Question about Singer 3116 Simple
Singer 7444 trouble winding bobbin
I have a brand new Singer 7444 that won't wind the bobbins properly. After winding for a little while, the thread starts wrapping around the shaft under the bobbin. I then stop the process by releasing the pedal only to find that the thread that's on the bobbin is really messy. There are some loops of loose thread for example. Please help!!!!
    Scholar:
  • 69 Answers
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Posted on Mar 01, 2009
Having difficulty winding a bobbin, the thread goes across the "top" of the bobbin not inside....any help
Check that the bobbin is seated all the way down on the bobbin winder spool. However, the bobbin winder most likely needs a slight adjustment. I have several machines that tend to wind the thread either high or low on the bobbins so I just use a stiletto or pencil to raise and lower the thread as it winds. It helps to wind the bobbin at a slower speed--reduces stretch on the thread and allows you the ability to manually guide the thread onto the bobbin.
If you'd like to save wear & tear on your machine and be able to wind bobbins without unthreading the machine, look for a stand-alone bobbin winder (one brand is called "Sidewinder"). They cost around $30 and can be found online or at most fabric stores like JoAnn's. Just be sure to verify your bobbins will work on the winder--some Singer and other brand bobbins will not work.
Oct 19, 2016 | Sewing Machines
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
My Janome 3018 will not wind a nice tight bobbin. They are loose and spongy. This machine is brand new. I have double checked that it is threaded properly and the thread is in the correct place and
You are not exactly threading the machine when you wind the bobbin. So follow the directions for winding the bobbin, make sure the thread fits under the little revolving wheel, and make sure that the stitch part of the machine is disengaged.
Jan 01, 2015 | Janome Sewing Machines
Bobbin winder on singer 1725
Hai, Please change the new bobbin winder. Because bobbin winder and winding is very important.
Mar 20, 2014 | Singer 1725
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Singer Touchtronic 2000 - it will not wind a bobbin, I have found a manual onlin that says you just drop it in and push the foot feed and it will wind the bobbin but it doesn't do anything.
Take your thread that is under the presser foot and wind the thread on the tension disk. It is located right above and to the left of the presser foot. Then you will drop in the bobbin and slide the thread into the **** in the top of the bobbin. Push the little white tab in the bobbin slot all the way to the right until it is in the center of the bobbin. Then press the foot feed and the bobbin should wind.
Oct 24, 2010 | Singer Sewing Machines
How to thread bobbin on Singer Precision 7444 Sewing Machine
Have you got the manual?
If not, you can download one free from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in 7444 and click on search.
On the next page choose the free download option.
Pages 16 anfd 18 of the pdf file will tell you how to wind and thread the bobbin.
Hope this helps!
Sep 22, 2010 | Singer 7442 Mechanical Sewing Machine
Singer 7444 won't wind the bobbin... please help...
I guess the machine was defective, i trade it to the new one, and the bobbin worked fine...
Dec 26, 2008 | Singer 7444 Mechanical Sewing Machine
Singer 3116 Simple Logo
457 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
