You had to plug it in the charger for a while and then you hel the power button for more than a minute
if it not work hold power button and volume up for 20 sec.
If the battery is to far below the minimum operating voltage most wall chargers can not charge the battery. Test the voltage of the battery and make sure it is charged to the minimum operating voltage (usually around 3.6v). If its too low you need to bump charge the battery with a power supply.
I replaced the battery and the charging port / ribbon cable and it still will not show that it's charging OR turn on. Is there anyone out here that could possibly give me some other ideas what could be wrong with it ? I even ordered a new charging cable that plugs into the factory wall charger and still nothing
SOURCE: samsung galaxy tab 2 10.1 wgxa model GT-P5113 is frozen
Hold the power button down for up to 15 seconds. This should hard reset it. Not to be confused with erasing data.
SOURCE: Galaxy tab won't charge or
Hold the up and down button and Power on for10 seconds and that should cause the Galaxy 3 to reset. Work for me.
SOURCE: My Samsung Galaxy Tab says
You're in download mode. If you're not connected to USB, then pull the battery and plug it back in. This will restart your device.
SOURCE: I just got my galaxy tab 7 on Monday. Turned on
Welcome to Fixya
Try to insert the SDCARD to a computer that has a card reader and see ifthe computer will detect the SDcard. If the computer can detect the card, then the card slot of your galaxy tab has a problem.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: My Galaxy tab just froze
Detailed instructions are here to reset your tab without pulling the battery: http://www.mojocode.com/content/samsung-galaxy-tablet-101s-wont-boot
