the back light to not illuminate
  • jimhauzel May 23, 2009
    N95 Lcd blacklight and keyped light is no working. Plis Hlep me
Phone softwer
Posted on May 26, 2009
3 Suggested Answers
SOURCE: n95 lcd backlight
coil??...i dont understud...where is??
Thanks
Posted on Mar 14, 2008
devdeep dhar
  • 375 Answers
SOURCE: no backlight on my n95
LCD Back light not working:------ To fix this you need to change a coil in the Board of the phone. The Image of the cable location is below:----- dcd5d17.jpg Sir, I am honest and advising you to consult another expert for the back light problem in the Top Slider Keypad. Sir, please rate my solution for the first problem.
Thank you Sir, I wish the second problem will be solved. Have a nice day.
Posted on Sep 23, 2009
Height above sea level of my house in Southampton
3 metres
Geographic coordinates of Southampton, United Kingdom. Latitude ...
dateandtime.info/citycoordinates.php?id=2637487
Latitude of Southampton, longitude of Southampton, elevation above sea level of Southampton. ... Coordinates of Southampton in degrees and decimal minutes. Missing: my ‎house
Southampton - Wikipedia
https://en.wikipedia.org/wiki/Southampton Southampton is the largest city in the ceremonial county of Hampshire, England. It is 75 miles .... The city walls include God's House Tower, built in 1417, the first ..... [hide]Climate data for Southampton, elevation 3 metres (9.8 feet), 1981-2010 ... The centre of Southampton is located above a large hot water aquifer that ...
Frequently asked questions about Southampton in Queensland - Bonzle
www.bonzle.com > home > homesteads > Southampton
myBonzle menu: Add to my places Add picture Add story Add note. Skip to map ... What is the elevation/altitude/height above sea level of Southampton? Southampton is at an ... Old Parliament House, East Parliament House Picture relating to ...
An Oceanfront Home Built Above Sea Level ' Southampton, House ...
https://www.pinterest.com/pin/172122016986387096/
Southampton · House · House beautiful ... Balconies · An Oceanfront, Southampton Home Built 17 Feet Above Sea Level ...
Height above sea level of my house in Southampton Google Search
Oct 16, 2017 | Computers & Internet
Tip
Perform Nozzle Check Pattern of Canon Inkjet Printer without Computer
Models:
BJC3000 and above,S300 and above, i450 and above,Pixma ip2000 and above
Procedure:
  • Set A4 paper in paper tray.
  • In stand by condition,hold down Resume/Cancel button until LED indicator blinks twice then release the button.
Models:
Pixma ip1200,1300 ,1600,1700,1800,1900,2200
Procedure:
  • Power on the printer, immediately after printer standing by press Resume/Cancel button 5 times within 2 seconds.
The printer start printing nozzle check pattern after procedures above performed properly.
on Dec 02, 2008 | Canon S400 InkJet Printer
Question mark key and slash plus 2 keys above it have turned to eee with accent above
https://support.microsoft.com/en-ca/kb/258824 - I suggest you check out this article - or you can google yourself - How do I change my Keyboard Mapping? and then see what comes up.
I would appear that you have somehow setup something on those keys - e with an accent above is most likely French
May 28, 2016 | Logitech Computers & Internet
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
I just bought a 46 inch SAMSUNG LED HD TV from Best Buy and will be mounting it on a brick wall above the fireplace. The fireplace has gas logs with a an 8 inch mantle that extends 8 inches off the...
it is not safe to mount the TV 8 inches above the mantle.
Secondly, the heat will certainly be a danger if the TV is mounted above the mantle.
I would advice you look for another position to mount the TV.
I hope the above is clear.
Regards.
Sep 27, 2011 | Televison & Video
What is the fluid capacity for a 1986 monte carlo ss
Engine Coolant - Volume: 12.00QTS. ( 11.4L ) - [50/50 mixture of Ethylene Glycol Base Antifreeze and water] - 4.3L Eng - [GM Specification 1825-M.]
Engine Coolant - Volume: 16.30QTS. ( 15.4L ) - [50/50 mixture of Ethylene Glycol Base Antifreeze and water] - 5.0L Eng - [GM Specification 1825-M.]
Engine Oil - Volume: 4.00QTS. ( 3.8L ) - [SAE 5W-30 (Preferred) (Below -20Deg.F to Above 100Deg.F), 10W-30 (0Deg.F to Above 100Deg.F), 30 (40Deg.F to Above 100Deg.F)] - 4.3L Eng
Engine Oil - Volume: 4.00QTS. ( 3.8L ) - [SAE 5W-30 (Preferred) (Below -20Deg.F to Above 100Deg.F), 10W-30 (0Deg.F to Above 100Deg.F), 30 (40Deg.F to Above 100Deg.F)] - 5.0L Eng
Fuel Tank - Volume: 17.60GALS. ( 66.6L ) - 4.3L Eng
Fuel Tank - Volume: 18.10GALS. ( 68.5L ) - 5.0L Eng
Feb 07, 2011 | 1986 Chevrolet Monte Carlo
How to calculate above ground volume. 60' x 30' x 7' house with sloped side yard. house is 1' above ground in front and slopes to 7' above ground in the back. For sizing heating and air conditioning...
Total volume of home is 12,600.
total volume below grade is (6' x 60' x 30')/2 = 5400.
total - below grade volume = above grade volume
7200 cubic feet.
Feb 22, 2010 | Carrier Heating & Cooling
Media show 4 will not start. It says i dont have the right vga hardware or driver to run media show
Well..
I checked the system requirements for this software to run in youir PC.
Do you have any of the following requirement
VGA
  • Minimum Intel 945 GM and above
  • Minimum Nvidia Geforce 6600 and above
  • Minimum ATI X1600 and above
  • 64MB-VRAM and above
  • Some animation effects may be turned off or degraded for lower-end graphics system
Jan 22, 2010 | CyberLink MediaShow 4 for PC
Wifi
Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
Acer Aspire 1000 Series --Launch Keys above the keyboard
Acer Aspire 1640Z ---- Launch Keys above the keyboard
Acer Aspire 1690 ---- Launch Keys above the keyboard
Acer Aspire 2000 Series ---- Button on the front of the laptop
Acer Aspire 2012 ---- Launch Keys above the keyboard
Acer Ferrari 3000 ---- Button on the front of the laptop
Acer Ferrari 3020 ---- Button on the front of the laptop
Acer Ferrari 3400 ---- Button on the front of the laptop
Acer Ferrari 4000 ---- Button on the front of the laptop
Dec 30, 2008 | Acer Aspire 5003WLMi Notebook
Htc p3450 touch gprs and mms settings
you need to get the settings from your service provider (people who supply your sim) and enter the settings into the connection settings screen on the phone
May 23, 2008 | HTC Touch P3450 Smartphone
Nokia N95 Cellular Phone Logo
595 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
