Question about Universal Remote Control MX-3000 LCD Touchscreen Remote Control
My mx300 the select key is not working correctly
My select key on right is fine but if I use thearrows to the left or the right they are not moving any suggestions?
  • Bob Krause Apr 15, 2009
    I have exactly the same issue. Have you received any response yet?
    Problem Solver:
  • 15 Answers
You may have "gunk" in your remote. Start with a compressed air bottle and spray inside carefully. (do not open the remote up). Use a damp cloth and wipe as much as possible. See if there is any difference. It may need to be repaired.
You can contact info@totalcontrolremotes.com with any MX-3000 related issue - they are authorized dealers, programmers, and specialize in this type of remote control.
Posted on Sep 06, 2009
Google screen only (all other screens are correctly positioned) has moved right, can't access right side of screen. can't adjust
Press the windows key on your keyboard, and while holding it down, press the the left arrow key. that will move it to the left.
Dec 05, 2014 | Google Chrome
Windows start bar has completely gone
Sympton
You cannot see the taskbar (which contains the "Start" button) anywhere on your desktop.
Causes
  1. The taskbar may be hiding at the bottom of the screen after being accidentally resized.
  2. If the presentation display was changed, the taskbar may have moved off of the visible screen (Windows 7 and Vista only).
  3. The taskbar may be set to "Auto-hide" (Windows XP with Service Pack 2 only).
Solutions
  1. Put the mouse pointer on the bottom border of your screen.
    • If the pointer turns into a double-arrow doublearrow.gif, click and drag upwards.
    • If your taskbar isn't hiding at the bottom of the screen, try moving the mouse to the right, left, and top edges, looking for the double-arrow.
  2. Press the Windows logo key and the P key on your keyboard to bring up the presentation display mode options.
    • Make sure "Computer Only" is selected.
    • Use the arrow keys to toggle between options and Enter to select the correct display mode.
  3. Press the Windows key on the keyboard to bring up the Start Menu
    • Right-Click on the taskbar and select Properties.
    • Toggle the 'Auto-Hide the taskbar' checkbox and click Apply.
    • If it is now checked, move the cursor to the bottom, right, left, or top of the screen and the taskbar should re-appear.
    • Repeat step three to return to your original setting.
Dec 04, 2012 | Computers & Internet
Letter between c and b wont work! its the paste code key also and I dont recall using it to paste anything Whmat's your problem?
Of course, it wont work because you used a wrong short cut key. The correct short cut command for copying is press the control C simultaneously then for pasting it, it should control V simultaneously. Try it again using the right short cut command. Good luck!
Sep 20, 2011 | Microsoft Comfort Curve 2000 Keyboard
The print is very large.tried to hold the ctrl key and - key to make it smaller. does not work
Right click on the desktop
select Properties
Select Settings at the top
then on the left side move the "slider" to adjust you screen resolution to a higher setting ( move to the right)
Nov 17, 2010 | Computers & Internet
How do I use a micro sd card to save photos?
Before doing the steps pls format the memory card first
To transfer pictures to memory card follow the steps below:
  1. Remove the memory card slot cover, located on the upper right side of the handset
  2. Insert a microSD memory card into the memory card slot, until it locks in place
  3. From the standby screen, press the left soft key for Menu
  4. Select My Stuff (7)
  5. Highlight Graphics, using the navigation keys
  6. Press the left soft key for Options
  7. Select Open (1)
  8. Highlight desired Photo, using the navigation keys
  9. Press the left soft key for Options
  10. Select either Move (4) or Copy (5)
  11. Select either Selected (1) or Multiple (2)
    • If Multiple, highlight each Photo, using the navigation keys
    • Press thecingular%20logo%20only.jpg key to check each Photo’s box
    • Press the left soft key for either Move or Copy
    • Highlight Memory Card, using the navigation keys
    • Press the left soft key for Select
    • Highlight the Graphics folder, using the navigation keys
    • Press the left soft key for Options
    • Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
  12. Highlight Memory Card, using the navigation keys
  13. Press the left soft key for Select
  14. Highlight the Graphics folder, using the navigation keys
  15. Press the left soft key for Options
  16. Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
  17. Remove the microSD memory card from the memory card slot
Oct 19, 2009 | Samsung SGH-A707 Cellular Phone
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
Need the ability to "tab" from field to field on right of kybd
When you press ENTER to finish working in a cell, Microsoft Excel moves the cursor one cell down by default. However, you can select the direction in which you want the cursor to move.
  1. On the Tools menu, click Options.
  2. On the Edit tab, do one of the following:
    • To change the direction in which the cursor moves, select the Move selection after Enter check box, and then select a direction in the Direction box.
    • To keep the cursor in the current cell, clear the Move selection after Enter check box.
Note When a range or set of ranges is selected, pressing ENTER moves the cursor within the range or set or ranges only.
Jan 22, 2009 | Logitech Marble Mouse Trackball
Keypad problem
hi my n73 keypad is nt working' all keys nt work
Jun 02, 2008 | Nokia N73 Cellular Phone
Mx300 fax / printer
I found this on Canon's website.
Remote RX If the fax interrupts telephone conversations after the initial sixty seconds that it uses to monitor for fax signals, change the Remote RX ID number. The default Remote RX ID number is 25. See the folloing steps to change the Remote RX ID number.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button.
  3. Press the left or right arrow to select [RX SETTINGS], then press <OK>.
  4. Press the left or right arrow to select [REMOTE RX], then press <OK>.
  5. Press the left or right arrow to select [ON] or [OFF], then press <OK>.
    Note: The default setting is [ON].
    1. If [Remote RX] is set to [ON], a window will appear displaying the current REMOTE RX ID.
    2. Use the left or right arrow to select the preferred ID value (from 00 through 99).
    3. Press <OK> to set the ID.
  6. Press the <Fax> button to return to Fax standby mode.
If the fax continues to interrupt telephone conversations after the Remote RX ID number was changed, turn off Remote RX. The default setting from the factory is ON. See the folloing steps to turn off Remote RX.
1. Press the <Menu> button until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [REMOTE RX] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select [OFF] then press <OK>.
5. Press <Stop/Reset>.
Apr 09, 2008 | Canon MX300 Office All-In-One Printer
Universal Remote Control MX-3000 LCD Touchscreen Remote Control Logo
91 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
