Question about Building Materials
Craftsman Garage Opener Clicks only and LED blinking 5 times
My 1/2 HP Model 139.53641SRT opener clicks to all my remotes open button (I have no wall mount) but the motor does not move. The LED next to the green "Learn" button blinks 5 times and pauses for 2 seconds continuously after I hit the open/close button on my 3 button remote model 139.53779 (LED does not blink right after I re-plug in AC power). http://ths.gardenweb.com/forums/load/garages/msg012015459574.html indicates a 5 blinks is a diagnostic for ""RPM sensor or motor overload".
I verified obstruction sensor works and aligned. I also opened the opener housing and verified the motor gear to be fine. Is there anyway to checkout the motor and the RPM sensor?
(Right before the opener stops working, I open the garage door and accidentally hit a button on the 3 button remote that I normally don't use to close it about 5 minutes later and the opener started to act that way. I tried holding the same button for 2 seconds just in case that is the "locked" button for vacation and the opener still behaves the same. I wanted to make sure that I did not accidentally lock up the opener by hitting a wrong button on my remote and end up replacing the opener if someone out there can tell me how to unlock it. I have no owner manual because the opener and remotes came with the house.)
Thanks for your help.
I also replaced the gear drive on my 41A-5021-E 1/2 HP LiftMaster Garage Door Opener.
After following instructions carefully, the door moves about 3 inches and reverses same. The chain not yet installed so not related to any door problems (binding, etc.).
I have also centered the position (up and down travel limit) switch so not related to where it is at.
Makes no difference using wall switch or remotes.
Both sensors 'see' each other and are glowing brightly. I put something in their way and the lights blink properly, so appears not to be sensor related.
If I unplug the unit and let it set for a few minutes and plug it back in, the green led next to the 'learn' button is off, but upon attempting to open the door with either wall switch or remote, the led blinks 5 times, waits 2-3 seconds and repeats. Unplug and replug and same thing happens.
Is the '5 Blink Led' a 'trouble' code?
HELP!
  • krimes Apr 06, 2009
    I replaced a gear inside my 1/2 hp garage door opener. When I went to plug it back in there was a pop inside the unit and now all I get is a LED flashing 5 times and a few clicks inside the unit when the button is pushed. Did you ever come up with a solution to this?
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Posted on Apr 12, 2010
  • 16 more comments
  • fruitcake120 Dec 12, 2010
    Opener clicks nothing happened, 5 flashes code. Found the solder joint on the board bad, resoldered works great !!!!!!!! Thanks Billjacko
  • jhunter888 Feb 14, 2011
    Thanks for this post ... my issue problem was exactly as you described.
    I had a failed solder joint behind the relay. Works fine now after I soldered the joint back. (Joint behind the relay.
    Thanks so much.
  • marzgtp Mar 08, 2011
    Do you have to take the unit down to fix this?
  • alang399 Sep 02, 2011
    Same problem, door went up fine, but won't go down, only hear a click in it when I hit the button. I can jumper the motor wires and verified the motor still runs. I get five flashes from the green led. I also found a bad solder on the board for a relay, fixed the solder and works again.
    THANK YOU
  • mike davies Jan 30, 2012
    Thanks for the info Mine too !! Blinking 5 times Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. THANKS for the Info would have never looked for that tiny weak solder joint !!
  • app_3rp12323
    app_3rp12323 Mar 12, 2012
    wow, seems to be a common theme! I am a divorced woman who never had to deal with this sort of problem and I had the same exact problem these descriptions and directions were specific enough that with a little soldering help from a friend, I am back in business! THANK YOU!!
  • dbodden1019
    dbodden1019 May 03, 2012
    Took me a while to find this post but I'm glad I did. Saved me the cost of a new opener. I would have never found that on my own but once I read this it was a breeze. Thanks a million.
  • dbodden1019
    Thanks a million. Would have never found this on my own but with this post I was able to save the cost of a new opener.
  • Alan Polansky
    Alan Polansky May 04, 2012
    My Craftsman 1/2 HP also had the same problem, and the same solution. Thanks! One of the smaller relays joints needed to be soldered in the back. Looking at it closely, there was a lack of solder and the relay didn't appear to be making contact. I didn't pull out the whole board because of all the internal wire connections, I just partially pulled out the logic board and did the soldering. Works fine now. How can so many have the exact same issue?
