Question about Dryers
Maytag dryer mod #mde600ayw only makes a humming noise when start switch pushed will not turn.
  • 70 Answers
A hum with a burning smell means the motor winding has failed.
you can try this: open the door and hold in the door switch, have another person hold the start button. You manually roate the drum by grabbing a fin and moveit while the unit is humming.IF the dryer starts, you need a motor.
Good Luck!
Posted on Mar 01, 2009
Admiril Electric dryer Mod. # ADE7005AYW. For the
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 31, 2011 | Maytag Dryers
When I push the start button on the dryer it makes a hum noise and did not start. It makes a lot of electrical consumption because the lights of the house decrease their intensity when I push the start...
heatman101
a
Sep 28, 2010 | Maytag Dryers
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
heatman101
Sep 25, 2010 | Maytag Dryers
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Dryer will not start
Check your electric going to the dryer to make sure you have power to the machine.
Then check to make sure you motor is not running, sometimes with a broken belt the motor is almost silent when running.
If the motor is not running then your problem may be the start switch, timer switch, or the motor could be faulty.
One thing you can try is to make sure your power is off to the machine, reach in and turn the drum by hand 1/4-1/2 turn. Turn back on the power and try to push the start switch again. Sometimes motors will get dead zones in them and this will move it out of the dead zone.
I hope this helps
Oct 01, 2009 | Maytag MED5600TQ Electric Dryer
Dryer quit working, When I turn the timer to desired cycle and push start it makes a Humming noise but does not tumble?
The humming noise is more than likely your drive motor. Replace your drive motor.
Sep 14, 2009 | Maytag Dryers
Dryer does not start. if you push on the start button you can hear a small hum from the area of the timer, otherwise nothing. door switch seems to be working
one  make sure you advance the timer into the heating area of the cycle if you did that and turned it on and still humming you  have a bad motor
Jun 07, 2009 | Maytag SDE3606A Electric Dryer
Maytag Neptune Dryer Model # MDE3000AYW
Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
Sep 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
251 people viewed this question
Top Dryers Experts
