Question about AO Smith Three Phase Swimming Pool Pump Motor Ao Smith
Starting three phase pump
How best to start a three phase pump from a timer
    Scholar:
  • 90 Answers
First you need to have 3 phase power. Almost no households have 3 phase power availble. You would need to get a three phase converter which would cost as much as a new pump. If you have three phase power you will need a 3 pole relay that is triggered from a timer and rated for the current of the motor.
Posted on Feb 28, 2009
What direction should a Hobart H600 mixer rotate?
Check Rotation (Three-Phase Machines Only)
Three-phase machines must be connected so the planetary rotates in the direction of the arrow on the
Drip Cup. To check rotation:
Set the gear shift lever on 1.
Apply power to the mixer, set the Electro-Mechanical Timer on HOLD; or, if equipped with a
Programmable Timer Controller, set it on [ -- : -- ]. With the Bowl Support all the way up,
momentarily run the machine by pushing the START and then STOP buttons.
If rotation is incorrect, DISCONNECT ELECTRICAL POWER SUPPLY and interchange any two
of the incoming power supply leads.
Oct 12, 2017 | Hobart Food Mixers
What would be a good replacement for a FLYGT 3152 3 phase grinder pump that uses guide rails?
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Jul 04, 2017 | Grinders
    Hi!3-phase motor wires brn/blue/blk no open cct.P.c.b there are no components burnt out or blown.I removed interlock switch and will buy new one and try again.Belt ok.Pump solenoid valve ok .
    Check for a motor start capacitor that is defective. This can happen without external symptoms. Highly unlikely Hotpoint washer has 3-phase motor. Most household loads are single-phase. In North American residences, three-phase power might feed a multiple-unit apartment block, but the household loads are connected only as single phase. In lower-density areas, only a single phase might be used for distribution. Some large European appliances may be powered by three-phase power, such as electric stoves and clothes dryers. Three wires could be for different speed ranges or one could be frame ground.
    Apr 08, 2015 | Hotpoint Washing Machines
    Gould water pump
    I service all sorts of Goulds water pumps for a living but will need some more info to troubleshoot your problem. For starters would need to know what voltage feeds it, single or three phase, horsepower, type of controller (pressure switch, Variable Frequency Drive, Three phase across the line start etc.), what you are doing with it, pump model number, motor frame number, etc. etc.
    May 12, 2013 | Cars & Trucks
    I need a wiring diagram for a three phase paragon timer model number 8145-20.
    Paragon 8145-20 is a 240VAC (2 phase) timer. I doubt you will be able to find a 3 phase type timer.
    I would suggest you use this timer as a control and purchase either contactors or relays rated to handle the 3 phase load.
    Dec 21, 2010 | Paragon 8145-20 Defrost Timer
    I need a three phase wiring diagram for 8145-20 model timer.
    8145-20 240Volt Paragon timer is not 3-phase.
    Clock motor is 240V.
    You need a transformer to convert 3-phase to single phase 240V to operate timer.
    Then timer outputs can control 3-phase power using 3-phase contactors
    Contactor below is 3 phase with 240V coil
    http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
    Defrost timer wiring diagrams show below:
    http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
    I have a 3 phase electrical motor for my air compressor, How would i connect this from the air compressor pressure switch and towards the electrical source 120V? (for low volt)
    If the electrical 120 volt source is single phase, the only way to run this motor is with a single phase to three phase converter. Best to sell the three phase motor and obtain a similar horsepower 120 volt single-phase capacitor-start motor (1750 RPM) for the compressor. You would also require a 3-phase pressure switch for use with the 3-phase motor. Hope this helps!
    Nov 05, 2010 | Garden
    Some submersible pumps have a gray motor box to start the pump & some submersible pumps have the new style motor box built in and is not lighting proof. some 240vac are two wire and three! I would like...
    The difference in the two pumps is that with a three wire pump the start and run capacitors are in the gray box. With a two wire pump the caps. are built into the motor. Because of this with a two wire pump you only need to run the 240v down the well to the pump. The yellow wire on the three wire pumps is the igh voltage wire that come from the start cap. I have used both pums but usually use the two wire because they are easier to hookup and the wire is cheaper because you only need to run three wires. (2 hots and ground) On large HP pumps you will always have three wire motors because the caps. get too big to get them in the motor. It is best to go three phase with big pump if you can.
    Nov 14, 2009 | Plumbing
    AO Smith Three Phase Swimming Pool Pump Motor Ao Smith Logo
    136 people viewed this question
    Top AO Smith Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
    Are you an AO Smith Garden Expert? Answer questions, earn points and help others
