Question about Sharp LC46SB54U 46 in. LCD TV
Error code e203 tv sharp lc-46sb54u - Sharp LC46SB54U 46 in. LCD TV
  • Anonymous Mar 28, 2009
    I have 2 Aquos. One receives intermittent E203 on one particular digital channel (via cable TV) the other is perfect. Amplifying the signal at the 2 splitters I have but no help. The last thing I can try is to change out the long (50 ft) cable run.
    President:
  • 1,077 Answers
My sharp manual says E203 means "No broadcast now".
Under possible solution, it says " Check the broadcast time in the program guide".
My manual says nothing else after that.
I hope that helps. Please rate me. :)
Posted on Mar 01, 2009
  • jayme May 01, 2012
    Had the same problem on my sharp TV LCD, with the error code E203, power tv off, Tv cord is on a power strip device, turn the switch off, and then waited few, then on, the error no longer there, called the cable people also, said the same power down and then wait. this does not fix it, a temp fix, sharp should know why, maybe needs a software update on the TV? Jayme
Can I use the USB service port to power a Bluetooth transmitter
Hi Frank,
If you are referring to using your TV as the USB port... you cannot. It's strictly for service. I have tried as well and it won't recognize it. It's strictly for servicing.
Mar 01, 2016 | Sharp LC-46SB54U LCD TV 46 inch Class,...
Sharp troubleshooting
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
The tv goes off but there is audio.
If you have sound the inverter board has failed,or one of the ccl lamps has died .when you switch on the powersupply sends power but on receiving a fault condition from either of the two faults above will shut down power to the inverter board.
Len..
Apr 11, 2014 | Sharp LC-46SB54U LCD TV 46 inch Class,...
Power and OPC blinks, TV will not change Input modes
Try removing set and or a box if used from power for several minutes.
Dec 23, 2012 | Sharp LC-46SB54U LCD TV 46 inch Class,...
I have a 46 inch Sharp model #LC-46SB54U. The
no_picture.jpg Part Number NOTE Description Product Note Substitute Part n/a Total Availability 0 Estimated Ship Date no longer available
Apr 27, 2010 | Sharp Televison & Video
Need owners manual for Sharp 46'lCD TV Mod.#LC-46SB54U
Owners manuel can be found at www.managemyhome.com right hand side--enter man and model #, to avoid having to sign up, right click and open in a new window when the pdf file pulls up. Its their I just checked.
Feb 24, 2010 | Sharp LC46SB54U 46 in. LCD TV
Sharp LC46SB54U 46 in. LCD TV Logo
2,265 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
