Question about Intel Motherboard
Computer Wont Boot after Removing Display Chip
Hi all! Hope you can help me.
I am quite tech oriented, and usually figure the problems out myself. But this one is messing me up.
I have a desktop computer that was working, but I had to take the hard drive out to look @ its serial number. I put everything back the exact way it was, and now the screen wont boot up or nothing will display. Everything is on, all the cables firmly attached.
I even tried 3 different display adapter chips and it doesnt work still. I also tried it on a different motherboard, and still no change.
It happened before, but I did something to get it working, but I forget what I did.
Can anybody help me?
Greatly Appreciated!
  • 1 more comment
  • Nelson
    Nelson Feb 28, 2009
    Thank you both very much for a quick response and a detailed one at that.
    For Lolita, I have tried removing and re-inserting the memory module, but that has not fixed it.
    For Sublimation, I will try removing the battery for 24hrs and see if that makes a difference. If not, I will reply back for CMOS help (most likely).
    Thank you both!
  • Peter Steiert
    Peter Steiert May 11, 2010
    You're welcome, let us know how it turns out.
  • Peter Steiert
    That thing that you tried, was it a CMOS reset? To reset the CMOS you can either set a certain jumper on your motherboard to reset the CMOS or you can pull out the BIOS battery from your motherboard leaving it out about 24 hours to ensure the power runs out.
    President:
  • 2,976 Answers
Look on the chip for a small square or circle mark at one end only. This MUST match up with the mark on the board. This indicates the polarity of the chip. Hopefully, if it was in wrong, it didn;t blow the chip.
Posted on Mar 01, 2009
  • 385 Answers
Sometimes when this happens to me there are several things that I try. Remove the memory module and reseat it firmly and then try to boot again. Most of the time, this is the problem. If not, then try resetting the bios.
Thanks,
Lolita
Posted on Feb 28, 2009
How to rotate the screen on a gateway touch screen desktop
Hi. I am fairly certain you would need to go into the Windows Control Panel. Go to "Display, then "Adjust Screen Resolution." Where it says "Orientation," change "Portrait" to "Landscape." This is generally how you change the screen orientation in Windows for most PC's. I hope this has helped you. Thanks!
Oct 18, 2014 | Gateway Computers & Internet
Change drive orientation
what orientation are we talking about? CDROM and DVD Drives work sideways and horizontally, notice the plastic holders when you open your drive door, the cd/dvd won't drop to the floor...
No action is required on your part, everything will work as normal?
Any question? let me know.
Jan 18, 2013 | Dell Precision T3500 Computer Workstation...
Why is everything i look at inverted?
If everything is inverted, you may have the display orientation set for Landscape/Portrait (flipped). In this case, the taskbar will be at the top of the screen. With most Windows OS versions, click on the desktop (anywhere with no icons or running programs) and select Screen Resolution. In the drop down menu for Orientation, change the setting. (Landscape is usually the desired choice for computers with Widescreen displays.)
With some laptops, you may find this under Display Properties or Graphics Options. (On my desktop, changing the Graphics Option is available but doesn't work.)
I hope this helps.
Sep 15, 2012 | Computers & Internet
Hi have a acer 5735 and my screen is rotated and flipped upside down please help to resolve
Welcome to FixYa
Here is the simple solution to your problem
press CTRL+ALT+ directional arrow up
this is the shortcut key for screen orientation
Hope this helps
Jun 14, 2011 | Computers & Internet
Sony vaio Desktop Windows XP. Turns on but never actually starts up goes to screen where you can start safe mode, and other choices. None of those work. Took to Best Buy. Tech says Windows corrupted need...
Hi the best thing to do...is press and hold delete when the laptop is starting up,and go into the bios,and make sure that the 1st boot device is you cdrom,after you have enabled that to be your 1st boot device then press f10 and enter..then your laptop will reboot...
open up your cdrom,insert your operating system,then press the laptop power button to shut it down then power it back up...then hopefully it will prompt you to make a fresh install..
Hope this help and if there is anything else i could help you with..
Regards
Apr 02, 2011 | Sony Computers & Internet
Does anyone have a diagram for the timing marks for a 2002 nissan altima engine 2.5
Hi I have attatched a figure showing proper timing chain and gear orientation. Hope you find this information helpful its not to difficult to set up so you should have no problems.7710f70.gif
let me know how you get on or if you need further asssitance ok
Aug 02, 2010 | Nissan Altima Cars & Trucks
I am not a computer professional, I am just trying to figure out what the heck has happened to my computer. I have a HP Pavilion Slimline s3420f PC and it is running Vista on it. I have always just put my...
Sleep is more commonly known as Hibernation with Vista.
Sometimes certain updates or freshly installed service packs can mess with your settings, or sometimes disable the feature altogether.
Microsoft have released a fix for just this problem.
Go here to Microsoft (link below) read down the page until you see Fix this problem, click on that and then click on Run when prompted.
You should get a message saying that the problem is fixed.
Restart your computer and set your Hibernation settings.
http://support.microsoft.com/kb/929658
Hope this helps and good luck
Nov 13, 2009 | HP Pavilion S3420F Slimline Desktop PC
Unable to see my recyclebin
Refer to this tech article. See the section... Let me fix it myself and the Workaround section.
http://support.microsoft.com/kb/810869#letmefixit
Jul 26, 2009 | Western Digital 500GB My Book World...
Won't Print Microsoft Visual C Error
I would suggest contacting the person who installed the wireless. If you paid for the service they must repair the problem. A Technician should not leave your computer in a mess like this one did. If you don't get any satisfaction from them, call the Better Business Bureau and see what can be done to rectify this problem. If you try to fix their mess you won't have a case. I hope this helps.
Caro.
Apr 13, 2009 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
