Question about Ld ASUS P5LD2 DELUXE INTEL 945P CHIPSET SERIAL ATA300 ATX FORM FACTOR 2xPCI-E(X16)/1xPCI-E(X1)/3xPCI/4x... (MBP5LD2S) Motherboard
Computer doesnt boot
I have a Asus p5ld2 deluxe mother board with intel Pentium Dual Core processor. the machine starts without any memory or graphics card. but when I put the grahics card or the memory it doenst boot and it stops. so can any one of you suggest what I can do to get this running again.
thanks
Krishna
  • hkmattaparti Mar 01, 2009
    thanks guys for your suggestions. the memory card and graphic card used to work upto now. I thuahgt that the graphics card is a problem. so I just trashsed that. but I have 4 1 gb memory cards, and all of them are not working. so I would suspect if anyone of them should atleast work. so I dont know whether it is mother board or memory problem now.
    the mother board is having a video out built in so I am not worried about the video card but the memory card as these are not built in but external to the mother board.
  • Tim Crosslin May 11, 2010
    Are you adding memory and the video card? Or was it originally installed on this board?
  • 59 Answers
Okay here is a link to a free memory tester from Microsoft. I have used it in the past and it is a great tester. If all pass this test then the problem is the motherboard. Hope this helps.
http://oca.microsoft.com/en/windiag.asp
Posted on Mar 01, 2009
  • 32 Answers
Both cards are defective.if upon inserting them it wont work then it tells you thats the problem. there not expensive new memory cards..id try that first..steve
Does my pc that is intel pentium dual core e2140 @1.60ghz have pci express?? Can this processor support graphic cards like nvidea 9500gt 1 gb??? or any other cards???? plse reply fast
Graphics support is mainly determine by the mother board. based on the processor you have that mother board should be equipped with a PCI express slot. in that case YES it is Supported. make shure you follow installation instructions and check that you have at least the minimum power supply requirements for the card 380W or above.
Best of luck
Jun 01, 2011 | Intel Pentium Dual Core E2140 / 1.6 GHz...
What mother board should is best for use on this video editing,engineering,and games with better graphics and can also work for more than 18 hours?
The best computer mainboard, would be either an AMD AM3 mainboard made by ASUS. For example ASUS Crosshair IV Formula or ASUS M4A88TD-V EVO/USB3. Or an Intel computer mainboard. ASUS Socket 1156/1155/1366.
Your Pentium Dual-Core E2180 2.0Ghz on the LGA775 socket is not good for Games or video.
The best thing to do is to purchase a new computer system.
Use either AMD Phenom 2 or Intel I5 or I7.
Use a good mainboard as above.
Use a good Graphics card, Nvidia 400 series.
Keep all the components running cool with a case that you like and has place for lots of 120mm or 140mm fans.
Use DDR3 RAM 1333MHz or higher.
Use Cooler Master or Corsair Power Supply.
If however you are wanting a good mainboard to be used with your Pentium Dual-Core E2180 2.0Ghz on the LGA775 socket then click here.
ASUS is very good, all these mainboard on the LGA775 socket are good, choose one that looks good to you and one that you can afford.
Thanking you kindly
damnor01
Feb 02, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
I want to know that did intel d945gcr supports core 2 duo processor...............plz
This mother board will work if we have a compatible processor like Intel Core2 Duo, Intel Pentium D, Intel Pentium 4.But the processor should be greater than 2.99Ghz if the processor is less than this then it will to work.Dual core processor means there will be two processors working
The detailed specifications of the new Intel D945GCCR Motherboard are:
  • Form Factor:MicroATX
  • Processor:Intel Core 2 Duo, Intel Pentium D, Intel Pentium 4 and Celeron D processors in the LGA775 package
  • Supported System Bus:800 MHz / 533MHz
  • Chipset:Intel 945GC Express Chipset with ICH
  • Supports Hyper-Threading Technology
  • Graphics:Intel Graphics Media Accelerator 950
  • Graphics Connector:One PCI Express* x16 graphics connector
  • Memory Support:Dual-channel DDR2 533 / 400 MHz, 2 DIMM slots (2GB Max)
  • Expansion Slots:Two PCI connectors
  • One PCI Express* x1 connector
  • Audio:Intel High Definition Audio with 5.1 Surround Sound
  • USB Ports:Eight Hi-Speed USB 2.0 ports (4 back / 4 front)
  • Storage One IDE (ATA 100/66/33)
  • Four Serial ATA ports (3.0 Gb/s)
  • On-Board LAN:Intel PRO 10/100 Network connection
  • Warranty:3 year limited warranty
Hope that solve your problem!
Thanks for using Fixya!
Dec 15, 2010 | Intel D945GCCR Motherboard
Mother board
Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
Pros: None noted, given available product data.
Cons: None noted, given available product data.
Suitability: A compact motherboard, suited for small computers.
Value: In view of its inexpensive price, this motherboard has great features for the money.
Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
XFXg31
General
  • Product type (AE) Motherboard
  • Form factor Micro ATX
  • Width 9.6 in
  • Depth 7.6 in
  • Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
  • 64-bit Processor Compatibility Yes
  • Mainboard processor socket LGA775 Socket
  • Mainboard / Multi-Core Support Dual-Core / Quad-core
  • Chipset Type Intel G31 Express
  • Data bus speed 1333.0 MHz
  • Storage key information Serial ATA-300 , eSATA port
  • Power connectors 24-pin main power connector , 4-pin ATX12V connector
  • Processor
  • Installed Qty (Max Supported) 0.0 ( 1.0 )
  • Memory
  • Cache Memory Type None
  • Supported RAM Technology DDR2 SDRAM
  • RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
  • Supported RAM Speed PC2-6400
  • Video
  • Graphics Controller Intel GMA 3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Audio
  • Audio Output Sound card
  • Sound Output Mode 5.1 channel surround
  • Audio output compliant standards High Definition Audio
  • Telecom / Networking
  • Modem None
  • Networking Network adapter - Ethernet , - Fast Ethernet
  • Features
  • Hardware Features Intel Fast Memory Access Technology
  • Expansion / Connectivity
  • Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
  • Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
  • Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
  • Additional connectors (optional) 4 x Hi-Speed USB
  • Miscellaneous
  • Included Accessories I/O back plate
  • Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
  • Software Included Drivers & utilities
  • Windows Vista Readiness Certified for Windows Vista
  • The Intel board is a discontinued product but is a better board than asus
    Sep 01, 2009 | Computers & Internet
    Sir can i change my processor to dual core using this asus p5v800-mx?
    Dear sir,
    Deffinately This Mother Board supports Dual core 2ghz-2.8Ghz And Pentium D 3GhzProcessors.You can Upgrade your PC.
    P5V800MX motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date. Enjoy the extraordinary CPU power from the latest dual-core CPU.
    Aug 04, 2009 | ASUS P5V800-MX Motherboard
    Is it compatible a intel dual core processor to a
    Hi..
    If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
    Good luck !!!
    Regards
    PCmania
    Jul 15, 2009 | ASUS P5PE-VM Motherboard
    How can i upgrade my intel(r) pentium r dual core 2.8 processor.
    http://www.mercury-pc.com/p-mainboards-list.php hello, try this link to id the board, as you will see 5 945 mercury mainboards. if you pick the one you have, like 945gcm for example, you can find out the fsb, cpu, memory. if you still need help, reply please rate this solution and good luck!
    Apr 29, 2009 | Intel Computers & Internet
    Can some one please let me know the name of the motherboard supporting Pentium 4 1.5 Ghz processor as well as Intel Core duo series of processors. Thanks, Ajay
    The chips to which you refer are incompatible with respect to the socket used for each as well as the fact that Core duo and Pentium 4 1.5 GHz chips are from separate generations, the latter having been obsolescent since 2003. Therefore, there is no single motherboard that supports both, and the Pentium 4, Socket 478 boards can be obtained from various aftermarket sources.
    Here is an example of the kind of board you need for your Pentium 4.
    $11 to $290 from 21 sellers
    ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 3 reviews
    ATA-100, Serial ATA-150, 0 MB / 4 GB (max), DDR SDRAM, Intel 865G, 4 x USB
    Prepare for the future with the Intel Desktop Board D865GBF, a platform that is truly a generation ahead. This ATX board features next-generation processor, dual-channel DDR400 memory support, integrated Intel Extreme Graphics 2, an AGP 8X slot, 8 USB 2.0 ports, integrated 6-channel audio and next-generation storage device support.
    FEATURES AND BENEFITS
    Support for the Intel Pentium 4 processors featuring Hyper-Threading Technology and 800-MHz system bus in the mPGA478-pin package. Also supports the Intel Pentium 4 processors (1.60a, 1.80a, 2a, 2.20 GHz or higher) with 533-MHz or 400-MHz system bus in the mPGA478 package.
    Intel 865G Chipset featuring Intel Extreme Graphics 2 using Dynamic Video Memory Technology (DVMT). Low-cost, high-performance graphics solution.
    Dual-Channel DDR400 SDRAM support: Four DIMM sockets designed to support up to 4 GB of DDR400 SDRAM memory (also supports DDR333 and DDR266). Flexible support for either single- or dual-channel operation.
    AGP 8X/4X graphics interface: Flexibility to upgrade via a high-end AGP graphics card.
    SATA150 and Ultra ATA100 connectors: Flexible support of new-generation SATA150 (2 ports) and current generation ATA (2 channels) storage devices. « less
    While the board for your Core Duo is widely available now
    Mar 26, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
    Intel processor E2200 LGA775 not working
    This motherboard supports Intel single core Pentium 4/ Celeron processors, according to the asus website.
    So your dual core is not supported.
    You need to get a intel pentium 4 or celeron processor
    Apr 04, 2008 | ASUS P5RD1-VM Motherboard
    Pc restart problem
    Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo"). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14. http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
    Oct 03, 2007 | ASUS P5LD2-VM Motherboard
    Ld ASUS P5LD2 DELUXE INTEL 945P CHIPSET SERIAL ATA300 ATX FORM FACTOR 2xPCI-E(X16)/1xPCI-E(X1)/3xPCI/4x... (MBP5LD2S) Motherboard Logo
    100 people viewed this question
    Top Ld Computers & Internet Experts
    David Payne
    David Payne
    Are you a Ld Computer and Internet Expert? Answer questions, earn points and help others
