Question about Sony KV-35S42 35" TV
Tv won't power up
We recently had a power failure with power surges prior to the failure. When the power returned, my TV will only blink the red "standby" light continuously. I tried unplugging the unit for a day, no dice. Any help is greatly appreciated.
    Problem Solver:
  • 11 Answers
Your regulator might be blown, & the red led is an indication your standby supply is still up. I can't recall the part #, its MX ### something, but there will most likely be a .22 ohm resistor feeding it, it'll be blown to
Posted on Aug 03, 2007
SOURCE:
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Tv Won't come on
I suspect a power board failure but to be sure i would have to know how many times your light is blinking as there is a code to it. please repost with number of blinks. This is a common problem with this brand of sony televisions as far as I can tell from what i have been reading online. If you are still under warranty you should contact Sony. If you need further help from an expert please let us know the number of blinks.
Aug 03, 2007 | Sony KV-35S42 35" TV
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Wont turn on but tries too come on,power light blinkink
Internal power supply failure. Was there a lightning storm in your area recently or utility work being done recently? This two things usually kill TV's and other electronics with surges when power is restored. If the set is under warranty call the manufacture, if not, call you homeowners insurance agent to see if the damage is covered w/or w.o. deductible. At least you can get something toward repair/replacement costs. Future fix, purchase and install a surge arrestor in your main AC panel for the whole house or buy a power strip with a built in surge filter/protector for your expensive equipment.
Jan 23, 2014 | Samsung PN51D490 3D Plasma TV
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
RED LIGHT KEEPS BLINKING..WAS LIKE A POWER SURGE THIS MORNING..I UNPLUGED TV OFF MOSNTER SURGE PROTECTOR..CAME HOME AND PLUGED BACK IN...TV RED LIGHT TV REC STILL BLINKING
Surge protectors aren't perfect... If the surge was big enough and long enough then it can cause problems. Most manufacturers have on-board protection as well. That's not perfect either. Often the surge does nothing more than confuse the microprocessor (computer) that controls all aspects of your television. The fact that the red light is blinking means that your set is trying to protect itself. This can happen for one of two reasons. Something in the set has failed. Usually the power supply inside the set possibly also a trouble in the scan section of your set. These are normally a shop repair. The other thing is when the microprocessor is confused it will do nothing further until it's reset. To reset the processor simply unplug the set from the wall and wait 10 minutes. Plug it back in and if it works then happy viewing. If it doesn't then you will need a repair.
If is a failure caused by a failure in the grid that delivers power to your set then you are usually able to file a claim for the repairs. Contact your local power company. explain what happened. If it's their fault then usually they will pay for a repair. I know the PG&E does.
Zashiban
Jun 23, 2010 | Toshiba 42LX196 42 in. LCD HDTV
I have a sony kdf60xbr950 rear projection television. the bulb has recently been replaced. one day while programming the tv to work with a universal remote it stopped turning on. when i attempt to turn...
depress the pin that the lamp cover should and the picture returns. never will i buy sony ever again. their tech support could not tell me to push a pin down when i described my problem to them and told them the led light pattern? i bought sony because i felt like i would have support for my products. boy was i wrong. now even though the tv works again it suffer from a blue blob across the screen now. perhaps the pin is not depressed all the way.
Apr 08, 2009 | Televison & Video
Sony KV-35S42 35" TV Logo
127 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
