Question about NAD T743 Receiver
Nad 743 shuts off at -14db vol. Why?
I have 5 speakers hooked up. Is it anything in the setting of tone defeat?
Please help.
thnx
greg
  • Anonymous Apr 03, 2009
    my nad T743 last month started turning off when I would try to increase the volume from -16 to -19 db in a surround mode. Upon getting power back which would only last for 5 min at best I noticed the device selection had changed and was frozen not allowing me to go back to my setting.  I took it to the dealer.  They said for $350 they could fix it.  However, they said they did not know what was causing the problem.  I am on my way to retrieve my NAD.  I will attempt to find someone else to do the repair.
    This is sad.  I have had several NAD components over the last 20 or so years.  Never had a problem before.  I'm afraid the NAD reputation matters no more to them.
  • janus11 May 17, 2009
    mine does the same, when it's warm (more then 30 minutes on), control processor turns mad. A reset (video 6 + source down) recovers normal service... until next crash... It seems related to temperature, with a fan on top of it it works 2 hours while without fan sure I loose it after on hour max.
Mine got fixed by replacing the front panel PCB with control processor. Only 350€...
Posted on May 03, 2010
The amplifier has occasionally shut itself off due to overheating for the last 3 years (I've had it since 2005). But now it continuously shuts itself off and simly won' start up anymore. Does it need a...
They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
A heat sink is just a finned heat-conducting device for radiating heat to the air which should be flowing freely through the unit's ventilation holes. It can't break in normal use. But it CAN get clogged with dust reducing its effectiveness.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T743-Receivers-manual/id/8043bh636/t/2/
Page 6
"Choose a location that is well ventilated (with at least several inches to both sides and behind), and that will provide a clear line of sight, within 25 feet/8 meters, between the receiver's front panel and your primary listening/viewing position-this will ensure reliable infrared remote control communications. The T 743 generates a modest amount of heat, but nothing that should trouble adjacent components. It is perfectly possible to stack the T 743 atop other components, but the reverse usually should be avoided. Nonetheless, it is generally preferable that the T 743 stand alone. It is especially important that sufficient ventilation be provided; if you are contemplating locating the T 743 within a cabinet or other furniture, consult your NAD audio/video specialist for advice on providing adequate airflow."
If you're lucky, you haven't finally toasted it. If you have, a hands on tech will need to sniff sround (literally) to find the dead component(s).
Mar 06, 2011 | NAD T743 Receiver
NAD T763 - i turned it on and all the lights on the display lit up and stay on. It doesn't work at all !! Any suggestions?
Have you tried doing a factory reset?
1. With unit powered ON, press the VIDEO and TONE DEFEAT buttons.
2. Display will show "AH RESET DONE".
3. Power off (from rear panel switch) and back on.
Jan 29, 2011 | NAD T763 Receiver
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
Creative inspire 4.1 volume control got wet
sir i want creative 4.1 volume control wire please
pavanpralhad@gmail.com
Sep 30, 2009 | Creative Labs Inspire 4400 Computer...
How do I adjust the trebble on my Denon Receiver?
go to sound parameter in your parameter menu under the setup. There should be a tone control option, when there you can adjust the bass and treble by a variable decibel range. the range is -14db to 14db.
Jul 07, 2009 | Denon AVR588 Receiver
Power on T743
Just had my t753 in bits... sounds like its overheating to me. Check that the fans on the bottom still turn and aren't clogged up with dust. Make sure that it has plenty of ventilation.
hmm, also try unplugging everything and leaving it on and see if it still freezes? ie check you're cabling is ok, there are no shorts from bare speaker wires etc...
Could try resetting it too? (in each case hold the buttons for 5 seconds then release)
- Firmware version: hold video 6 and tone control
- Reset DSP: video6 + tone defeat
- Reset completely: video6 + right source button (this will wipe all settings - hold for 5 seconds, release and then unplug from the wall or turn off with the rear power switch)
Nov 23, 2008 | NAD T743 Receiver
Nad 214 amp
problem is- intermittent speaker relay. You can cleaned contacts or better upgrade relay to better one (sealed)  Dariusz
Jan 03, 2008 | NAD 712
Outdoor speaker hook-up
Go into the manual setup on the GUI then go to the zone 2 and zone 3 setup. If you are using only the power from the receiver to power the speakers, make sure the setting is for Zone 3 amp "INT" if you still have no volume, on the front of the receiver look at the display, make sure "zone 3" is lit up then use the small remote and turn up the vol. if it's on you will see "zone 3 vol" and the bar going up it should be ok. if it says "fixed" it thinks you have an external volume control, if you do, make sure it's "on" at about 12 o'clock and test. If not, you need to switch it in the on screen "menu" or "GUI" button, follow to zone 2 & 3 vol control and make sure it is set to variable. If you still have no vol post a comment and we can dig further. Hope this helps
Aug 18, 2007 | Yamaha RX-V2600 Receiver
Nad 302 amplifier
sounds to me that the vol control has lost its earth end connection So yes its a problem with the dial control You couls try some contact cleaner But better still lift of the lid and base if possible while the amplifier is not plugged into the power socket and see if you have a dry joints around the vol control pot regards Trev
Mar 14, 2007 | NAD CI9060 Amplifier
NAD T743 Receiver Logo
512 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
