Question about Craftsman Garden
Battery 4 craftsman lt1000
Need to charge battery but no indication of the voltage on the battery
  • 49 Answers
SOURCE: Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Posted on Jan 29, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 3 Answers
SOURCE: craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Posted on Jun 23, 2009
  • 12 Answers
SOURCE: I just put a new battery in my Craftsman LT1000 & it stalls out?
MAKE SURE YOU DIDNT HOOK THE WIRES UP BY MISTAKE. I HAVE SEEN THIS HAPPEN MORE THAN YOU WOULD THINK.IT OVER LOADS THE CHARGING SYSTEM AND SHORTS IT OUT
Posted on Jul 29, 2009
  • 138 Answers
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Posted on Aug 25, 2009
Craftsman LT1000 riding mower hard to turn over
Make sure carb is not dumping gasoline into cylinder causing a hydraulic lock
Jul 29, 2014 | Craftsman Garden
LT1000 lawnmower clicks when trying to start. It is the module that the cable from the starter is connected to. What is wrong?
You might want to check your battery, sounds like it is weak put it on a charge overnight and see what happens. Preferably a battery maintenance charger, they give the best condition for charging batteries
Nov 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jul 26, 2009 | Garden
Craftsman lt1000 18 hp briggs keeps wanting to die
Jun 23, 2009 | Garden
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Good battery & good starter but won't crank craftsman lt1000
check and see if the white wire on the starter solenoid has voltage when the key is in the start position. If so, the solenoid is bad. If not, back probe wire until you find voltage.
Feb 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
429 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
