Question about Dell R6053 Keyboard/Multimedia Control Panel
My dell keyboard is locked up again!
How to unlock by dell keyboard
    Problem Solver:
  • 7 Answers
Call Dell and talk to there repair technican in the service department. Sounds like you have two items trying to use the same IRQ, if that is what is happening you will need to do some internal resetting of cards that you have put in. By chance havve you installed any equipment just before this started happening>
Posted on Mar 01, 2009
How to unlock keyboard for dell isperon 7000
There is no way to lock, or unlock the keyboard. Please try booting your system, and press F2 and see if you can enter the BIOS. Try this with the internal keyboard. If this does not work, then try running the keyboard test from the Dell Diagnostics. The internal keyboard should work, even when an external keyboard is attached. See if the keyboard will work in the diagnostics. If not then you have a keyboard failure
Aug 20, 2014 | Dell Inspiron 700M Notebook
Unlock keyboard AND mousepad!
Hello, have you tried plugging in a USB keyboard or mouse? I'm have a hard time finding info on locking or unlocking a keyboard and mouse pad on a laptop, (without third party software) there is one bit of software that requires you to type "unlock" to gain control again. I doubt thats you problem.
have you rebooted the laptop? press and hold the power button for 4 seconds and the pc will shut off.
Oct 20, 2013 | Dell Latitude D820 Notebook
Caps lock light flashing and laptop not responding
Hello.
Disconnect all power. Flip the laptop to unlock and remove the battery. Reinsert and lock the battery. Power on, again.
Hope this helps.
Jan 05, 2012 | Dell Keyboard for Inspiron 1300 B120 B130...
One day I noticed after my kid played with my laptop dell insperion mini 1012 that my keys stopped wprking. The mouse woorks and when I searched in the control panel it says the divice is working. It has...
Look at the top right hand side of the keyboard. See if the NUMB LOCK and FUNCTION LOCK keys are lit. If one or both are lit hit the key to unlock it.
Pressing the WINDOWS KEY and the letter U will bring up ease of access window. Down the list you'll see use without keyboard and mouse. Click there and make sure it is not check marked. You may also need to turn off STICKY KEYS and FILTER KEYS and hit save to unlock it.
Try pressing the WINDOWS KEY and the letter L at the same time and see if that doesn't unlock it. If that locks it instead of unlocking it press it again to unlock it.
If none of these fixes the problem then UNPLUG the laptop from the adaptor. Turn it upside down and remove the battery. Wait one minute then put the battery back in. Reconnect the power supply and reboot the machine.
Aug 16, 2011 | Dell Computers & Internet
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    The keyboard is locked
    Dear Sir,
    plz folow this step to unlock keyboard
    1. Step 1 Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
    2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
    3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
    4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
      For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
    5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
    6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
    Thanks For Your Time,
    Apr 13, 2010 | Dell adamo PC Notebook
    Dell keyboard locked up
    Dear Sir,
    PLzz folow this step to unlock your keyboard
  • Step 5 Reconnect the power adapter or AC cord. Start your computer.
  • Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard
  • Thanks For Your Time.
    Apr 10, 2010 | Dell 0Y3740 Keyboard
    My Inspiron 1525 comes on with the "9" lock(?) illuminated; it goes off while booting, and comes on. What is this "lock", is this "lock" important; what does it mean; and if I need to get it "unlocked",...
    Ordinary "desktop" keyboards have a separate "keypad" (slash, star, minus, plus, enter, dot, and 0 through 9) in the same layout as a "traditional" adding-machine.
    However, to keep the laptop's keyboard much smaller, those keys are superimposed on the right-hand side of the "standard" keyboard.
    So, press "NUMeric LOCK" to use the "keypad" layout, and press it again to use the "standard" letters (I, O, P, K, L, M, et cetera) on the keyboard.
    Keyboard is not responding it does sometimes then stop again
    Step 1
    Nov 15, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
    Dell optical wireless mouse locking
    If your mouse is "locking" the two most likely causes are either due to a battery issue or a connection issue. The first is unlikely since you're saying it started just after you replaced the battery, but you might want to try again if you have other new batteries around that you can use. Also you could try Re-Pairing (if you have the bluetooth wireless keyboard/mouse combo that dell offers) the keyboard and mouse after reboot. step by step Instructions for re-pairing or fixing a corrupted are should be available on the Dell support website and vary depending on the exact model you have.
    Jun 28, 2008 | Dell Wireless Keyboard Optical Mouse w0147
    Dell R6053 Keyboard/Multimedia Control Panel Logo
    430 people viewed this question
    Alun Cox
