Question about Apple iPod MA446LL/A MP3 Player
My ipod had a low battery, so i charged i overnight as usual, when i got up the next day it said fully charged and when i unplugged it from the usb, it shut off and would not come back on. ive tried to reset it, and when i plug it into the stereo to charge the apple comes up but nothing else?
  • kirkmiller May 11, 2010
    What model Ipod do you have? Have you tried resetting your Ipod to its factory default settings with the Ipod reset tool?
    President:
  • Apple Master
  • 688 Answers
I think you may just have a dead battery. The batteries on the iPod last a long time but they do go bad after years of use.
Occasionally a battery will die almost immediately without warning.
Also, use an AC wall charger to verify it's actually being charged.
USB cables work for transferring music, but are a weak source for charging. If you need a battery click here or check ebay they are fairly inexpensive to replace.
Posted on Mar 02, 2009
Battery life draining overnight
Try disabling everything you can through the software, if not possible, unplug them. Then plug one in at a time and leave it overnight. If its OK in the morning, plug in the next item, and so on. Make sure battery is fully charged between each test. When the unit discharges overnight again, the last item you reconnected befroe it discharged is the one causing the voltage drain.
Aug 20, 2014 | Toshiba NB520 Netbook
Tip
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
on Aug 09, 2011 | Apple iPod touch
I have connected my nanomax ipod to the computer and it is not charging.how should i charge it?
Good morning, afternoon, evening or night; whatever time you are viewing this solution post. Thank you for choosing FixYa to solve your problem. So you have connected your Nanomax iPod to the computer and it's not charging like it's supposed to, and you want to know how you should charge it properly? There are two ways you can charge the battery - charging via your Dock Connector to USB Cable, or the Apple USB Power Adapter (which is sold separately). Here are the step by step instructions to charging your and Nanomax.
Using the Dock Connector to USB Cable
  1. Using your Dock Connector to USB Cable, plug the dock connector end to your iPod and plug the USB end to your computer. Make sure the computer you are using has a USB 2.0 port (check your computer's technical specifications to see if it's USB 2.0 certified). Most USB ports on the keyboards of laptops do not provide enough power to perform charging activities. If you have a Docking Station, plug the docking connector into the station and placed the iPod in the station as well.
  2. Make sure your computer is fully awake and not asleep (meaning in sleep mode).
  3. A fully charged battery takes 3 hours to complete. An 80% charged battery takes an hour and 30 minutes. The battery is charging when it shows the charging icon (a battery not fully shaded in green, with a lightning bolt).The battery is done charging when the "fully charged" icon shows (a green-shaded battery with a 2-prong plug showing).
  4. When you are done, disconnect the cable from your computer.
Using the Apple USB Power Adapter
  1. Connect the Alternating Current (AC) Plug Adapter with the power adapter (if connected already, skip this step).
  2. Using your Dock Connector to USB Cable, connect the dock connector end to your iPod and the USB end to the power adapter.
  3. Plug the power adapter into a polarized wall outlet or surge protector outlet.
I think you connected everything correctly, but the USB port on your computer did not have enough power to charge your battery. If that's the case, you will have to find a computer that has a USB 2.0 port on it (like a desktop PC or MAC, or a car adapter charging device) and connect to it, or use the USB Power Adapter (sold seperately). I think this pretty much answers your question. I hope this benefits you the best way possible. Once again, thank you for choosing Fixya as your one-stop solution spot for your problems. Have a good day, evening or night; whatever time you are viewing this, and visit us again the next you need assistance troubleshooting.
Apr 27, 2011 | Audio Players & Recorders
How will be i identify it is fully charged battery i charged for 45 minites.But the battery will not be fully charged. please send me the solution for this problems
If using usb charger use usb port on back of desktop, not data port in front, also most laptops do not have fully powered usb ports due to battery consumption. The wall charger, or a usb charger plugged into a usb/ac adapter (like included with ipods and kindles or sold seperately) is your best bet for reliable charge.
Charging unit should have a light on it.
When charger is plugged into power source and not helicopter, the light will show you {#1} what it looks like when battery is fully charged. Typically this is steady on, and usually red. (sometimes green) When you connect helicopter to charger, the light will change (usually goes dark) to signify it is charging {#2}. When light comes on fully (or completely returns to #1) then charging is done. (Note: charging using a laptop usb or a front side data port usb can take several hours.) Watch the light on charging unit when you unplug helicopter, if it gets brighter, helicopter is not charged, plug it back in. Make sure to let battery cool for 10 minutes after every charge and 10 minutes after every flight, and never run battery all the way down. As soon as you can't maintain altitude, land and power off. Fully draining a Li/Po battery weakens it's ability to hold a charge and can ruin it.
If all else fails, replacement batteries are available from Amazon and many others, they are cheap (around 5$) and very easy to install with no soldering and just a small screwdriver.
Hope this helps
r
Dec 31, 2010 | SYMA Toys industrial Syma S032 Ready to...
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    Sansa clip won't charge fully
    If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
    Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
    Does not charge
    Well, it sounds as though your battery is shot. However, before completely giving up i would restore the ipod in itunes and then let it fully charge. After it says "fully" charged, disconnect and test. if it still has no charge, reset it by holding down both the menu and center buttons until you see an apple appear on the screen. If after these steps it still does not charge i would check into getting a new battery either through iPodbatterydepot.com or by calling apple tech support at 1-800-APL-CARE (1-800-275-2273) Good luck
    Apr 19, 2009 | Apple iPod nano
    When I charge my iPod Nano it charges fine but instead of turning off or ... it will turn off but in about 2 seconds it goes to the "Charged"
    You need a new battery for your iPod. you can view a free instructional video on battery replacement at the first web address posted below. the second one is a cheap site I found for purchasing iPod parts.
    http://fixyouripod.weebly.com/
    http://www.ifixit.com/
    Mar 13, 2009 | Apple iPod nano
    My Ipod mini always saying battery low
    sound like the battery is attacking up. You can buy and replace the battery. That should fix your problem. My ipod mini did the samething.
    Jun 27, 2008 | Apple Mini IPod
    Apple iPod MA446LL/A MP3 Player Logo
    108 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
