Question about Garmin nuvi 200W GPS Receiver
Tried to upgrade maps from dvd, computer says gps needed 37megs more of space. deleted map routing file to get more space computer still says same thing not enough space
  • 1 more comment
  • jerry_newton Feb 28, 2009
    I deleted enough with the one file of maps
    the one file of map routing should have given
    me the space
  • jerry_newton Mar 01, 2009
    by deleting some more files your solution worked.
    thanks
  • 52 Answers
If you reset to factory settings, you can update the maps. You could also buy a memory stick.
Posted on Feb 28, 2009
    Scholar:
  • 85 Answers
My Garmin nuvi or what ever its called is telling me the memory is full I dont know how to free up space,
1)
you can do a system reset, which should clear the memory, it will basically return it to factory settings, so you'll lose favorites, recent destinations, etc.
Turn the unit off. Hold your thumb pressing against the bottom right of the screen. Hold it there while turning the unit on. Say "yes" when asked. That should do it.
2)1. Open Maintenance Mode by pressing the lower left-hand corner of the touch screen while unit is being turned on.
2. When the "Do you really want to start up in maintenance mode?" prompts, press the "Yes" button.
3. Log on password if necessary.
4. Press the "Clear user data".
5. When the "Do you really want to erase all user data?" prompts, press the "Yes" button.
6. Nuvi restarts.
3)Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
Step 3. Select the yes button.
Step 4. Enter your PIN if enabled.
Step 5. Main Maintenance Mode screen should have 4 selections:
System information
View Diagnostics
Clear User data
Clear Waypoints
Step 6. Choose "Clear Waypoints". After some time the unit should reboot.
click this link for more help
http://www.sciuridae.co.uk/garmin_update_guide.htm
  • Garmin Master
  • 6,487 Answers
If you can free up some more spaces on yur unit that will be better and try it again .........
    Sergeant:
  • 326 Answers
Reinstall the files again in your garmin and then try as its not having required space in it.
  • Garmin Master
  • 13,433 Answers
Try deleteing some old maps and files from the storage card and also from the device.
Nuvi 610 memory is full what can i do
Ok, so you want to upgrade the map on your Nuvi. You connect your Nuvi to the PC, you go to the Garmin website and your told that you don't have enough memory left on your Nuvi for the upgrade.
What can you do?
It seems every year, the map file gets larger and requires more free space on your Nuvi.
Not all Nuvi's are created alike. Some Nuvi's have more memory than others. Some Nuvi's, like the lower-end 2xx/2xxW series have such a limited memory, that they can only hold the lower 48 states map.
So, if your Nuvi has adequate storage space (1.6GB required for 2014) but you can't upgrade to a newer map due to a "not enough memory space" warning, there are a few things you can try to free up memory.
1. Delete any MP3's or photos that you may have added.
2. Delete any unused voices that you don't need.
3. Delete any unused vehicles that you don't need.
4. Delete any screen snapshots that you may taken with your Nuvi.
5. Delete the GUPDATE.GCD file.
6. Delete the PDF user manual.
You can always copy these files over to a folder on your PC before you delete them from your Nuvi.
Don't delete any files that you don't know what they are, as they could affect the normal operation of your Nuvi.
If you don't want to clear up free memory on your Nuvi, you may try loading the map onto a SD card.
Feb 01, 2014 | Garmin Nuvi 660 GPS Receiver
My GPS says " no detailed maps found that support routing. The Nuvi cannot be used without them." Tried resetting and no change
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Sep 25, 2010 | Garmin nuvi 205W GPS Receiver
My Garmin will not bring up eny maps . It just brings up no detailed maps found that support routing.
To retrieve your unlock codes you must first register your satnav if you haven’t already done so.
To register
· Connect the satnav to your computer.
· Go to www.garmin.com and select your country
· Click on “myGarmin”
· Click on “Register Your Garmin Product” and follow the prompts
You’ll be asked to create a username and password. Write them down and keep them safe as you’ll need them anytime you want to update your maps.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 16, 2010 | Garmin nuvi 350 GPS Receiver
Unit has lost detailed maps that support routing. Whats wrong? Nuvi cannot be used. Will not go beyond problem screen.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 15, 2010 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 205 keeps telling my " No detailed maps found that support routing. The nuvi cannot be used without them."
