Question about DeLonghi EAM3400 Espresso Machine
DeLonghi EAM3400 Magnifica with broken steam spout
We have a DeLonghi EAM3400 Magnifica  on which the steam arm has a plastic attachment of a plastic sleeve over an inner plastic spout. That inner plastic spout shot off the metal arm of the steamer the other day. We can't get it back on. There's a plastic residue of some kind on the metal arm. Since there are no threads on the inside of the plastic spout we thought perhaps this was a glue of some kind, but it would have to withstand high heat and pressure. We assume we can't replace the plastic valve, but is there a way? Can we order and install a new steam arm? I'm a handy person who works on computers and electronics. Is there a local repair shop in the Twin Cities (MN) so we don't have to ship it all the way out to California? Thanks, Susan
    Problem Solver:
  • 11 Answers
No offense to Irishwarrior but the answer to your question is yes, you can buy a replacement. Call Delonghi. The inner sleeve has a flat spot on the back that matches up with the steam wand. No glue, and o ring holds it in place, either the o ring is worn out or the hole in the bottom of the sleeve is partially clogged creating more pressure than the resistance of the o ring. A paper clip straightened out will "****" it out. If you need to replace the whole steam wand arm you would want to order a new "tap" valve. Delonghi can give you the # of an authorized service center where you can order one (Delonghi will not sell you "internal" parts)
Posted on Jan 19, 2010
    Problem Solver:
  • 10 Answers
You don't need to keep the plastic sleeve on the steamer. That's for creating more steam or frothing more than is necessary.
What I would suggest is this:Empty the espresso maker of all the water. Take it to the sink and with a scrub pad, remove ALL the plastic residue from the metal arm.
Then, set it back up, add water, coffee and when it's time to use the steamer, hold the cup under the arm, turn the steamer on and steam away!
There is no need for the plastic sleeve unless you want A LOT of foam and I have found that all it does is make a mess and is harder than **** to clean.
I hope I answered your question. If you have any more questions, please email me. Thanks!
Posted on Mar 01, 2009
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
I own a Delonghi EAM3400 Expresso Machine that has stopped processing water through either the steamer or spout where coffee is dispensed. The unit is ~5 years old and is used 2-3x's daily. There appears...
turn unit on ...switch on ... turn water steam control to open position ,,,,,it should sound load then go quite as air lock will come through .. hope this works if not i repair you need spares .. ..postal service too 07779933829
Feb 23, 2011 | DeLonghi EAM3400 Espresso Machine
Hi. I have a Delonghi Magnifica EAM3400 that wont pump steam. When I turn the steam valve you can hear a slight click like a switch has been activated but the pump does not turn on. Does anyone know of a...
poke something up the outlet hole .....pin or something .. or if this dont work u need service and replacement parts .. bsc appliance 07779933829 we carry out repair service via post anywere.
Dec 03, 2010 | DeLonghi EAM3400 Espresso Machine
The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Jul 20, 2010 | DeLonghi EAM3400 Espresso Machine
Plastic on steamarm blew off
Those pieces (2 of them) are suppose to come off. The outer sleeve turns 1/8th of turn clockwise looking down on it and then can be slid down. The inner slides off and has a flat spot on the back to line up with the steam wand, it's held in place by an o ring. All can be ordered through Delonghi.
They are designed to be removable so they can be cleaned after each use.
Before replacing any other parts, try descaling your machine. Build up will cause heating and steaming issues.
Aug 23, 2009 | DeLonghi EAM3400 Espresso Machine
Open Questions:
See all DeLonghi EAM3400 Espresso Machine Questions
DeLonghi EAM3400 Espresso Machine Logo
1,372 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
