Question about X2Gen MV20T TV
Freeview is not working
My internal freeview was working earlier today, i turned it on an hour ago and it said no signal, i done a complete new installation and it picks up no channels, i cannot watch my freeview now and its annoying
  • Anonymous Mar 07, 2009
    i dont know how to fix it either
  • Anonymous May 18, 2009
    me too
    President:
  • 1,653 Answers
Please see the following pages
http://www.freeview.co.uk/_retuneinfo/
http://www.freeview.co.uk/_retuneinfo/_format/downloads/ChannelGuide30September.pdf
The retuning had to be started after mid day today 30th.
Posted on Sep 30, 2009
I ask a question earlier today, said it posted about an hour ago. I can't find it. I need help with the 2008 GMC Envoy. We put a airflow pump on it, didn't solve the problem. We put a new
Disconnect the exhaust before the catalytic convertor and test drive 2004 to 2008 and above GMC catalytic tend to plug easy, If the catalytic is to difficult to disconnect, plus you need to secure from falling remove the 02 sensor on each bank before the catalytic,this may be a easy approach.Just to let you what effects the performace of the MAP sensor is a plug exhaust,it creates back pressure.And a IAT sensor goes 10% higher, Another problem the Envoy has is water intrusion into the spark plug recessed area creating misfire and rough idle, the water get past the COP (coil on plug),
Nov 13, 2012 | 2008 GMC Envoy
Sound not working, Was working earlier today and after shutting off the tv, when we turned it back on, sound wasen't working
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 03, 2012 | Vizio 42 in. LCD TV
I cant tune in the freeview channels on my brand new lg lcd tv
Have you completed the entire auto programming?This can take up to 30 minutes and if you don't complete it you won' get any digital channels.If you have done this then you need a new main signal board.Call lg and they will refer you to the nearest service center.
Nov 10, 2009 | LG 37LH30 37 in. LCD HDTV
The humax keeps on messaging that the antane cable is short circuited. is this an internal problem or a problem with the aerial itsefl
The Humax PVR-150T will definitely have problems using an indoor set top aerial; this is true of almost all Freeview receivers. Freeview signals are typically hundreds of times weaker than terrestrial transmissions and if you've managed with a set top aerial so far it's been working more by luck than design. I find that most set top aerials are so badly made that they're often faulty when new, but as most tend to flogged cheaply at markets and car boot sales the supply chain has no incentive to improve the product.
There has recently been a national Freeview retune, to complete this correctly your box needs the kind of solid and reliable signal which you cannot get with a set top aerial. Some receivers had compatibility issues with the retune and in many cases manufacturers broadcast OAD's (Over Air Downloads) to update the firmware in the boxes to be compatible. OAD's almost never successfully install via set top aerials.
There is an official list of Freeview devices which are known to have problems with the retune; unfortunately it has not proven to be a comprehensive list. The Humax MG-TU1 is one of those which have had problems and from memory it's closely related to your Humax PVR. The official advice is that you contact Humax directly on 0870 247 8800, but they'll probably instruct you to test your box using the aerial system it's designed to use before they'll be interested in offering further assistance.
Nov 05, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
No signal for 5 days. aerial works in television
Off/ON signal U well get ur signal back.Make sure U have plug in tight have power all the times.
Aug 13, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Jan 16, 2009 | Philips DVDR80 DVD Recorder
Goodmans GTV69RFDT Television had all freeview now only getting 3 channels
First ensure that the TV input is set on the Freeview channels, just in case.
Then check the antenna, when Freeview does not get all channels, it is always the aerial (antenna).
Many areas in UK have still poor reception. If you use an internal antenna, go to Argos or Currys and buy an amplified antenna for freeview, that will improve the signal.
Oct 15, 2008 | Goodmans W280NS Television
No Satilite Signal
it is a dicontinued like mine roadmate700 and started losing sattilite signal like everyone says here ,i got upset i spent alot of money on it,then this happens, so i decided and bought the new magellan mastreo 4000 and just updated the software and no problems i love it,portable,thin light weight internal chargable battery that lasts 3hrs,the signal strenght is awsome,never had any problems,my advice junk it, the 700 like i did and purchase a new unit.this way it will save you alot of problems and headaches in the future,beleive me.
Aug 02, 2008 | Magellan RoadMate 700 GPS Receiver
X2Gen MV20T TV Logo
234 people viewed this question
Top X2Gen Televison & Video Experts
Computer Repairing
Computer Repairing
ray gallant
Are you a X2Gen Televison and Video Expert? Answer questions, earn points and help others