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device at the bottom of this solution
To registe;
  • · Connect the satnav to your computer.
  • · Click on “myGarmin”
  • · Click on “Register Your Garmin Product” and follow the prompts
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 13, 2010 | Garmin nuvi 205 GPS Receiver
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instructions above for their U.S. mapping and then create another unlock file for their European maps:
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 10, 2010 | Garmin nuvi 205W GPS Receiver
I get the error no detailed maps found that support routing. Hwow Do I fix this?
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device in the botton paragraph
  1. Go to www.garmin.com and log into MyGarmin. If you don't have a MyGarmin account you'll need to register your satnav to get one. To register click on MyGarmin and then on Register your garmin product. Follow the prompts.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 06, 2010 | Garmin nuvi 260W GPS Receiver
Just updated the software with webupdate for windows_242 from garmin website succesfully. ''No detailed maps found that support routing. The street pilot cannot be used without them. comes up when...
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
To check that the map has not been disabled. Press Tools, then press Settings, then press Map, then press Map Info and see if your map has a tick to show it's selected. If not press the map name to select it. It should then work.
Jul 27, 2010 | Garmin GPS
Xls 330s tom tom no map
Connect the GPS to the computer. Forget the Tom Tom home for a little while. Use the windows explorer or file manager. Check whether the TomTom is shown as a drive. If yes, Right click on it. Then click properties. Check how much is the used space and how much is the free space. If you see that there is only about 50MB free space, that could be the reason. Tomtom update do not seem to overwrite the map file. Now check the properties of the new map file. It may be approximately around 1.3 GB to 1.5 GB. Since I do not have a Europe map I do not have the correct size. If the new map size is anything bigger than the available space on your GPS drive, then the update will not complete and crash. Solution. Copy the existing map (North American map has a name something like USA_Canada_and_Mexico_P) folder to your computer. Once you have a secure copy, delete this map folder from your GPS drive. You will now see that you have approximately 1.7GB of free space. copy the map folder from your CD to your GPS drive. Once copying is complete, safely remove the GPS from USB port. Restart and try it out on a known route to check efficiency.
Apr 15, 2010 | Tomtom XL 330 Car GPS Receiver
NO DETAILED MAPS FOUND TO SUPPORT ROUTING
You need to unlock the unit. I had the same problem with one that I have. Try this:
The No Detailed Maps Found That Support Routing message could be due to the following reasons:
To determine the cause of the message, touch the screen until the message No Detailed Maps Found That Support Routing disappears.
  • If you get a Can't Unlock Maps message following this error remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file.
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device.
  1. Log into your myGarmin account: https://my.garmin.com/mygarmin/customers/myGarminHome.faces
  2. Select myMaps.
  3. Select Manage Maps.
  4. Select the device from the drop down menu.
  5. The unlock code is located under the "Maps installed on this device" section.
Creating an unlock code file:
  1. Plug your Garmin device into the USB port.
  2. Double-Click on My Computer or Computer located on the desktop.
  3. Double-Click on the Garmin or nüvi drive.
  4. Double-Click on the Garmin folder.
  5. Right-Click in a blank space in this window.
  6. Move your mouse over the word New.
  7. Select Text Document.
  8. Press Enter / Return on your keyboard.
  9. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad.
  10. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces before or after.
  11. Select File.
  12. Select Save As.
  13. Change the Save As Type to All Files.
  14. Type gmapprom.unl in all lower-case letters for the File name.
  15. Select Save.
  16. Close the Notepad window.
  17. Delete the New Text Document file.
  18. Disconnect the GPS device from your computer.
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instuctions above for their U.S. mapping and then create another unlock file for their European maps:
  10. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces before or after.
  11. Select File.
  12. Select Save As.
  14. Type gmapprom1.unl in all lower-case letters for the File name.
  15. Select Save.
  1. Touch the wrench icon on the Where to/View map screen.
  2. Touch Settings.
  3. Touch Map.
  4. Touch Map Info.
  5. Select the checkbox next to the maps to be enabled on the device.
If you continue to receive the No Detailed Maps Found That Support Routing message after completing these steps please contact Garmin Support: http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Feb 03, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
