Question about Maytag MSD2454G Side by Side Refrigerator
I have a refrigerator Model #MSD2456GEQ (Maytag Plus)
I have a refrigerator Model #MSD2456GEQ with Serial #105735582F and Rev. # 10. The outside water and ice is leaking underneath the
outside covering and rusting out the front of the refrigerator. The ice and water control buttons have also melted through so there is a hole where the light is. I would like very much to have someone from the factory take a look at this terrible looking appliance that should have not done this regardless of the factory warranty. Please advise. Esther Willeke
  • 1462 Answers
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
SOURCE: water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Posted on Nov 17, 2008
tborn6
  • 700 Answers
SOURCE: Change water filter for a maytag plus refrigerator
press the light switch button inside of the refrigerator five times.
Posted on Apr 03, 2009
localwonder
  • 6784 Answers
SOURCE: Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Dec 13, 2009
woodchuck789
  • 4070 Answers
SOURCE: Maytag MZD2766GES refrigerator quit cooling, both sides.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Remove the cardboard backing from the back bottom to access the compressor area.
Posted on Dec 20, 2009
How to replace an Dryer Drum Belt ?
check youtube for a lot of vids on this subject
Feb 14, 2018 | Maytag Performa PAV2200
I have a side by side Maytag mod #msd2456geq the ice tray is leaking into the ice cube bin causing one big lump.
Hi welcome to fix-ya, I would start by changing both watervalves. Not to hard just the cost. The valve numbers are 61005626 and 12001892, The cost at sears is 50.90 and 48.55. I hope this helps.
Sep 17, 2011 | Refrigerators
Our frig ice cube door chute keeps slaming and the lights are going crazy on the push button board. model MFI2568AES SER 10967637JR
Your control board is bad. Unplug refrigerator and replace it, follow instructions on board to reprogram and you should be good. It's on the back outside of refrigerator under panel. Or, call a repairman to do it for 400.00 plus. Hope this helps,
Oct 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I have a Maytag MSD2758GE side by side refrigerator/freezer whose thermostat/defrost assembly has gone bad. Obviously the freezer has iced up and isn't working properly, but would that effect the...
sounds like you need to replace the adaptive defrost assembly. and yes, it will effect the performance of the fridge. the part number is 12002104 if the first 2 numbers of your serial # is 22; or 61003990 if the 1st 2 numbers of your serial # is 10; or 61005988 if the 1st 2 numbers of your serial # is 17. here is a breakdown showing the location it is # 13 in the picture. hope this helps.250
Nov 07, 2009 | Maytag MSD2758GEB Side by Side...
How do I repair broken wall pins that hold up the shelves in my 10 year old maytag refridgerator
I believe maytag makes a repair kit take your model number and serial to a local appliance parts store. or call maytag good luck
Jul 08, 2009 | Maytag MSD2542VE Side by Side Refrigerator
What was the year of manufacture for refrigerator model HMG211747
go to this web site servicematters.com you will need the serial number off of your refrig. this is a maytag and whirlpool site but admiral is made by maytag. remember to use the serial number NOT the model number. thanks Peyton
Mar 12, 2009 | Refrigerators
Frig recall which model? Maytag refrigerator MTB2156GE* heard report of recall due to possible fire hazard
Name of product: Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand refrigerators
Units: About 1.6 million
Manufacturer: Maytag Corp., of Newton, Iowa
Hazard: An electrical failure in the relay, the component that turns on the refrigerator’s compressor, can cause overheating and pose a serious fire hazard.
Incidents/Injuries: Maytag has received 41 reports of refrigerator relay ignition, including 16 reports of property damage ranging from smoke damage to extensive kitchen damage.
Description: The recall includes certain Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand side by side and top freezer refrigerators. The affected refrigerators were manufactured in black, bisque, white and stainless steel. They have model and serial numbers printed on a label located on the top middle or left upper side of the refrigerator liner and have the following model and serial number combinations:
Serial Numbers ENDING with AND Model Numbers BEGINNING with Side by Side
Refrigerators AA, AC, AE, AG, AJ, AL, AN, AP, AR,
AT, AV, AX, CA, CC, CE, CG, CJ, CL,
ZB, ZD, ZF, ZH, ZK, ZM, ZQ, ZS, ZU,
ZW, ZY, ZZ ARS, CS, JC, JS, MS, MZ, PS Top Freezer
AT, AV, AX, ZK, ZM, ZQ, ZS, ZU, ZW,
ZY, ZZ AT, CT, MT, PT Refrigerators with freezers on the bottom are not included in this recall.
Sold at: Department and appliance stores and by homebuilders nationwide from January 2001 through January 2004 for between about $350 and $1600.
Manufactured in: United States
Remedy: Consumers should immediately contact Maytag to determine if their refrigerator is included in the recall and to schedule a free in-home repair. Consumers should not return the refrigerator to the retailer where it was purchased.
Consumer Contact: For more information, contact Maytag toll-free at (866) 533-9817 anytime,
Mar 10, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Dryer doesn't work.
Dry will not start, light is off. Power is on and working fine to dryer - is there a reset button?
Performa oversized Capacity Plus Model #PYE3360AYW .
Jan 18, 2009 | Maytag MAV3905EWW 13 Cycle Washer
Maytag MSD2454G Side by Side Refrigerator Logo
290 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
