Question about Bissell 6591 Power Trak Revolution Bagless Upright Vacuum
Motor seems like it is overworking. The sound of the vacuum is higher pitched than before.
    President:
  • 389 Answers
Hi!  Almost certainly your vacuum has a blockage somewhere. The higher pitch means the motor is running faster than normal, but it's not overworking, it's actually working less because it's moving less air.  Check for blockages and clear whatever you find (your user manual should tell you where and how to look), and that should be that! Alternatively, it may be that the drive belt to the brush roller has broken. Check that too. I hope this helps.  If not, please write again and I'll try again.
Posted on Mar 01, 2009
Lack of suction
You don't say what type of vacuum but it still sounds like a blockage or a split in a pipe... have another thorough look..
Is exhaust air blowing out of the machine... Is the motor running at a higher pitch than normal...?
Apr 16, 2017 | Vacuums
No suction at floor section only on hand held part
clean the hoses and any part connecting the actual vacuume to the floor attachment.... probably clogged or not getting a good seal....if the motor sounds like its going faster (higher pitch) then its clogged up.....
Nov 09, 2013 | Russell Hobbs 14835 Tornado Stretch...
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The motor in the power head ran at a higher pitch for a for 8 to 10 seconds then stopped. If I push the reset button the powerhead may or may not start or it may start and run for a few seconds. The brush...
Did you check the belt? A broken belt results in lower strain on the motor, causing it to run faster resulting in the faster speed and higher pitch. This could result in overheating, which will cause the motor to shut off.
If this isn't the problem you'll need to take it to the nearest Aerus Electrolux store for trouble-shooting and repair.
http://www.aerushome.com/storelocator/
Dec 29, 2010 | Electrolux C101 Bagged Canister Vacuum
My versatility electrolux vacuum is 2 years old and it has lost its suction, i have replaced the filters and checked every hosing area i have access to, it seems to all be clear. I dont know what else to...
It sounds like the fan blades have worn away until there's basically no air resistance, thus no air flow/suction. The whine is created by the motor turning at a higher speed due to lack of resistance.
The fan wasn't covered by the warranty, anyway.
It's time to either replace the motor/fan assembly or buy another vacuum.
Sep 20, 2010 | Electrolux Vacuums
My dirt devil is not sucking,i cleaned out hoses and bottom seems to be turning fine?
The fan motor is probably not working. Does it sound normal? Higher or lower pitch sound?
Dec 05, 2009 | Dirt Devil Vacuums
There seems to been a high pitched sound in the motor. I'd describe it as a 'dry' sound, and the high pitch of it is very loud. I want to stop vacuuming because it's so loud. Are there any oil/greasing...
High pitched noise is not good. It may indicate that a bearing is going out. I would not use Kirby as it may lead to burned motor.
If you feel that it vibrates quite a bit too - then it may be only broken fan blade.
Fan blade - you are looking ar around $40-$50 and if this is a motor bearing - $60-$80. If anyone wants to charge you more - we will repair it but you will have to pay shipping both ways (roughly another $30 both ways all together)
Ohhh yeah - try it with the hose. If no sound then brush roll bearings may be bad...
Good Luck,
Rocky
If you want to send it for service - go to GoodVac.com click on SERVICE, print form, fill out and ship it here.
Apr 04, 2009 | Kirby Generation 3 Bagged Upright Vacuum
High pitched sound when vacuum is on
You may be loosing your bushings on the motor,if this is an expensive machine it may be cheaper to have it fixed,if not it will burn up eventually.Also try taking the beater bar out and make sure you don't have something rapped around it causing a noise.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 19, 2009 | Dyson DC14 All floors Bagless Upright...
Bissell 6591 Power Trak Revolution Bagless Upright Vacuum Logo
218 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
