Question about Whirlpool Pearl AIGO True Bathtub with Back Massage - 103556-100
Need to know how to access the motor on my whirlpool tub
I have a whirlpool tub that was installed in 1991 when my home was built. Unfortunately, I do not know the make/model. I can no longer get the jets to turn on. I have a panel on the front with 2 very small screws. I am just wanting to know if I undo those two screws should I be able to pull that front panel off. I know that the motor sits behind there because I saw it as it was being installed. I just don't want to damage anything.
Yes you should have an access panel to the pump somewhere. It sounds like you have already found it. You may want to get a qualified electrician involved. There are at least three sources of possible failure. The first and least expensive is that the motor tripped the ground fault interrupter and just needs to be reset. The second is that the switch has gone bad. The third and most expensive is that the pump is broken and needs to be replaced.
Posted on Mar 01, 2009
How can I find the manufacturers name on jetted tub when i can't get access to the motor?
Normally when you install a jet tub you should have an access panel to get at the motor for repair or replacement,I doubt if the name of the manufacturer would be on the motor,as they are probably made by a different company,I have a Maax jet tub but the motor is made by Balboa...try searching manufacturers for the same style of tub as yours!!
Aug 30, 2013 | Home
Replacing defective pump switch
The air switch on a bathtub is located in the bath pump. Your description sounds like you are asking about the air button which is located on the top lip of the bath tub.
Click on those links to see your options for whichever part you need.
Rod
U S Parts Center
888-521-6183
Mar 17, 2013 | Home
Jetted tub is on 2nd floor over kitchen. when jets are on water comes thru kitchen light fixture! Help!
First find access to tub,by code there needs to be access to pump motor,either built into wall or various tubs front skirt is removeable.Fill tub and run to visibly see leak,sounds like bearing assembly gaskets are leaking on pump,could possibly be a jet connection,but if it only does while running its the pump or motor assembly.Hope that helps,in the future make sure water is always above suction intakes or can lead to premature burnout of pump
Jan 26, 2011 | Home
Where can I buy just the brass trim on the jet for my whirlpool tub (aker)?
The trim for any brand whirlpool (w/p) tub must be ordered from that specific tub manufacturer. They will need to know exactly what your particular model is.
The model of your w/p tub, and serial number, is most often, but not always, located on the motor end of your unit but not on the motor itself. Access to this end of the tub, if installed to code, should get you the information you need, otherwise you are out of options'
Jun 03, 2010 | Whirlpool Royal A-909 Bathtub
Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
Jun 04, 2009 | American Standard 2770.018w.020 Cadet...
Bathtub jets don't work
The first step is to determine if the pump is working or not. Is there an external switch on the wall next to the tub? Can you hear the pump humming underneath? CHeck your fuse box to see if a breaker has been tripped.
I know those sound easy, but its always best to check the simple things first.
If you don't hear the pump running and its not the breaker, it has now become a bit more difficult project but still something any competent home owner can fix.
YOu have to access the electrical plug on the tub. It is 110v outlet that is underneath the tub on the same end as the switch or opposite the drain.
You needs to access the tub through the wall from the other side and check out that electrical connection. Could just be the the GFI switch thrown. If not then it cold be a bad pump or broken impeller.
For help if that's the case just post again as it is a length process.
Apr 15, 2009 | Home
Jets not working
i have seen this in the past, a ground fault electrical outlet on the inside of a roman tub,if you have a 2 story house look for access panel on or by tub. otherwise you have to remove tile or other to access motor, you probably need a step too anyways
Mar 12, 2009 | Eljer San Antonio Acrylic Whirlpool -...
Jetted bath tub has stopped working - motor hums, will not run
The shaft on the motor should spin freely as should the impeller when attached to the pump. If there is drag on either, replace the pump and motor assembly. I have worked on jetted tubs for the past 5 years, I have seen seized pumps more than once.
Mar 06, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Whirlpool corner tub not working
you wiil need to check 2 things.First you will need to check the motor.Their should be a reset switch on the motor.also attached to the power buuton is ablack thin hose if this hose came off the switch or motor than the motor wont come on.Look around for an access door .If thier is acloset in an adjoining room you might find it thier.
Jan 23, 2009 | Whirlpool 2 Person Corner Air Tub By...
Whirlpool does not work
I think it is manufatured by Nordic.?
this link should help you will all the installation use and repair.
http://www.nordichottubs.com/owner-center/default.aspx
let me know if this is not the one.
please post additional comments in this thread.
Nov 11, 2008 | Whirlpool Royal A-909 Bathtub
Whirlpool Pearl AIGO True  Bathtub with Back Massage - 103556-100 Logo
623 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
