Question about Apple iPhone Smartphone
I cant turn on my iphone, dark screen and stuck on the itunes sig
I cant turn on my iphone, it doesn´t seem to be charging Iby no means I don´t get the charge "sign"..The screen is dark and it only shows the shadow of the Itunes transmission sign always.... what a pitty .....
Its an A1203 8G,... I only used it for 2 days--..
i would really apreciated if anyone could help me
thanks a lot
p.s. i already tried several chargers
  • 1 more comment
  • michellara Mar 03, 2009
    it is still not working after 2 weeks so Im gonna let it dry more
    thanks for the solution though
  • michellara Mar 05, 2009
    thanks a lot anyway
    marthazcasto I have tried that several times but no answer...
    thank you very much for your comment
Try to hold the home and power button and try 2 reboot it then wen u see the apple come on let both of them go
Posted on Mar 01, 2009
Hey i had the same problem just hold the lock button and the middle circle one at the same time i guess to reboot it
Posted on Mar 05, 2009
Ipad won't turn on and stuck on itunes
if you can't turn it on, how can you know it's stuck on itunes? Try charging the ipad if the battery gets to low. the ipad will not turn on or give you any indication of that condition other than it won't come on. You may need to charge for at least a couple hours. having been off that long, I would the itunes issue would no longer be present. It you try itunes again, be sure a tell what you did to get it in that state.
Mar 21, 2014 | iPhone Apps
Cant update my iphone 4 (model mc609ll )
Perform a recovery-mode restoreIf your iPhone, iPad, or iPod touch is already showing the "Connect to iTunes" screen, please go to step 5.
  1. Connect your USB cable to your computer but not to the iPhone, iPad, or iPod touch until step 3.
  2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the device to turn off.
    • If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
  3. While pressing and holding the Home button down, connect the USB cable to the iPhone, iPad, or iPod touch. The device should turn on.
  4. Continue holding the Home button until you see the Connect to iTunes screen. When this screen appears, you can release the Home button:
    Note:
    If the image of a battery appears, let the device charge for at least ten minutes to ensure that the battery has some charge, and then start with step 2 again. If you don't see the Connect to iTunes screen, try these steps 1 through 4 again.
  5. iTunes should automatically open and display the following message:
    [img alt="Alert text: "iTunes has detected an iPhone in recovery mode..."" width="520" height="241" src="http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT1808/HT1808--recovery_alert-002-en.png" data-hires="true">
    "iTunes has detected an iPhone in recovery mode. You must restore this iPhone before it can be used with iTunes."
    If iTunes not open after two minutes, please open iTunes yourself.
  6. Use iTunes to restore the device.
Sep 21, 2013 | Apple iPhone 4 Black Smartphone
Iphone stuck on apple logo
  1. Connect the iPhone's USB cable to your computer, but not your iPhone.
  2. Turn you iPhone off. If the phone won't turn off in the traditional manner, just keep holding the buttons until the screen goes dark.
  3. Once you've turned the device off, press the home button on the face of the device and plug in the USB cable to the device's dock connector.
  4. When it turns on, keep pressing the home button until the iTunes logo appears on the screen.
  5. You'll know the phone is now in recovery mode because a window in iTunes will tell you.
  6. You can then start the restore process by clicking the "Restore" button in the iTunes window.
Sep 12, 2013 | Audio Players & Recorders
My iphone 3 wont turn on
Connect it to iTunes, you might need to activate it, or restore it.
that's all that means. There's no verifiable OS active on the phone
Nov 12, 2011 | Apple iPhone Smartphone
The screen is dark and it will not charge then u plug it up all it does is show that it needs to b connected to itunes but it wont do nothing else
Plug in your iPhone, and while it is showing "connect to iTunes", run this software: http://cache.firmwareumbrella.com/downloads/tinyumbrella-5.00.09.exe and click on "Fix Recovery" once it detects your phone. It will kick it out of recovery mode, which is where you're stuck right now.
Aug 19, 2011 | Apple iPhone Smartphone
IPHONE STUCK ON USB AND ITUNES SCREEN CANNOT CHARGE
It's sounds like your iPhone is stuck in recovery mode
Try this
Sep 23, 2009 | Apple iPhone 3G
When i plug my ipod touch into the computer this comes up..HELPP
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Sep 06, 2009 | Apple iPod touch
My iphone got stucked on the apple logo
here is a small tutorial that my help you....good luck I hope this helps please don't forget to rate
http://www.youtube.com/watch?v=u4xLvpazV24
Jul 19, 2009 | Apple iPhone Smartphone
My iphone won't sync with itunes. it did at first but now keeps coming up with an error I have an original iphone, never been jailbroken or any such thing, and can not currently get it to sync with itunes...
Recharge
Make sure iPhone is charged. Connect to a USB port and look for the lightning bolt battery icon in the upper right. If you don't see this icon, then iPhone is not charging. The battery will charge to 80% in an hour.
Note: If you put your computer into sleep mode while iPhone is connected via USB, iPhone may not charge.
This screen means to keep iPhone connected so it continues charging. Please note:
If iPhone is not sufficiently charged it will not show up in iTunes
Use a high-power USB port such as the one on your computer, or use your iPhone AC adapter.
Don't use the USB port on your keyboard because it is a low-power port and iPhone will not charge.
Make sure you are using USB to charge. Accessories that use FireWire to charge are not supported with iPhone.
If you see the red part of the battery image flash three times and then the screen goes black, it means that iPhone is not receiving power to charge.
If the above steps dont resolve follow the following steps :
Retry with a different USB port.
Note:
Restart
Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Does iPhone appear frozen or stuck? Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone again.
Note: If that doesn't work, try restarting your computer.
Reinstall
Reinstall iTunes 7.7 or later.
Get the latest version of iTunes (7.3 or later) from http://www.apple.com/itunes/download/
Thanks.
Oct 21, 2008 | Lands Phones
Apple iPhone Smartphone Logo
280 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
