Question about Onkyo TX-SR606 Receiver
No audio sound from HDMI connection from TV to Onkyo 606 amp.
I have tried to connect the HDMI cable from HDMI out on the Onkyo 606 amplifier to an HDMI in on a Samsung Digital TV. I cannot receive any audio out through through the amplifier and my home theatre speakers. I have read the manual several times and cannot see that I am missing any steps. Help.
If you go to the setup menu, hardware setup, hdmi, and turn the audio out: on it should work hope this helps
Posted on Jul 29, 2009
    Problem Solver:
  • 12 Answers
You have the output of the receiver going to the input of the TV?
i believe that you should be running the TV output to the receiver input to get your sound from the TV to the receiver and thus speakers.
the easiest setup is to just run your cable box and DVD player HDMI's into your TV inputs. then run another HDMI from the TV output to the receiver input.
Posted on Mar 01, 2009
  • Mark Willison
    Mark Willison Mar 01, 2009
    you have the output of the receiver going to the input of the TV?
I would like to find out how to play audio from my panasonic viera tx-40cx400b tv/other devices e.g. xbox one etc through to my Teac A-H300 amplifier.
Having looked at the TV, you will have a lot of problems trying to connect to that amp. The TV has a digital optical out output only. The disc player you mentioned will also be out only. You need a optical "in" for them both. The TV has no analogue out sockets. The only chance you might get any sound out is via the scart socket. If that is fully wired, then the scart might produce L&R analogue out. A scart plug with RCA connections (make certain it has both audio in and out) might produce some sound for the amp.
Otherwise no chance!
The amp you have was not made to work with digital signals. The TV will produce high quality Dolby 5.1 sounds. Assuming you get the scart to produce the sound, then you will only get stereo sound, little better than the TV itself!
I therefore recommend you get a decent digital amp that you connect all your future devices too. One that has HDMI connectors as well as at least two optical inputs.
Onkyo make some excellent models. For example this model would do the job Onkyo TXSR444 Home Cinema Receiver.
Feb 25, 2016 | Teac A-H300 Amplifier
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
No Audio in HDMI THRU Onkyo HT-R380 Receiver
Hello, I am sorry about your issue. I suggest that you contact us at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Mar 03, 2017 | Onkyo HT-S3300 Theater System
TX-SR606 hdmi ports work when unit warms up? and on screen
Why don't you connect the HDMI cable direct to your tv. For audio run a digital cable to your receiver.
Feb 24, 2010 | Onkyo TX-SR606 Receiver
Onkyo 606 doesnt show video anymore fom ps3 over hdmi
i hate to say it i got the same problem and the only way i sorted was a master reset which means u have to do all the set up again and asign all the hdmi again but since i done that no problems to do this un plug the lot for an hour reconnect everything then push and hold the vcr button and push stand by a message will say clear on the receiver then it is back to when u frist got it out th box hope this helps
Sep 03, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
Jan 24, 2009 | Onkyo Audio Players & Recorders
I recently bought a Onkyo TX-SR606 Amp, I can get audio through the Amp for everything else (Foxtel HD, PS3, DVD) but not for running normal television through the Amp or using the Built in Tuner on my...
The reason for this is that the HDMI out from the Amp is out only,and does not feed back anything from your TV etc.You will have to connect via other means such as Digital out from Tv to the Amp
Aug 02, 2008 | Onkyo Audio Players & Recorders
Ps3 defaults to 576p when connected through onkyo 606 receiver
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Jun 22, 2008 | Audio Players & Recorders
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR606 Receiver Logo
1,231 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
