Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis 2060 --loose pulley,belt slips off.
Has new motor and new pulley/wheel. I noticed that the old pulley was 'stripped' where it fits onto the drum, so bought a new one, which fit snugly with no play. Now, several weeks later, the new pulley is also stripped in the same way, and belt is back to slipping off frequently, even after I tighten down the pulley bolt. I have watched it spin and belt does not seem to be the problem. Machine seems to have low tolerance for unbalanced loads. Could it be a bad load balance sensor, and the unbalanced loads that loosen the pulley bolt, causing the belt to slip off? Any other ideas?
  • 236 Answers
SOURCE: Is used Bosch Axxis WFL 2060 with door replaced a safe bet
not a bad price (poss a little bit high) but i would want to see it running on a warm wash first.
Posted on Mar 18, 2009
uniman9310
  • 190 Answers
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
Posted on Jun 03, 2009
barkencoa
  • 3463 Answers
SOURCE: can't fit a belt to the Bosch washing machine. Is
There is no provision made for adjusting belt.
With the rear panel removed, fit the belt round the motor pulley first, and slowly feed it round the drum pulley, at the same time turning the pulley by hand..
Watch your fingers, it will be tight.
You will find it easier to do if you lean the washer away from you, this will give you more room to get your hands in..
Hope this helps you.
Posted on Dec 03, 2009
smartr10U
  • 1305 Answers
SOURCE: Replacement front door for a Bosch Axxis WLF 2060
Visit repairclinic.com. Enter your model number in the search box and it should call up the parts you need.You'll be able to see actual photos of the parts on size grids so you can compare with what your's look like.
I did a quick search and it looks like you're looking for part number 1046685 .
Posted on Dec 14, 2009
  • 353 Answers
SOURCE: Bosch Axxis 2060 clothes remain soaked after wash cycle, have to
Clean your filter
Posted on Jun 11, 2010
Drum does not spin for any cycle originally would not spin at 1100
This sounds very much like the belt COULD be slipping OR a motor problem. Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. Ours for a Bosch cost GBP250- but it's your choice!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 06, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Motor humming drum stopped. pulley or belt perhaps?
Hello & Welcome to FixYa
The problem is with the motor itself that is bad and needs replacement. I don't think it is the belt that is bad causing this issue, if you want you can take it apart and check the belt. However, the hum sound itself indicates that the motor is bad and recommended repair is replacing the motor. Please get back to me if you have any other questions.
Kevin
Jan 17, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Washer, not spinning. Belt looks ok, front filter removed and cleaned. Previous answers say motor brushes, how are these looked at? Access through the back, would prefer not to take...
IF THERE IS BLACK DUST UNDER THE MOTOR IT IS USUALL DEAD. YOU CAN REMOVE MOTOR FROM THE BACK I HAVE DON IT. YOU NEED A METER TO CHECK THE MOTOR. I CAN HELP.
Apr 25, 2010 | Bosch Axxis WFL 2060 Front Load Washer
DRUM DOES NOT URN. MOTOR RUNS
Check the belt or the bolt securing the wheel attached to the drum
Nov 26, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Remove bosch axxis 2060 washer motor
May 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Mar 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Drum makes loud whinning noise when spinning at high rpms.
Remove drive belt.and turn drum by hand, if it feels rough or sounds noisy, then the main drum bearings have failed., also check that the main drum pulley is not loose. If you think it is the bearings, then it is quite an expensive repair.
Plz rate this solution.Thanks.
Dec 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Won't spin - belt fine!
I had the same problem with my Bosch 2060, which is almost 6yrs old. After opening the back of the washer and inspecting, belt looked good and not loose. Spending several hrs on net looking for postings, most thinking replacement of motor brushes is the solution. Someone posted that the connector on the right side of motor (located under the tub) to the right side could be loose. I pushed on the connector to make sure it was tight. Powered up and went to spin cycle and was greatly relieved that washer began to spin. Thanks for whoever posted this simple fix.
Jan 07, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2060 front load
bad belt bad motor bad motor control unit bad ccu or wires un plugged if you can hear the motor rum check belt one time i had a nail jamming the tub through the holes in it like to never found it in that stainless steel tub lol
Dec 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