  • BBS Boy Jul 16, 2012
    Same problem with my 1998 Craftsman Opener. I would never have looked at the solder joint had I not read this SUPER USEFUL post. I took my board out and look a few times to finally find the melted away solder joint. Put some new new soldier on, reconnect everything and saved myself a couple hundred bucks for a new opener! Thanks a lot!
  • Donna Sep 20, 2012
    Holy cow! Thanks for this posting! We started having this same problem with a LiftMaster 1280R. It was intermittent (probably as the solder was disintegrating) but eventually failed. Pulled the board out and inspected the solders - yup! One failed solder! Repaired and reseated the board - good as new! (Just a note - our lights failed as well due to the bad solder job, in case anyone sees the above symptoms + no lights, although they hear the 'click' as the signal registers at the unit.)
  • Homer S Dec 15, 2012
    Same symptoms on mine. Same solution - bad solder joint repaired. Thanks a bunch!
  • mw13068 May 04, 2013
    billjacko, thanks so much for posting the information! My garage door opener has been on the fritz for months, and 30 minutes after finding your comment, it is FIXED. A cold solder joint under the big white relay on the logic board was the problem.
  • Elrod Jetson
    Elrod Jetson Apr 10, 2014
    My logic board had a weak soder joint as well. The large white relay appears to be passing AC current perhaps to the capicitor to operate the motor? Not sure without a schamatic. Anyhow, I guess after many years of pasing high current the solder became unstable and sure enough, resodering that one tiny connection fixed my issue. Thanks again!
  • Angus Thomas Sep 15, 2014
    My opener was blinking a five and would click intermittently, thanks to this advice I looked at the board, sure enough a joint had failed, redid it and operating like new.
  • Bob Flesher Jan 04, 2015
    Sad - same symptoms but I couldn't find a bad solder joint. off to buy a new one, I guess.
  • Matt Cox
    Matt Cox Mar 22, 2015
    Couldn't believe it was that easy, soder joint on board, right behind white relay. Looked barely disconnected, but dropped a bit of soder, put it back together and worked great. Thanks so much for this post!
  • Anonymous Dec 19, 2015
    Totally agree with the above comment! Thank you!
  • 118 Answers
Five flashes indicate motor overheated or RPM sensor Failure. Replace the RPM sensor. If you turned the lock on the green light inside the wall button will be flashing. The wall button still works when the lock is turned on. The lock only turns off remote access. I doubt that the lock is an issue. Here is a link to a liftmaster owners manual http://www.liftmaster.com/consumerweb/pdfdocs/114A3181.pdf
Posted on Mar 01, 2009
    New Friend:
My door would not close and there was just a clicking sound when using the remote or the door button. I unplugged the unit, checked everything everyone posted as solutions. Had 5 blinking green lights from the unit. I replaced the cog in the unit 3 years ago and probably put on too much grease. What worked this time was using a tooth brush and cleared some excess grease off the circuit board. Unplugged and plugged again and it worked. Hope this helps.
Posted on Apr 25, 2013
    New Friend:
Same issue, however I found the end bracket for the screw track to be loose; over torquing the motor. Remounted it, reset the fault by unplugging the unit. and all OK
Posted on Feb 27, 2013
Moved to a place with a 139.53975SRT1 Garage Door and Keyless Entry. Keyless entry stopped working and I cant get code to operate door. All remotes stopped working. Reset codes with Learn button,...
Try this method for programming. Press and hold the button down on the remote while you press and immediately release the learn button. Do this for each remote.
Have you replaced the battery in the keypad? Try this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Post back with your results.
Jan 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Champion garage door opener opens by itself and the light does not come on
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door is opening randomly
Mar 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you clear and re-enter a new code for wall mounted remote
To change the code you need to locate the smart/learn button which is near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you like and press enter.
See if this works for your car.
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxillary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Feb 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
HAVE SEARS/CHAMBERLAIN "91"MODEL 53615SR AND NEIGHBORS OPENER KEEPS OPENING OUR GARAGE DOOR BUT OUR OPENERS WONT OPEN HIS
Dec 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
My neighbor opens my garage while opening his ,how do i correct the problem
Here are some tips that may help.
Nov 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
first off, hitting extra button on remote would not do anything. Is door up or down/ where is trolley that attaches to chain, by door or motor. Is is jamned against a bolt. Try a paper clip and jump from white to read terminal. Does it work. Does light bulb blink 10 times. I ignore the diagnostic lights and go by symptons. Give more info.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Neither remote control will open door but wall mounted button wil
Make sure the code set inside the remote is the same as in the main reciving unit code.
Dec 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
15,401 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
