Question about Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan
Replacement Motor for the NuTone LS80SE Ceiling Fan
Do you know where I can find a replacement motor for the NuTone LS80SE ceiling fan. Motor Type: 88624
Thank you, Mike Chmiel
    Scholar:
  • 95 Answers
Https://www.centralvacuumstores.com/nutone/fan-motor-ls-series.php
Posted on Mar 02, 2009
Nutone Model 671 Died and need Replacement
You should be able to use any replacement by Nutone. The kit should have finishing rings to install and cover anything from the old one.
Mar 12, 2014 | Broan-NuTone Dryers
Old NuTone 9093n Model replacement.?
Hi -- I just spent a couple of days taking out the old assembly, cleaning all the parts (layers of dust coats) and putting the 9093N back in order to fix the noisy fan. The cold air coming back in is from to the heating and I'd guess the heating element is busted. Yes, you can run it in both airflow modes: ceiling air exhaust and hot air blown to the floor. That said, the noise level on mine hasn't gone down. So I'll look for the replacement assembly. Good luck!
Mar 23, 2013 | Broan-NuTone Dryers
Our bathroom Nu Tone Model QT-100l fan is sounding loud and Rough. Can I purchase the motor part for this? If so will the motor be attached to the metal housing and I should be able to simply replace the...
The replacement motor is available from several sources online. The best way is to purchase the new motor assembly. All you need to do is remove the blower housing from the ceiling, there are three screws that hold the motor assembly in place. The whole job takes about five minutes. Here are a few sites with the motor.
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0 http://www.cshincorporated.com/product_info.php/manufacturers_id/33/products_id/11272
Aug 22, 2011 | Broan-NuTone QT100L Fan
I have a Nu Tone LS80SE bath fan that died. It is an obsolete fan with no more support. Is there a current fan replacement that doesn't require major modifications to my duct already in place? I just...
I had the LS-80SE and it appears that that model is discontinued, including the replacement motor. I ended up replacing it with the QTN110E, which is a bit bigger. The QTN is designed to mount to a joist on the opposite side of the LS model, I avoided having to do that by just screwing through the metal body into the joist that the LS was mounted to instead of using the mounting holes that are provided on the QTN. You will end up having to remove a small amount of drywall approx 1"x 11.5" to fit the QTN in. Put a backing strip or piece of plywood up and behind the drywall so that you have something to screw the filler piece of drywall in to when you do your repair, mud the cracks, sand, texture if need be... hope that helps
Feb 22, 2011 | Broan-NuTone Nutone LS80 Ultra-QuieTTest...
Motor replacement
The NuTone replacement part number for the motor is the S97017705.
http://bit.ly/aoPz0i
Oct 19, 2010 | Broan-NuTone (8663RP) Ceiling Fan
Fan motor does not work.
The replacement motor is available for that fan model. The NuTone part number is the 0696B00. It can be purchase from these sites:
http://www.ventingdirect.com/nutone-0696b000-power-unit-assy-packaged/p431404?y=16&term=0696b000&x=41
Jul 24, 2010 | Broan-NuTone QT100L Fan
We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
http://bit.ly/ax4Upk
Jul 12, 2010 | Broan-NuTone N-763RLN Combination Light...
My Nutone 8814R motor went out on my ceiling fan and i just ordered a new motor. My question is how do i take out the old one and replace it with the new one. Will it be easy to do myself? Also is there an...
The good news is that this is a relatively easy item to remove and replace, as they make a replacement fan/motor unit (sub assembly) that you can swap out for the old one.
All you need to do is pull down on the trim vent plate and then squeeze the wire retainer clips together to remove the grill/trim.
Once you've done that, you can unplug the fan portion of the exhaust fan unit from the base enclosure. Now simply remove the screw or nut that holds the fan and mounting plate into the enclosure and simply pull it down and pivot it out of the enclosure - you might have to push in on the side of the enclosure where you removed the screw/nut to get the fan and metal plate out of the cabinet.
The replacement fans usually come with a new metal mounting plate that fits many of the older exhaust fans, but if your's looks different or doesn't work, you can remove the fan and install just the fan motore onto your old metal fan mounting plate.
Instructions are typically included in the replacement unit packages. This is also very simple to do with only 2 screws holding the fan onto the mounting plate.
Once you're done, simply hook the edge of the plate back into the fan enclosure and then push it up and fasten the mounting screw/nut onto the plate and plug the fan into the ceiling enclosure and replace the grill plate and you're all set!
Hope you find this Very Helpful and best regards!
Oct 12, 2009 | Broan-NuTone Deluxe 8814R Ceiling Fan
Have a broan n688 ceiling exhaust fan in bathroom and now it takes a couple of minutes to actually start, finally making a whirring noise before coming on. Solution?
First turn the power to the fan OFF. Take it down from the ceiling by removing the screws holding the cover on. Then remove the screws holding it to the ceiling. Then unscrew the screw caps that twist (connect) the wires from fan motor to the house wiring. Do a general clean up on the fan. Use an old paint brush to get in the hard to get at places. Rotate the fan by hand. If it does not rotate freely, put some oil on the shaft where it goes into the motor, and put some on where the shaft comes out the back. If it still does not rotate freely, buy a replacement and install it.
Oct 07, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
New Broan fan rattles
I would take it back for exchange...
($159... is high end pricy... Amazon = $168 (worse)).
Old ... tired fans can dry out... gather dust.
Their life can be significantly extended with
fresh lube... As for me...
I've learned to just find & buy a NEW MOTOR.
But a new FAN... Outrageous!
Take it back
... Broan-NuTone Nutone Is a QUALITY
FAN... Expect quality.
Apr 20, 2017 | Broan-NuTone Nutone QTRN080 Quiet Test 80...
Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan Logo
3,335 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
