Question about Explorer Appliances BO696 Gas Kitchen Range
BO696 problems-burners too high on lowest position
We use propane and somewhat of a problem also is the need to depress the knobs for several seconds after burners ignite.
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Posted on Mar 18, 2009
Kozy world propane wall heater pilot will not light
This can be caused by several things:
1. The inline gas valve running to the the heater is OFF. Turn the valve ON.
2. The gas control knob on the heater is not exactly in the PILOT position. Unless the knob bottoms
out and you feel strong pressure (other than spring pressure) pushing back at you. It's not exactly
in the PILOT Position. Once the pilot lights, hold the control knob in for 30 seconds to 60 seconds
to allow the Thermocouple to full heat.
3. The pilot is dirty and needs to be cleaned, as do the burners.*
4. The LP Gas Tank is empty or to low to maintain te proper gas pressure.
* Here is a link to a demonstration on how to properly clean the pilot & burners.
http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 23, 2011 | The Companion Group Kozy World Portable...
I have a brinkmann 4 burner. The cross over at the back of the burners has it's own flame. The back of the grill, even at the lowest setting is still very hot. Flames come up between the plates. On...
Sounds like a gas regulator problem. But, somewhat unusual, as most people complain of low flames. In any event, you will need to replace the Hose/Regulator Assembly. They run about $30.00 and can be found at any hardware store or home center, that sell gas grills and accessories.
As a safety measure, after turning off the gas tank, check each burner for blowout or rust through..
I hope this helped you and thanks for choosing FixYa.
Jul 31, 2011 | Brinkmann 810-8530-S Stainless Steel...
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
I cannot get the gas grill to light. The tank was not completely empty but I replaced it anyway to make sure that was not the problem. I have the same problem with the refill. It does not seem to be...
the regulator could have gone into lock up.
try this to unlock it...
  1. Open the BBQ Lid
  2. Turn ALL main control knobs to the "OFF"/CLOSED position
  3. Turn the Propane tank valve to the "OFF"/CLOSED position
  4. Disconnect the Regulator hose from the Propane tank
  5. Turn ALL main control knobs to the "ON"/OPEN position
  6. Let stand for 1-2 minutes, allowing all excess gas in valves and manifold to dissipate
  7. Turn ALL control knob back to the "OFF"/CLOSED position
  8. Reconnect the regulator hose to the Propane tank- hand tighten only.
  9. Check all hose connections to ensure that a positive seal has been made
  10. SLOWLY turn "ON"/OPEN the propane gas supply
  11. Wait approximately 5 seconds for the regulator pressure to stabilize
  12. Turn "ON"/OPEN the selected burner control knob to "HI"
  13. Press the Multi Spark ignition button or match light selected burner.
  14. Hope this helps you has me in the past!
Jan 08, 2018 | Char-Broil 463220004 Grill
The flame coming out of the burner bars is small
May likely be low on propane or propane tank gate valve not opened far enough. Otherwise sounds like faulty regulator.
Jan 16, 2010 | Weber Genesis Silver A Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
BO696 problems-burners too high on lowest position (propane used)
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Explorer Appliances BO696 Gas Kitchen Range Logo
560 people viewed this question
Top Explorer Appliances Kitchen Ranges Experts
Vernon Taylor
Are you an Explorer Appliances Kitchen Range Expert? Answer questions, earn points and help others
