Question about Philips 42PF7220A 42 in. Plasma Television
Our 52 inch Phillips Plasma tv is not working
Awhile ago our 52inch phillips plasma tv stopped working. I turned it on one morning and the screen flashed red. We could her sound and change channels but still had the flashing red. We called Phillips and they were not much help since our warranty was up. We talked to a Tv repairman but he didn't work on Phillips tvs. But he did tell us that he thought it could be two different things, one would cost maybe 20 bucks plus labor or 800 bucks plus labor. My question is, is it worth it to fix these tv's? Is it possibly something we could do on our own? Is it something as simple as a fuse?
  • kt2040 Mar 03, 2009
    We actually have taken off the back and it looks like a computer it sooo complicated. We did find fuses and actually found four. I am not sure what ones we should change or if we should try changing all of them? Also there was a flashing green light in the inside of the tv when we turned on the power with the back off. It was blinking the same time the screen was. Any ideas what that could mean?
  • kt2040 Mar 04, 2009
    We will try that and I will let you know if it starts working. Thank you so much for your help, we weren't sure where to begin and now we have an idea!
  • 90 Answers
Open the back of the set and inspect the power supply board -- there should be two fuses on the board- they cost around 2 dollars at radio shack -- check all connections for wear or damage -- there are two boards in most televisions -- a power supply board and a audio / digital board -- one is probably board
Posted on Mar 03, 2009
  • mike4671 Mar 03, 2009
    change all the fuses first ---- they are slow burn fuses and radio shack carries them --- try this and then if this doesnt work -- the next steps is changing the board - replace the fuses with the same ratings -- make sure to replace the same fuses in the same bracket
I have a Phillips 42 inch Plasma. I tried
One of two issues/problems:
1) Main Power supply problem
2) High Voltage Power supply problem.
A Good TV Service Shop that works on Philips would be the first place I'd call. It will be much cheaper to bring the TV into the shop instead of having a tech come out to your location.
Possibly a $200 to 300 dollar repair.
Blessings,
A/V Media Guy
Nov 23, 2009 | Televison & Video
My phillips 42 inch plasma tv just clicks when I
There is no lamp in a Plasma TV screen and no ballast.
Check the power supply capacitors.
Aug 19, 2017 | Philips 42PFP5332D 42 in. Plasma...
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Jul 04, 2008 | Televison & Video
Phillips plasma 50pf7320
I have a 50 inch phillips plasma and the pixtals are taking over and color is dark the amblight is very dim,
Jun 25, 2008 | Televison & Video
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
776 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
