Question about LG WM3988HWA Front Load Washer / Dryer
WM3988HWA Error NO Water Source
Can anyone advise why LG WM3988HWA all-in-one will not fill with water?  Faucets are on full force.  Tried to check pump area but water ran out onto floor. LG support line = NO help.  Geek Squad will not arrive for 3 days and we had old machines disconnected prior to delivery.   Thank you
  • fixer444 May 11, 2010
    Try pressing 'end of cycle' to clear the screen....'end signal'. To start afresh.
    Problem Solver:
  • 18 Answers
CHECK THE WATER FILTERS AT THE BACK OF THE UNIT THEY ARE PROBABLY DUE FOR A CLEANING.
Posted on Dec 29, 2009
Hi there, Ok, i think i'm getting close to solving this problem. I have an LG dishwasher- Model # LDS 5811ST. I have stripped it down and clean all hoses etc. It is running fine through all the cycles....
try adding some more water to the machine after it has done the fill cycle do not over fill it. if there is no change in the performance the you need to replace the main wash motor.
if there is achange the you need to change the fill valve
Apr 06, 2010 | Dishwashers
The code is f 20
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks.
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Apr 01, 2010 | Whirlpool GHW9100L Front Load Washer
My neptune washer has an indicator light that reads 'nf'. Can't find anything in the manual?
The washer has tried to fill and could not. Make sure the water faucets are open all the way.
Check for kinked hoses.
See error codes2_bing.gif on page 12 of the manual.
Dec 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
LG wm1832cw filling slowly
The water valves might be going bad, or there is a clog in the hoses. Also check the water pressure going into the washer.
Dec 03, 2009 | LG Washing Machines
Display code FE... what needs to be done
FE in an over fill error. (the pump should automatically come on to drain water) If the machine is not overfilling, check the thin hose that goes to the water level switch. If it is overfilling you will either need to replace the inlet water valve if it is filling with no power to the vavle, or the main control board if it is receiving power in the FE condtion.
Oct 08, 2009 | LG WM3988HWA Front Load Washer / Dryer
LG LDS 5811ST still getting the IE error after several fix tries
If Hall sensor is OK? Air break replace next PCB
if there is enuf water ?
Aug 18, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
When Istrted to wash my cloths , the washer stop and post F-20
drain_inlet_hose_wall.jpg Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Dec 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM3988HWA Front Load Washer / Dryer Logo
131 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
