Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Bad resolution Westinghouse 22" LCD
This afternoon when I "woke up" my monitor discovered that the resolution was terrible and the coloring was dull. I has never done this before and I even plugged it into the neighbors computer to find the problem still was present. Please help.
  • dmo5036 Mar 26, 2009
    My computer screen when turned on is very dull and cloudy, the graphics are no longer as bright as they should be, with white lines coming diagonally down it. Aso the screen twitches sometimes during startup
    President:
  • 1,996 Answers
You might have to apply one or more of the following troubleshooting steps to solve this problem:
Fuzzy Image
• Set desktop resolution on your PC to 1680 x 1050 at 60 Hz.
• Adjust Phase/Sharpness setting on the monitor
Cannot find 1680 x 1050 under screen resolution on my Display Properties
• You may need to download and install the latest video card driver for your PC.
Listed below are websites for major video card manufacturers:
Nvidia: http://www.nvidia.com/content/drivers/drivers.asp
Intel: http://downloadfinder.intel.com/scripts-df/support_intel.asp
ATI: https://support.ati.com/ics/support/default.asp?deptID=894
If you need any further clarification, you can view a user's guide online at: http://www.westinghousedigital.com/pdf/60_User_Manual.pdf
If I've managed to solve your problem or answer a question, please take a moment to rate this post,..thanks!
Posted on Mar 28, 2009
I have a 22" Westinghouse
Change the settings on your HDMI output to 720 progressive for resolution. The tv likely cannot handle the 1080 resolution, or the tv can only use interlaced (1080i or 720i) format.
Aug 21, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
My Westinghouse LCM 22w3 was working great with full res at 19xx x 16xx. Now it is no longer recognized by my Windows Vista system. In Device manager, the monitor shows as a General PnP 17" with res...
I suggest you test your computer by using a different known good monitor. If it works ok you will know your Westinghouse has a fault and if it doesn't you will know there is a problem with your computer (video card maybe?)..
Sep 29, 2017 | Westinghouse Electric LCM-22W3 22 inch LCD...
I get a "no input signal" error message on the
Check the cable, to make sure that it's plugged into the monitor and the computer.
After that restart the computer - some computers only detect monitors right when it turns on.
Dec 22, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Westinghouse 22 lcd monitor. I have a 1 inch black stripe vertically down the left side. The monitor adjustments and resolution settings do not correct the problem, Sort of like an old crt gun being out of...
This is an issue with the Inverter or wire that sends the signal from the inverter to the screen. This is typically a non-service issues and results in a new monitor. May recommend you contact westing house and see if the screen is under warranty.
Oct 19, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Westinghouse 22 lcd monitor. faint click and went
More likely the filter caps failed and may have taken out the inverter fuse and the MOSFET in the inverter circuits also. yoo need to open it up and inspect the inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 09, 2010 | Westinghouse L2046NV Monitor
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
After any game, and go back to XP, my monitor go like 8 bit color,have to power down and up
Try useing a different resolution. The native resolution should probable be 1280 x 1024. Try updateing the video drivers.
Nov 23, 2007 | Acer AL1916W 19" LCD Monitor
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
537 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
