Question about HP OmniBook XE3 Notebook
Laptop my screen is blinking or flashing all the time can you help me out i dont know what it could be
How to fix monitor?
Posted on Mar 28, 2009
I want driver cd  and os for my lop top Hp omnibook Xe3 note book please help me how to get it ?
Posted on Mar 02, 2009
Planar monitor works but doesnt.
Try Another Monitor---If OK--Problem Is With Your Monitor---If Does The Same Thing--Problem With Computer Video.
Mar 18, 2015 | Planar Computers & Internet
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Sep 28, 2009 | Compaq Computers & Internet
2004 Sony 52" Wega dont turn onnthe stand by light stays flashing. This TV first started by taking long to turn on and now and then would turn off until one day it just didnt turn on and the standby button...
When that model Sony shuts down the LED starts blinking as you say but it is telling you something because it blinks a certain number of times and then pauses and repeats the number of blinks. Count the number and then I might be able to help you narrow down where the trouble is.
Jun 14, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony wega rear projector
What color does it flash? Also it may be blinking a code so we need you to count the # of blinks it should blink a certain # of times, then pause, and blink that same # of times again. Let me know and I will be able to help you furthur.
Tim
Sep 11, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Dell D500 not starting
It's unfotunate that you don't have the info from the blue screen, this would help tremendously. The blinking light is actually a code, a certain light will blink a certain number of times for a specific code. Go to Dell's support site and find the light codes for your machine, this will help in narrowing down the problem area. I believe you're going to need the tools to remove the covers, so you might think to pick them up. A majority of the time this type of problem is either with the memory or the hard drive. Start with the codes list, and gofrom there. If you need any help, just ask.
Aug 12, 2008 | Dell Latitude D500 Notebook
Toshiba EA60 laptop wont go in boot sequance, its stop after toshiba logo and gives a black screen with blinking curser in top lef corner
Its probably not the BIOS but the board warping beneath the CPU Socket or similar.. Dont flash it (BIOS) or it will probably kill the chip. Let me look up the model number...
Feb 12, 2008 | Computers & Internet
HP OmniBook XE3 Notebook Logo
90 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
