Question about GE 24 in. PDW7880JSS Built-in Dishwasher
Keypad and status issues on ge profile 9880 dishwasher
No status lights work
cannot change modes such as select type of wash
only delay start and start/reset seem to have functions
tried circuit breaker reset 3-4 times
could not locate tech sheet under kickplate? (somewhere else?)
anyone know how to enter diagnostic mode?
seems to be stuck on 101 minute cycle option only?
this may be a result of a power failure a few days back???
tried the child lock/unlock etc. (heated dry for 3 seconds...)
please help
  • Laurainla Mar 07, 2009
    I have same dishwasher and the same problem. I just had the Module Control Assembly replaced by a GE service person, and things worked for about 1 week. Also, I don't know how this happened, but when the repair person took the door apart it was full of roaches. I have been spraying my house regularly and have never seen the type of roaches that were in the door. It was really gross. Not sure if this was the problem or not. We sprayed everything with RAID and my bug guy sprays all around the dishwasher thoroughly so they don't get into the kitchen. I guess that's South Louisiana for you. I am about to order a new Module Control Assembly, but maybe it is my keypad. Any help for me would be appreciated too? I've already spent $175 on this issue!
5 Suggested Answers
SOURCE: start button on the HMI won't work
There is a ribbon cable that connects to the control panel. Mine was operating the same as yours. I opened up the front and reinserted the cable and its been fine ever since. you need to take all the screws out from the door panel inside the washer to geet to it.
Posted on Nov 17, 2007
rickzilla
  • 706 Answers
SOURCE: power outtage blues
Hello daniedag,
Unfortunately, your dishwasher may have experienced a power surge when the power went off and dmaged some internal components or the control logic. There is no way of knowing the extent of your problem without a thorough diagnostics to it. It could be something as simple as a circuit borad component, stuck relay but this kind of repair is probably not something you would want to tackle yourself unless properly trained and with the proper test equipment. If you have homeowners insurance, it may cover the damage.. If not, then a service call is most likely required. Here is a link to the GE website for yopur dishwasher but your model is not PWD9200 and IS PDW9200 http://genet.geappliances.com/DocSearch/Dispatcher
Hope this helps..
Regards,
Rick
Posted on Dec 13, 2008
SOURCE: GE Dishwasher GLD4200L00BB not running
Did you ever get a solution to your problem. I have had the same model for 5 years and today it did exactly what you described. Please help.
Posted on Oct 27, 2010
SOURCE: GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Posted on Jan 30, 2011
Daniel S
  • 4323 Answers
SOURCE: I have a ge profile performance dishwasher and it
Hi
There are two ways to reset it: first to reset press and hold the RINSE ONLY/HEATED DRY button for 30 seconds. Second way to reset is by pressing these buttons in sequence...high temp wash then heated dry...high temp wash then heated dry...follow this for around 4 times and then wait for 2 minutes to reset the unit. If the issue returns then it is either the heating element or the control board that is bad and should be replaced. Please Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 05, 2011
What does a 5h code indicate
The GE dishwasher error codes I have seen start with a letter (usually "C") not a number. I suspect that this isn't an error, but an indication that you have activated the system to delay starting the dishwasher. I believe 5h represents a 5 hour delay. Pressing the "Delay" button should cycle through the different selections and eventually bring it back to Zero.
Feb 07, 2015 | GE Dishwashers
GE profile PDW9280J00SS dishwasher. It will not start. The keys on the keypad light up except the start buttom. I push start and nothing happens. all the other button are lit and i think work. Do I need to...
Possibly, but first, check the door switches and their cover to make sure they are OK. You will have to seperate the inner and outer halves of the door to get to them, located where the tub latch protrudes into the door.
Feb 05, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
I am gettting a message on my dishwasher that says 1h
I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
Error code
you have set it to start after a one hour delay- just press the start delay button until it cycles through past 24h and you will get back to the immediate start mode...
Oct 12, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
Start button on the HMI won't work
Nov 01, 2007 | GE 24 in. Profile PDW9800J Built-in...
GE 24 in. PDW7880JSS Built-in Dishwasher Logo
306 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
