Question about Proscan 42LA30H 42 in. LCD Television
I am trying to hook my DVD player up to it and it is not working?
  • 44 Answers
There are many ways to hook up a dvd player to a tv! Audio/video cables, s-video, and component.
Second you need to make sure the tv has the correct source selected. your tv will say on the back which number source you plugged your dvd into. make sure these are the same!!
Posted on Feb 28, 2009
Trying to hook DVD player to tv
CONNECTION THRUE USB WORKS.
May 22, 2013 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Hooking up this dvd player -- I have audio but no
TRY USING THE RED AS THE YELLOW AND THE YELLOW AS RED, THIS SHOULD MAKE ONE SIDE OF THE AUDIO NOT WORK AND THE VIDEO WORK. REPEAT WITH THE YELLOW/ WHITE. TRY DIFFERENT CORDS. TRY IT ON A DIFFERENT SYSTEM. YOU MAY HAVE KNOCKED SOMETHING LOOSE INSIDE IT.
Nov 16, 2009 | Pioneer DV-343 DVD Player
Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
Oct 17, 2009 | Televison & Video
No picture with a dvd in.
Couple things to try (I always try the simplest fixes first):
  • Try changing the input on the VCR
  • Double-check connections to make sure secure and in right spots
  • Hook the DVD player straight to TV and see if it works that way (Some copy protected DVDs don't like being run through recording devices.)
  • Reset dvd player - maybe a setting got changed (Output set to DVI for example)
Hopefully one of those will fix, if not, comment back and we'll dig deeper.
Apr 06, 2009 | Apex Digital AD-1110W DVD Player
Hook this dvd player to an hdtv
You are confused regarding how to connect your DVD player to your Samsung TV. There is no such thing as "5 composit hookups". Your DVD player most likely has right audio (commonly red), left audio (commonly white), and video (commonly yellow) outputs which should be connected to corresponding inputs on the rear of your TV.
Dec 15, 2017 | GE 5803P Multi-disc DVD Player
Dvd/tv hook up
plug in dvd player direct to tv yello red white for sound into a input ok vidieo one ect then change input on tv to that input ch2 hit ch down to go into inputs
Feb 10, 2008 | Sanyo DS31590 31" TV
Dora Tv & Dvd
How are you connecting the two? A/V input jacks? Are you selecting that input (line 1, line 2, etc...)?
Sep 12, 2007 | Emerson Dora The Explorer DVD Player
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
Proscan 42LA30H 42 in. LCD Television Logo
132 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
