Question about Dewalt DW618 Router
How to open the case in order to replace the bearings
    An expert whose answer gotĀ voted for 100 times.
  • 86 Answers
This is a serious disassembly and re-assembly.
Not only do you need to remove the yellow plastic cover end, but also disassemble the collet end. Depending on which version 618 you have it may have screws on the collet end or just a large nut. Sometimes you can't see the screws because they are plugged or covered with wood dust. The bearing is press-fit on the shaft on at least one end and requires an arbor press and special pressing sleeve. So you can only get so far on one of the 618 models then you have to use the arbor press to finish disassembly. The outside of the bearing sits in a very very close fit bore in the aluminum housing, which often becomes very difficult to disassemble without heating the aluminum housing. One bearing (top) must be pressed off the shaft and the replacement bearing precisely positioned where the old one was, so you need to measure with an inside snap gage, a dial caliper tail or depth micrometer to assure proper re-positioning. If you don't get it right then the motor shroud will rub the housing and the shaft won't sit right in the lower bearing.
You also need to replace the brushes while you have it apart. Between the labor, brushes and bearings cost you are better off taking it to a DeWalt service center - but even so, the cost to replace the router would usually be less than the service cost if it is out of warranty! Be very careful to make sure if you or anyone does do this job that the replacement bearings are properly rated for high speed - otherwise you'll be doing the job again in a few months of use.
Posted on Mar 01, 2009
My Amana washer makes load noises during wash cycle, what could cause that?
transmission bearings are the problem and transmission needs to be replace in order to fix the problem, in some cases some people chenge only the bearings but is better to replace the transmission at once.
Dec 03, 2014 | Amana 3.2 cu. ft. Top-Load Washer
My receiver ventilation fan does not work
Could be seized bearings. Open up the case. Take a note of the part number. Order a replacement. Fit it.
Sep 05, 2014 | Audio Players & Recorders
Greasing the axle
The front wheels don't use axles, instead they use roller bearings similar to auto wheel bearings. Scooter front wheel bearings are usually sealed bearings or shielded. If the bearing is stiff or ruff and a sealed bearing you must replace it. Sometimes you can revive a shielded bearing by soaking in carburetor cleaner rotating soaking rotating soaking until the bearing runs smooth. Then you repack the bearing with grease. To repack a bearing you must place some heavy grease in the palm of your hand. Hold the bearing at a 45 degree angle to your palm. Catch some grease between your palm and the inside of the bearing race. Force the grease between the race and the shield until you see grease coming out the other side. Do this all the way around the bearing The rear wheel are normally mounted to the trans-axle. The manufacturer considers this to be a sealed unit however you can open it. Remove the Allen head screws and split the axle case by move the slender side down the shaft until its open enough to apply grease with a gun. PUT LOTS OF GREASE. When you close the case most of the grease is going to be squeezed right out again. To prevent this i installed a Zerk fitting. WARNING Do not install a Zerk yourself. What i'm trying to do is to pressurize the case with grease in order to get the grease to where its needed. Do not use the scooter inside until you find its not dripping grease. Hope this helps
Jun 02, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Whisperflow pump making loud squealing noise
The noise is likely either the seal or a bearing in that order. If you are mechanically capable of working on the pump yourself then you can purchase a seal and gaskets at a pool supply store. If the bearings are bad then the motor needs to be replaced. In some cases a bearing can be replaced but usually it is more work than it is worth.
Aug 09, 2011 | Pentair 1 hp WhisperFlo InGround Pool Pump...
How to replace front wheel bearing
Jack up vehicle, use jack stands for safety. Remove wheel, brake caliper, axle nut, brake caliper bracket, rotor. Remove wheel hub bearing bolts, unplug speed/abs sensor, remove bad assy. Good idea to clean up any corrosion on spindle where bearing mounts and use anti seize in case you have to replace again down the road. Sometimes it is a pain to get bearing assy. loose from spindle because of corrosion. Reverse order of dissassembly and use manuf. suggested torque for reassembly.
Nov 11, 2010 | Chevrolet Venture Cars & Trucks
How do you take the inner drum out of a Frigidaire front loading washer?
Make sure you have plenty of well-lit space to work as well as lay out the parts removed. Remove the cabinet top by removing several screws from the rear, slide it back somewhat, then lift up. Remove the back panel by removing screws along the top rear, then lift up. Pull loose the rubber boot (it's glued to the cabinet front opening as well as to the outer drum face) CAREFULLY from the front panel opening. After uncoupling the drum motor, wiring, hoses, and suspension components, lift out the entire outer drum assembly. The case splits after removing a handful of bolts from the split circumference. Remove the large drum pulley and any snap-rings holding the large shaft in place. The inner drum should pull out of the rear case, but leave the bearings and seal in the case. The inner bearing and seal are prone to failure over time. The official fix is to replace the rear case (with new seal and bearings) for some 300 to 400 dollars. We chose to replace the bearing and seal from a local bearing supply house for about $16. It's still working well after over 10 years. Assemble in reverse order. Use 3M automotive trim cement for gluing the rubber boot back to the cabinet front. Hope this helps!
Jul 25, 2010 | Frigidaire GLTF1670A Front Load Washer
Squealing coming from alternator pulley bearing. any way to replace just the pulley or bearing
clean the glaze off the pulley first. If the squeaking is still present replace the bearing. They are sold separately at Berry Bearings nation wide. The Altenators case will have to be opened up to remove the bearing
May 03, 2010 | 2006 Pontiac Grand Prix
F1 code, bad filter, bad bearing, bad machine
Hey I just quit from sears what you are saying can't be true. LOL jk. I know exactly what you mean I had to order a bearing 3 times before I got one that was not broken. I wish you the best.
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Lights on for service engine soon anti lock and trac off
Id have to know what code has triggered the Service Engine Soon light in order to diagnose that. It could be related to the anti-lock and traction control system being off or it could be something separate.
That said, it is common for the anti-lock and traction control to be turned off if one or more of the wheel speed sensors goes bad. In some cases the wheel speed sensors are separate from the wheel bearings but in your case I believe they are integrated with the wheel bearing, so in order to replace the sensor you have to replace the wheel bearing.
In order to know which wheel bearing is the culprit, you'd have to have the car hooked up to a scan tool capable of reading ABS codes.
Dec 31, 2008 | 2001 Oldsmobile Alero
Dewalt DW618 Router Logo
568 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
