Question about Proscan 32LB30QD 32 in. LCD TV
DVD input channel reads "no signal" when I try to play a DVD
I've had the Proscan 32LB30QD TV for only 4 months and now the built-in DVD player won't work. The discs go in and out of the player fine, there are no foreign objects stuck in it. I change the input on the TV to DVD and the screen just reads "no signal" and will not play the DVD.
  • middiesgurl Mar 03, 2009
    it seems like a good solution, but i just don't care enough to go through all that to fix it. I was trying to see if someone knew it was something simple like doing something the TV menu, but if it is that complicated i don't have the time and money to deal with it, so thanks for your input
  • Anonymous Mar 15, 2014
    It wont allow me to watch tv as I usually would be able to and it wont properly channel auto scan
  • 44 Answers
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Posted on Feb 28, 2009
  • javswr
    javswr Mar 01, 2009
    Why thanks for trying, for a rating? I do not see a response from you, does this mean you tried these solution?
  • javswr
    javswr Mar 01, 2009
    If it is not the above quick solution then it is your signal board is bad! this is not hard to replace. The signal board streams the all inputs to the lcd screen via the lcd controller! You can order a signal board from www.shopjimmy.com, you will need your brand and model number! Good luck, I hope this is helpful!!
I have the Proscan TV/DVD combo. The cable remote works for the TV, but NOT for the DVD player. And ever since I got cable, the Proscan remote no longer works (for tv or dvd.) Long story short, I have...
Did ever worked properly?Is it wright one for unit that you have,you can check that in your owner manual,if not I will go back to dealer and ask for replacment.
Aug 23, 2011 | Proscan 32LB30QD 32 in. LCD TV
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
I did not receive a manual with my tv. Can you send me a link to download one? proscan 32 lcd hdtv with built in dvd player. also the dvd player is skipping and I only have had the tv for 3 days? any...
I found the manual on-line, here is it's location;
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0807524.pdf
For the issue with the built in DVD player, I would first try different types of DVD's to see if there is a problem with one type in particular. Check the Manufacturers website to see if there is a firmware update for your model (may not be applicable for your model). Try to use a DVD cleaner disk that is appropriate for the DVD player since it operates in a vertical position rather than a horizontal one.
I hope this helps.
Cheers!
Mar 01, 2010 | Proscan 32LB30QD 32 in. LCD TV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
My remote stopped working and there isn't any sort of # on the remote to know whqat to order to replace it. I have the proscan 32" 720p model with built in DVD player.
its may be the bulb a the front part,, while presing up and down channel move bulb with finger if change channel its a lose solder joint on bulb,, if not bulb maybe bad
Aug 12, 2009 | Proscan 32LB30QD 32 in. LCD TV
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
Proscan 32LB30QD 32 in. LCD TV Logo
848 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
